cs_parameters.cpp File Reference
#include <stdarg.h>
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "atmo/cs_at_opt_interp.h"
#include "base/cs_ale.h"
#include "base/cs_field.h"
#include "alge/cs_gradient.h"
#include "base/cs_log.h"
#include "base/cs_map.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "base/cs_post.h"
#include "base/cs_parall.h"
#include "base/cs_parameters_check.h"
#include "base/cs_renumber.h"
#include "base/cs_restart.h"
#include "base/cs_restart_default.h"
#include "rayt/cs_rad_transfer_fields.h"
#include "base/cs_syr_coupling.h"
#include "base/cs_time_moment.h"
#include "cfbl/cs_cf_model.h"
#include "base/cs_sat_coupling.h"
#include "base/cs_tree.h"
#include "base/cs_turbomachinery.h"
#include "base/cs_velocity_pressure.h"
#include "base/cs_vof.h"
#include "base/cs_wall_functions.h"
+ Include dependency graph for cs_parameters.cpp:
cs_space_disc_t * cs_get_glob_space_disc (void)
 Provide access to cs_glob_space_disc. More...
cs_time_scheme_t * cs_get_glob_time_scheme (void)
 Provide access to cs_glob_time_scheme. More...
void cs_parameters_set_init_state_on (int idx)
 Set init state to 1. This is necessary for fortran mapping and should be changed in the future. More...
void cs_parameters_define_field_keys (void)
 Define general field keys. More...
void cs_parameters_read_restart_info (void)
 Read general restart info. More...
void cs_parameters_add_variable (const char *name, int dim)
 Define a user variable. More...
void cs_parameters_add_variable_variance (const char *name, const char *variable_name)
 Define a user variable which is a variance of another variable. More...
void cs_parameters_add_property (const char *name, int dim, int location_id)
 Define a user property. More...
int cs_parameters_n_added_variables (void)
 Return the number of defined user variables not added yet. More...
int cs_parameters_n_added_properties (void)
 Return the number of defined user properties not added yet. More...
void cs_parameters_create_added_variables (void)
 Create previously added user variables. More...
void cs_parameters_define_auxiliary_fields (void)
 Create auxiliary fields for some numerical algorithms. More...
void cs_parameters_create_added_properties (void)
 Create previously added user properties. More...
void cs_add_model_field_indexes (cs_field_t *f)
 Add field indexes associated with a new non-user solved scalar variable, with default options. More...
cs_field_t * cs_parameters_add_boundary_values (cs_field_t *f)
 Define a boundary values field for a variable field. More...
cs_field_t * cs_parameters_add_boundary_temperature (void)
 Define a boundary values field for temperature, if applicable. More...
bool cs_parameters_need_extended_neighborhood (void)
 Check if extended neighborhood is needed. More...
void cs_parameters_global_complete (void)
 Complete global parameters. More...
void cs_parameters_eqp_complete (void)
 Complete general equation parameter definitions. More...
void cs_parameters_output_complete (void)
 Complete general output option definitions. More...
cs_equation_param_t cs_parameters_equation_param_default (void)
 Return a local equation param structure, with default options. More...
void cs_time_scheme_log_setup (void)
 Print the time scheme structure to setup.log. More...
void cs_space_disc_log_setup (void)
 Print the space discretization structure to setup.log. More...
General parameters and options management.
◆ cs_add_model_field_indexes()
void cs_add_model_field_indexes ( cs_field_t *  f)
[in,out]ffield
◆ cs_get_glob_space_disc()
cs_space_disc_t * cs_get_glob_space_disc ( void  )
space discretization description structure
◆ cs_get_glob_time_scheme()
cs_time_scheme_t * cs_get_glob_time_scheme ( void  )
time scheme information structure
◆ cs_parameters_add_boundary_temperature()
cs_field_t * cs_parameters_add_boundary_temperature ( void  )
When a volume temperature variable field already exists, this amounts to calling cs_parameters_add_boundary_values for that field. When such a variable does not exist but we have an Enthalpy variables, an associated temperature boundary field is returned.
pointer to boundary values field, or null if not applicable
◆ cs_parameters_add_boundary_values()
cs_field_t * cs_parameters_add_boundary_values ( cs_field_t *  f)
[in,out]fpointer to field structure
◆ cs_parameters_add_property()
void cs_parameters_add_property ( const char *  name,
int  dim,
int  location_id
[in]namename of property and associated field
[in]dimproperty dimension
[in]location_idid of associated mesh location
◆ cs_parameters_add_variable()
void cs_parameters_add_variable ( const char *  name,
int  dim
[in]namename of variable and associated field
[in]dimvariable dimension
◆ cs_parameters_add_variable_variance()
void cs_parameters_add_variable_variance ( const char *  name,
const char *  variable_name
[in]namename of variance and associated field
[in]variable_namename of associated variable
◆ cs_parameters_create_added_properties()
void cs_parameters_create_added_properties ( void  )
◆ cs_parameters_create_added_variables()
void cs_parameters_create_added_variables ( void  )
◆ cs_parameters_define_auxiliary_fields()
void cs_parameters_define_auxiliary_fields ( void  )
Create properties definied directly in C.
◆ cs_parameters_define_field_keys()
void cs_parameters_define_field_keys ( void  )
◆ cs_parameters_eqp_complete()
void cs_parameters_eqp_complete ( void  )
Also set associated field properties such as number of associated time values.
◆ cs_parameters_equation_param_default()
cs_equation_param_t cs_parameters_equation_param_default ( void  )
◆ cs_parameters_global_complete()
void cs_parameters_global_complete ( void  )
◆ cs_parameters_n_added_properties()
int cs_parameters_n_added_properties ( void  )
◆ cs_parameters_n_added_variables()
int cs_parameters_n_added_variables ( void  )
◆ cs_parameters_need_extended_neighborhood()
bool cs_parameters_need_extended_neighborhood ( void  )
true if extended neighborhoo is needed, false otherwise.
◆ cs_parameters_output_complete()
void cs_parameters_output_complete ( void  )
Complete general output options definitions.
◆ cs_parameters_read_restart_info()
void cs_parameters_read_restart_info ( void  )
This updates the previous time step info and notebook varaibles values.
◆ cs_parameters_set_init_state_on()
void cs_parameters_set_init_state_on ( int  idx)
[in]idxid of variable. 1 density.
◆ cs_space_disc_log_setup()
void cs_space_disc_log_setup ( void  )
◆ cs_time_scheme_log_setup()
void cs_time_scheme_log_setup ( void  )
