cs_saddle_solver.cpp File Reference
Set of functions to solve saddle-point problems. More...
#include <float.h>
#include <limits.h>
#include "base/cs_array.h"
#include "alge/cs_blas.h"
#include "cdo/cs_cdo_solve.h"
#include "base/cs_log.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "cdo/cs_saddle_system.h"
#include "alge/cs_saddle_solver.h"
+ Include dependency graph for cs_saddle_solver.cpp:
int cs_saddle_solver_get_n_systems (void)
 Retrieve the number of saddle-point systems which have been added. More...
cs_saddle_solver_t * cs_saddle_solver_by_id (int id)
 Get a pointer to a saddle-point solver from its id. More...
cs_saddle_solver_t * cs_saddle_solver_add (cs_lnum_t n1_elts, int n1_dofs_by_elt, cs_lnum_t n2_elts, int n2_dofs_by_elt, const cs_param_saddle_t *saddlep, cs_cdo_system_helper_t *sh, cs_sles_t *main_sles)
 Add a new solver for solving a saddle-point problem. More...
void cs_saddle_solver_finalize (void)
 Free all remaining structures related to saddle-point solvers. More...
void cs_saddle_solver_free (cs_saddle_solver_t **p_solver)
 Free a cs_saddle_solver_t structure. More...
void cs_saddle_solver_clean (cs_saddle_solver_t *solver)
 Free/reset only a part of a cs_saddle_solver_t structure. More...
void cs_saddle_solver_update_monitoring (cs_saddle_solver_t *solver, unsigned n_iter)
 Update the current monitoring state with n_iter. More...
void cs_saddle_solver_log_monitoring (void)
 Log the monitoring performance for all defined saddle-point solvers. More...
cs_real_t * cs_saddle_solver_m11_inv_lumped (cs_saddle_solver_t *solver, const cs_matrix_t *m11, const cs_range_set_t *b11_rset, cs_sles_t *xtra_sles, int *n_iter)
 Retrieve the lumped matrix the inverse of the diagonal of the (1,1)-block matrix. The storage of a matrix is in a gather view and the resulting array is in scatter view. More...
void cs_saddle_solver_m12_multiply_vector (cs_lnum_t n2_dofs, const cs_real_t *x2, const cs_adjacency_t *m21_adj, const cs_real_t *m21_val, cs_real_t *m12x2)
 Compute the resulting vector of the operation m12*x2 The stride is equal to 3 for the operator m21 (unassembled) x2 corresponds to a "scatter" view. More...
void cs_saddle_solver_m12_multiply_scalar (cs_lnum_t n2_elts, const cs_real_t *x2, const cs_adjacency_t *m21_adj, const cs_real_t *m21_val, cs_real_t *m12x2)
 Compute the resulting vector of the operation m12*x2 The stride is equal to 1 for the operator m21 (unassembled) x2 corresponds to a "scatter" view. More...
void cs_saddle_solver_m21_multiply_vector (cs_lnum_t n2_dofs, const cs_real_t *x1, const cs_adjacency_t *m21_adj, const cs_real_t *m21_val, cs_real_t *m21x1)
 Compute the resulting vector of the operation m21*x1 The stride is equal to 3 for the operator m21 operator x1 corresponds to a "scatter" view. More...
void cs_saddle_solver_m21_multiply_scalar (cs_lnum_t n2_dofs, const cs_real_t *x1, const cs_adjacency_t *m21_adj, const cs_real_t *m21_val, cs_real_t *m21x1)
 Compute the resulting vector of the operation m21*x1 The stride is equal to 1 for the operator m21 operator x1 corresponds to a "scatter" view. More...
void cs_saddle_solver_context_alu_create (cs_saddle_solver_t *solver)
 Create and initialize the context structure for an algorithm related to the ALU algorithm. More...
void cs_saddle_solver_context_alu_clean (cs_saddle_solver_context_alu_t *ctx)
 Free main memory consuming part of the context structure associated to an ALU algorithm. More...
void cs_saddle_solver_context_alu_free (cs_saddle_solver_context_alu_t **p_ctx)
 Free the context structure associated to an ALU algorithm. More...
void cs_saddle_solver_context_block_pcd_create (cs_lnum_t b22_max_size, cs_saddle_solver_t *solver)
 Create and initialize the context structure for a block preconditioner used in combination with a Krylov solver such as MINRES or GCR. More...
void cs_saddle_solver_context_block_pcd_clean (cs_saddle_solver_context_block_pcd_t *ctx)
 Free the main memory-consuming part of the context structure for a block preconditioner used in combination with a Krylov solver such as MINRES or GCR. More...
void cs_saddle_solver_context_block_pcd_free (cs_saddle_solver_context_block_pcd_t **p_ctx)
 Free the context structure for a block preconditioner used in combination with a Krylov solver such as MINRES or GCR. More...
void cs_saddle_solver_context_gkb_create (cs_saddle_solver_t *solver)
 Create and initialize the context structure for the GKB algorithm. More...
void cs_saddle_solver_context_gkb_clean (cs_saddle_solver_context_gkb_t *ctx)
 Free the main memory consuming part of the context structure associated to the GKB algorithm. More...
void cs_saddle_solver_context_gkb_free (cs_saddle_solver_context_gkb_t **p_ctx)
 Free the context structure associated to the GKB algorithm. More...
void cs_saddle_solver_context_notay_create (cs_saddle_solver_t *solver)
 Create and initialize the context structure for the algorithm relying on the Notay's algebraic transformation. More...
void cs_saddle_solver_context_uzawa_cg_create (cs_lnum_t b22_max_size, cs_saddle_solver_t *solver)
 Create and initialize the context structure for an algorithm related to the Uzawa-CG algorithm. More...
void cs_saddle_solver_context_uzawa_cg_clean (cs_saddle_solver_context_uzawa_cg_t *ctx)
 Free main memory consuming part of the context structure associated to a Uzawa-CG algorithm. More...
void cs_saddle_solver_context_uzawa_cg_free (cs_saddle_solver_context_uzawa_cg_t **p_ctx)
 Free the context structure associated to a Uzawa-CG algorithm. More...
void cs_saddle_solver_context_simple_create (cs_lnum_t b22_max_size, cs_saddle_solver_t *solver)
 Create and initialize the context structure for an algorithm related to the SIMPLE-like algorithm. More...
void cs_saddle_solver_context_simple_clean (cs_saddle_solver_context_simple_t *ctx)
 Free main memory consuming part of the context structure associated to a SIMPLE algorithm. More...
void cs_saddle_solver_context_simple_free (cs_saddle_solver_context_simple_t **p_ctx)
 Free the context structure associated to a SIMPLE algorithm. More...
void cs_saddle_solver_alu_incr (cs_saddle_solver_t *solver, cs_real_t *x1, cs_real_t *x2)
 Apply the Augmented Lagrangian-Uzawa algorithm to a saddle point problem (the system is stored in a hybrid way). The stride is equal to 1 for the matrix (db_size[3] = 1) and the vector. More...
void cs_saddle_solver_notay (cs_saddle_solver_t *solver, cs_real_t *x1, cs_real_t *x2)
 Apply the Notay's transformation algorithm to solve a saddle point problem (the system is stored in a monolithic way). More...
void cs_saddle_solver_minres (cs_saddle_solver_t *solver, cs_real_t *x1, cs_real_t *x2)
 Apply the MINRES algorithm to a saddle point problem (the system is stored in a hybrid way). The stride is equal to 1 for the matrix (db_size[3] = 1) and the vector. More...
void cs_saddle_solver_gcr (cs_saddle_solver_t *solver, cs_real_t *x1, cs_real_t *x2)
 Apply the GCR algorithm to a saddle point problem (the system is stored in a hybrid way). The stride is equal to 1 for the matrix in the (1,1) block (db_size[3] = 1). More...
void cs_saddle_solver_gkb_inhouse (cs_saddle_solver_t *solver, cs_real_t *x1, cs_real_t *x2)
 Apply the GKB algorithm to a saddle point problem (the system is stored in a hybrid way). The stride is equal to 1 for the matrix in the (1,1) block (db_size[3] = 1). More...
void cs_saddle_solver_sles_full_system (cs_saddle_solver_t *solver, cs_real_t *x1, cs_real_t *x2)
 Apply an (external) solver to solve a saddle point problem (the system is stored in a monolithic way). More...
void cs_saddle_solver_uzawa_cg (cs_saddle_solver_t *solver, cs_real_t *x1, cs_real_t *x2)
 Apply the Uzawa-CG algorithm to solve a saddle point problem (the system is stored in a hybrid way). This algorithm is based on Koko's paper "Uzawa conjugate gradient method for the Stokes problem: Matlab implementation with P1-iso-P2/ P1 finite element". More...
void cs_saddle_solver_simple (cs_saddle_solver_t *solver, cs_real_t *x1, cs_real_t *x2)
 Apply the SIMPLE-like algorithm to solve a saddle point problem. More...
◆ cs_saddle_solver_add()
cs_saddle_solver_t * cs_saddle_solver_add ( cs_lnum_t  n1_elts,
int  n1_dofs_by_elt,
cs_lnum_t  n2_elts,
int  n2_dofs_by_elt,
const cs_param_saddle_t *  saddlep,
cs_cdo_system_helper_t *  sh,
cs_sles_t *  main_sles
[in]n1_eltsnumber of elements associated to the (1,1)-block
[in]n1_dofs_by_eltnumber of DoFs by elements in the (1,1)-block
[in]n2_eltsnumber of elements associated to the (2,2)-block
[in]n2_dofs_by_eltnumber of DoFs by elements in the (2,2)-block
[in]saddlepset of parameters for the saddle-point solver
[in]shpointer to a system helper structure
[in]main_slespointer to the main SLES structure related to this saddle-point problem
a pointer to the new allocated structure
◆ cs_saddle_solver_alu_incr()
void cs_saddle_solver_alu_incr ( cs_saddle_solver_t *  solver,
cs_real_t *  x1,
cs_real_t *  x2
[in,out]solverpointer to a saddle_point solver structure
[in,out]x1array for the first part
[in,out]x2array for the second part
◆ cs_saddle_solver_by_id()
cs_saddle_solver_t * cs_saddle_solver_by_id ( int  id)
Get a pointer to saddle-point solver from its id.
[in]idid of the saddle-point system
a pointer to a saddle-point solver structure
◆ cs_saddle_solver_clean()
void cs_saddle_solver_clean ( cs_saddle_solver_t *  solver)
[in,out]solverdouble pointer to the structure to free
◆ cs_saddle_solver_context_alu_clean()
void cs_saddle_solver_context_alu_clean ( cs_saddle_solver_context_alu_t *  ctx)
[in,out]ctxpointer to the context structure to clean
◆ cs_saddle_solver_context_alu_create()
void cs_saddle_solver_context_alu_create ( cs_saddle_solver_t *  solver)
[in,out]solverpointer to a saddle-point solver structure
◆ cs_saddle_solver_context_alu_free()
void cs_saddle_solver_context_alu_free ( cs_saddle_solver_context_alu_t **  p_ctx)
[in,out]p_ctxdouble pointer to the context structure to free
◆ cs_saddle_solver_context_block_pcd_clean()
void cs_saddle_solver_context_block_pcd_clean ( cs_saddle_solver_context_block_pcd_t *  ctx)
[in,out]ctxpointer to the context structure to free
◆ cs_saddle_solver_context_block_pcd_create()
void cs_saddle_solver_context_block_pcd_create ( cs_lnum_t  b22_max_size,
[in]b22_max_sizemax. size for the second part of unknows
◆ cs_saddle_solver_context_block_pcd_free()
void cs_saddle_solver_context_block_pcd_free ( cs_saddle_solver_context_block_pcd_t **  p_ctx)
◆ cs_saddle_solver_context_gkb_clean()
void cs_saddle_solver_context_gkb_clean ( cs_saddle_solver_context_gkb_t *  ctx)
◆ cs_saddle_solver_context_gkb_create()
void cs_saddle_solver_context_gkb_create ( cs_saddle_solver_t *  solver)
◆ cs_saddle_solver_context_gkb_free()
void cs_saddle_solver_context_gkb_free ( cs_saddle_solver_context_gkb_t **  p_ctx)
◆ cs_saddle_solver_context_notay_create()
void cs_saddle_solver_context_notay_create ( cs_saddle_solver_t *  solver)
◆ cs_saddle_solver_context_simple_clean()
void cs_saddle_solver_context_simple_clean ( cs_saddle_solver_context_simple_t *  ctx)
◆ cs_saddle_solver_context_simple_create()
void cs_saddle_solver_context_simple_create ( cs_lnum_t  b22_max_size,
Create and initialize the context structure for an algorithm related to the SIMPLE algorithm.
◆ cs_saddle_solver_context_simple_free()
void cs_saddle_solver_context_simple_free ( cs_saddle_solver_context_simple_t **  p_ctx)
◆ cs_saddle_solver_context_uzawa_cg_clean()
void cs_saddle_solver_context_uzawa_cg_clean ( cs_saddle_solver_context_uzawa_cg_t *  ctx)
◆ cs_saddle_solver_context_uzawa_cg_create()
void cs_saddle_solver_context_uzawa_cg_create ( cs_lnum_t  b22_max_size,
◆ cs_saddle_solver_context_uzawa_cg_free()
void cs_saddle_solver_context_uzawa_cg_free ( cs_saddle_solver_context_uzawa_cg_t **  p_ctx)
◆ cs_saddle_solver_finalize()
void cs_saddle_solver_finalize ( void  )
◆ cs_saddle_solver_free()
void cs_saddle_solver_free ( cs_saddle_solver_t **  p_solver)
[in,out]p_solverdouble pointer to the structure to free
◆ cs_saddle_solver_gcr()
void cs_saddle_solver_gcr ( cs_saddle_solver_t *  solver,
cs_real_t *  x1,
cs_real_t *  x2
This algorithm is taken from 2010 Notay's paper: "An aggregation-based algebraic multigrid method" ETNA (vol. 37)
◆ cs_saddle_solver_get_n_systems()
int cs_saddle_solver_get_n_systems ( void  )
the current number of systems
◆ cs_saddle_solver_gkb_inhouse()
void cs_saddle_solver_gkb_inhouse ( cs_saddle_solver_t *  solver,
cs_real_t *  x1,
cs_real_t *  x2
◆ cs_saddle_solver_log_monitoring()
void cs_saddle_solver_log_monitoring ( void  )
Log the monitoring performance of all saddle-point systems.
◆ cs_saddle_solver_m11_inv_lumped()
cs_real_t * cs_saddle_solver_m11_inv_lumped ( cs_saddle_solver_t *  solver,
const cs_matrix_t *  m11,
const cs_range_set_t *  b11_rset,
cs_sles_t *  xtra_sles,
int *  n_iter
[in]solversolver for saddle-point problems
[in]m11matrix related to the (1,1) block
[in]b11_rsetrange set structure for the (1,1) block
[in,out]xtra_slespointer to an extra SLES structure
[out]n_iternumber of iterations for this operation
a pointer to the computed array (scatter view)
◆ cs_saddle_solver_m12_multiply_scalar()
void cs_saddle_solver_m12_multiply_scalar ( cs_lnum_t  n2_elts,
const cs_real_t *  x2,
const cs_adjacency_t *  m21_adj,
const cs_real_t *  m21_val,
cs_real_t *  m12x2
This is an update operation. Be careful that the resulting array has to be initialized.
[in]n2_eltsnumber of elements for x2 (not DoFs)
[in]x2array for the second set
[in]m21_adjadjacency related to the M21 operator
[in]m21_valarray associated to the M21 operator (unassembled)
[in,out]m12x2resulting array (have to be allocated)
◆ cs_saddle_solver_m12_multiply_vector()
void cs_saddle_solver_m12_multiply_vector ( cs_lnum_t  n2_dofs,
cs_real_t *  m12x2
[in]n2_dofsnumber of DoFs for x2
◆ cs_saddle_solver_m21_multiply_scalar()
void cs_saddle_solver_m21_multiply_scalar ( cs_lnum_t  n2_dofs,
const cs_real_t *  x1,
cs_real_t *  m21x1
[in]n2_dofsnumber of (scatter) DoFs for (2,2)-block
[in]x1array for the first part
[in]m21_valvalues associated to the M21 operator (unassembled)
[in,out]m21x1resulting vector (have to be allocated)
◆ cs_saddle_solver_m21_multiply_vector()
void cs_saddle_solver_m21_multiply_vector ( cs_lnum_t  n2_dofs,
cs_real_t *  m21x1
◆ cs_saddle_solver_minres()
void cs_saddle_solver_minres ( cs_saddle_solver_t *  solver,
cs_real_t *  x1,
cs_real_t *  x2
◆ cs_saddle_solver_notay()
void cs_saddle_solver_notay ( cs_saddle_solver_t *  solver,
cs_real_t *  x1,
cs_real_t *  x2
[in,out]solverpointer to a cs_saddle_solver_t structure
◆ cs_saddle_solver_simple()
void cs_saddle_solver_simple ( cs_saddle_solver_t *  solver,
cs_real_t *  x1,
cs_real_t *  x2
◆ cs_saddle_solver_sles_full_system()
void cs_saddle_solver_sles_full_system ( cs_saddle_solver_t *  solver,
cs_real_t *  x1,
cs_real_t *  x2
◆ cs_saddle_solver_update_monitoring()
void cs_saddle_solver_update_monitoring ( cs_saddle_solver_t *  solver,
unsigned  n_iter
[in,out]solverpointer to a saddle solver structure
[in]n_iternumber of iterations needed for a new call
◆ cs_saddle_solver_uzawa_cg()
void cs_saddle_solver_uzawa_cg ( cs_saddle_solver_t *  solver,
cs_real_t *  x1,
cs_real_t *  x2
