cs_sat_coupling.cpp File Reference
#include <stdarg.h>
#include <ple_coupling.h>
#include <ple_locator.h>
#include "bft/bft_printf.h"
#include "fvm/fvm_nodal.h"
#include "fvm/fvm_writer.h"
#include "base/cs_ale.h"
#include "base/cs_assert.h"
#include "base/cs_array.h"
#include "atmo/cs_atmo.h"
#include "base/cs_base.h"
#include "base/cs_coupling.h"
#include "base/cs_mem.h"
#include "mesh/cs_mesh.h"
#include "mesh/cs_mesh_connect.h"
#include "base/cs_selector.h"
#include "base/cs_turbomachinery.h"
#include "base/cs_sat_coupling.h"
+ Include dependency graph for cs_sat_coupling.cpp:
void cs_sat_coupling_define (const char *saturne_name, const char *boundary_cpl_criteria, const char *volume_cpl_criteria, const char *boundary_loc_criteria, const char *volume_loc_criteria, int reverse, int verbosity)
 Define new code_saturne coupling. More...
int cs_sat_coupling_n_couplings (void)
cs_sat_coupling_t * cs_sat_coupling_by_id (int coupling_id)
void cs_sat_coupling_all_init (void)
void cs_sat_coupling_initialize (void)
 Initialization of main variables for code_saturne/code_saturne coupling. More...
void cs_sat_coupling_locate_all (void)
 Set the list of cells and boundary faces associated to a coupling and a cloud of point. More...
void cs_sat_coupling_add (const char *face_cpl_sel_c, const char *cell_cpl_sel_c, const char *face_loc_sel_c, const char *cell_loc_sel_c, const char *sat_name, int reverse, int verbosity)
void cs_sat_coupling_add_internal (cs_sat_coupling_tag_t *tag_func, void *tag_context, const char *boundary_cpl_criteria, const char *volume_cpl_criteria, const char *boundary_loc_criteria, const char *volume_loc_criteria, float loc_tolerance, int reverse, int verbosity)
void cs_sat_coupling_array_exchange (int cpl_id, cs_lnum_t nbrdis, cs_lnum_t nbrloc, cs_real_t *vardis, cs_real_t *varloc)
void cs_sat_coupling_exchange_at_cells (cs_field_t *f, cs_real_t *rhs, cs_real_t *fimp)
 code_saturne/code_saturne coupling using volumic source terms. More...
void cs_sat_coupling_bnd_initialize (int *bc_type)
 code_saturne/code_saturne boundary coupling initialization call More...
void cs_sat_coupling_exchange_at_bnd_faces (int *bc_type, cs_real_t *dt)
 code_saturne/code_saturne coupling using boundary conditions More...
void cs_sat_coupling_all_finalize (void)
◆ cs_sat_coupling_add()
void cs_sat_coupling_add ( const char *  face_cpl_sel_c,
const char *  cell_cpl_sel_c,
const char *  face_loc_sel_c,
const char *  cell_loc_sel_c,
const char *  sat_name,
int  reverse,
int  verbosity
◆ cs_sat_coupling_add_internal()
void cs_sat_coupling_add_internal ( cs_sat_coupling_tag_t *  tag_func,
void *  tag_context,
const char *  boundary_cpl_criteria,
const char *  volume_cpl_criteria,
const char *  boundary_loc_criteria,
const char *  volume_loc_criteria,
int  reverse,
int  verbosity
◆ cs_sat_coupling_all_finalize()
void cs_sat_coupling_all_finalize ( void  )
◆ cs_sat_coupling_all_init()
void cs_sat_coupling_all_init ( void  )
◆ cs_sat_coupling_array_exchange()
void cs_sat_coupling_array_exchange ( int  cpl_id,
cs_lnum_t  nbrdis,
cs_lnum_t  nbrloc,
cs_real_t *  vardis,
cs_real_t *  varloc
◆ cs_sat_coupling_bnd_initialize()
void cs_sat_coupling_bnd_initialize ( int *  bc_type)
[in]bc_typeboundary face types
◆ cs_sat_coupling_by_id()
cs_sat_coupling_t * cs_sat_coupling_by_id ( int  coupling_id)
◆ cs_sat_coupling_define()
void cs_sat_coupling_define ( const char *  saturne_name,
int  reverse,
int  verbosity
The arguments to cs_sat_coupling_define are:
[in]saturne_namematching code_saturne application name
[in]boundary_cpl_criteriaboundary face selection criteria for coupled faces, or nullptr
[in]volume_cpl_criteriacell selection criteria for coupled cells, or nullptr
[in]boundary_loc_criteriaboundary face selection criteria for location (not functional)
[in]volume_loc_criteriacell selection criteria for location
[in]reversereverse mode if 1
[in]verbosityverbosity level
In the case of only 2 code_saturne instances, the 'saturne_name' argument is ignored, as there is only one matching possibility.
In case of multiple couplings, a coupling will be matched with available code_saturne instances based on the 'saturne_name' argument.
◆ cs_sat_coupling_exchange_at_bnd_faces()
void cs_sat_coupling_exchange_at_bnd_faces ( int *  bc_type,
cs_real_t *  dt
[in]dttime step (per cell)
◆ cs_sat_coupling_exchange_at_cells()
void cs_sat_coupling_exchange_at_cells ( cs_field_t *  f,
cs_real_t *  rhs,
cs_real_t *  fimp
[in]fpointer to cs_field_t
[out]rhsExplicit terms (RHS)
[out]fimpImplicit source terms
◆ cs_sat_coupling_initialize()
void cs_sat_coupling_initialize ( void  )
◆ cs_sat_coupling_locate_all()
void cs_sat_coupling_locate_all ( void  )
The local "support" cells and boundary faces are used to locate the values in the distant "coupled" cells and faces. Depending on the role of sender and/or receiver of the current process in the coupling, some of these sets can be empty or not.
The cell values are always located and interpolated on the distant "cells" support. The face values are located and interpolated on the distant "face" support if present, or on the distant "cell" support if not.
If the input arrays LCESUP and LFBSUP are not ordered, they will be orderd in output.
◆ cs_sat_coupling_n_couplings()
int cs_sat_coupling_n_couplings ( void  )
