cs_navsto_param.cpp File Reference
#include <float.h>
#include <ctype.h>
#include "base/cs_mem.h"
#include "bft/bft_printf.h"
#include "base/cs_base.h"
#include "cdo/cs_equation.h"
#include "base/cs_log.h"
#include "cdo/cs_navsto_param.h"
+ Include dependency graph for cs_navsto_param.cpp:
cs_navsto_param_t * cs_navsto_param_create (const cs_boundary_t *boundaries, cs_navsto_param_model_t model, cs_navsto_param_model_flag_t model_flag, cs_navsto_param_coupling_t algo_coupling, cs_navsto_param_post_flag_t post_flag)
 Create a new structure to store all numerical parameters related to the resolution of the Navier-Stokes (NS) system. More...
cs_navsto_param_t * cs_navsto_param_free (cs_navsto_param_t *param)
 Free a cs_navsto_param_t structure. More...
void cs_navsto_param_set (cs_navsto_param_t *nsp, cs_navsto_key_t key, const char *keyval)
 Set a parameter attached to a keyname in a cs_navsto_param_t structure. More...
void cs_navsto_param_transfer (const cs_navsto_param_t *nsp, cs_equation_param_t *eqp)
 Apply the numerical settings defined for the Navier-Stokes system to an equation related to this system. Be aware that the user-defined settings can be modified in this function when a different choice is set between the settings for the Navier-Stokes system and the settings for the momentum equation. The final choice is given by the settings for the Navier-Stokes system. More...
void cs_navsto_param_log (const cs_navsto_param_t *nsp)
 Summary of the main cs_navsto_param_t structure. More...
cs_navsto_param_boussinesq_t * cs_navsto_param_add_boussinesq_term (cs_navsto_param_t *nsp, cs_real_t dilatation_coef, cs_real_t reference_value)
 Add a new Boussinesq term (source term for the momemtum equation) More...
void cs_navsto_param_set_boussinesq_array (cs_navsto_param_boussinesq_t *bp, const cs_real_t *var)
 Set the array of values to consider in the Boussinesq term. More...
cs_equation_param_t * cs_navsto_param_get_velocity_param (const cs_navsto_param_t *nsp)
 Retrieve the cs_equation_param_t structure related to the velocity equation (momentum equation in most of the cases) More...
const char * cs_navsto_param_get_model_name (cs_navsto_param_model_t model)
 Retrieve the name of the model system of equations. More...
const char * cs_navsto_param_get_coupling_name (cs_navsto_param_coupling_t coupling)
 Retrieve the name of the coupling algorithm. More...
void cs_navsto_set_reference_pressure (cs_navsto_param_t *nsp, cs_real_t pref)
 Set the value to consider for the reference pressure. More...
void cs_navsto_param_set_quadrature_to_all (cs_navsto_param_t *nsp, cs_quadrature_type_t qtype)
 Apply the given quadrature rule to all existing definitions under the cs_navsto_param_t structure. More...
cs_xdef_t * cs_navsto_add_velocity_ic_by_value (cs_navsto_param_t *nsp, const char *z_name, const cs_real_3_t val)
 Define the initial condition for the velocity unknowns. This definition can be done on a specified mesh location. By default, the unknown is set to zero everywhere. Here the initial value is set to a constant value. More...
cs_xdef_t * cs_navsto_add_velocity_ic_by_analytic (cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *analytic, void *input)
 Define the initial condition for the velocity unknowns. This definition can be done on a specified mesh location. By default, the unknown is set to zero everywhere. Here the initial value is set according to an analytical function. More...
cs_xdef_t * cs_navsto_add_pressure_ic_by_value (cs_navsto_param_t *nsp, const char *z_name, cs_real_t val)
 Define the initial condition for the pressure unknowns. This definition can be done on a specified mesh location. By default, the unknown is set to zero everywhere. Here the initial value is set to a constant value. More...
cs_xdef_t * cs_navsto_add_pressure_ic_by_analytic (cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *analytic, void *input)
 Define the initial condition for the pressure unknowns. This definition can be done on a specified mesh location. By default, the unknown is set to zero everywhere. Here the initial value is set according to an analytical function. More...
void cs_navsto_set_fixed_walls (cs_navsto_param_t *nsp)
 Add the definition of boundary conditions related to a fixed wall into the set of parameters for the management of the Navier-Stokes system of equations. More...
void cs_navsto_set_symmetries (cs_navsto_param_t *nsp)
 Add the definition of boundary conditions related to a symmetry into the set of parameters for the management of the Navier-Stokes system of equations. More...
void cs_navsto_set_outlets (cs_navsto_param_t *nsp)
 Add the definition of boundary conditions related to outlets into the set of parameters for the management of the Navier-Stokes system of equations. More...
cs_xdef_t * cs_navsto_set_pressure_bc_by_value (cs_navsto_param_t *nsp, const char *z_name, cs_real_t values)
 Set the pressure field on a boundary using a uniform value. More...
cs_xdef_t * cs_navsto_set_velocity_wall_by_value (cs_navsto_param_t *nsp, const char *z_name, const cs_real_3_t values)
 Define the velocity field for a sliding wall boundary using a uniform value. More...
cs_xdef_t * cs_navsto_set_velocity_inlet_by_value (cs_navsto_param_t *nsp, const char *z_name, const cs_real_3_t values)
 Define the velocity field for an inlet boundary using a uniform value. More...
cs_xdef_t * cs_navsto_set_velocity_inlet_by_analytic (cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *ana, void *input)
 Define the velocity field for an inlet boundary using an analytical function. More...
cs_xdef_t * cs_navsto_set_velocity_inlet_by_array (cs_navsto_param_t *nsp, const char *z_name, cs_flag_t loc, cs_real_t *array, bool is_owner, bool full_length)
 Define the velocity field for an inlet boundary using an array of values. More...
cs_xdef_t * cs_navsto_set_velocity_inlet_by_dof_func (cs_navsto_param_t *nsp, const char *z_name, cs_flag_t dof_loc, cs_dof_func_t *func, void *func_input)
 Define the velocity field for an inlet boundary using a DoF function. More...
cs_xdef_t * cs_navsto_add_source_term_by_analytic (cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *ana, void *input)
 Define a new source term structure defined by an analytical function. More...
cs_xdef_t * cs_navsto_add_source_term_by_value (cs_navsto_param_t *nsp, const char *z_name, const cs_real_3_t val)
 Define a new source term structure defined by a constant value. More...
cs_xdef_t * cs_navsto_add_source_term_by_array (cs_navsto_param_t *nsp, const char *z_name, cs_flag_t loc, cs_real_t *array, bool is_owner, bool full_length)
 Define a new source term structure defined by an array. More...
void cs_navsto_add_oseen_field (cs_navsto_param_t *nsp, cs_adv_field_t *adv_fld)
 Add a advection field for the Oseen problem. More...
◆ cs_navsto_add_oseen_field()
void cs_navsto_add_oseen_field ( cs_navsto_param_t *  nsp,
cs_adv_field_t *  adv_fld
[in,out]nsppointer to a cs_navsto_param_t
[in,out]adv_fldpointer to a cs_adv_field_t
◆ cs_navsto_add_pressure_ic_by_analytic()
cs_xdef_t * cs_navsto_add_pressure_ic_by_analytic ( cs_navsto_param_t *  nsp,
const char *  z_name,
cs_analytic_func_t *  analytic,
void *  input
[in]z_namename of the associated zone (if null or "" if all cells are considered)
[in]analyticpointer to an analytic function
[in]inputnull or pointer to a structure cast on-the-fly
a pointer to the new cs_xdef_t structure
◆ cs_navsto_add_pressure_ic_by_value()
cs_xdef_t * cs_navsto_add_pressure_ic_by_value ( cs_navsto_param_t *  nsp,
cs_real_t  val
[in]valpointer to the value
◆ cs_navsto_add_source_term_by_analytic()
cs_xdef_t * cs_navsto_add_source_term_by_analytic ( cs_navsto_param_t *  nsp,
cs_analytic_func_t *  ana,
void *  input
[in]z_namename of the associated zone (if null or "" all cells are considered)
[in]anapointer to an analytical function
◆ cs_navsto_add_source_term_by_array()
cs_xdef_t * cs_navsto_add_source_term_by_array ( cs_navsto_param_t *  nsp,
cs_flag_t  loc,
cs_real_t *  array,
bool  is_owner,
bool  full_length
[in]locinformation to know where are located values
[in]arraypointer to an array
[in]is_ownertransfer the lifecycle to the cs_xdef_t structure (true or false)
[in]full_lengthif true, array size is allocated and filled to access the full-length array corresponding to all locations where are defined the values
◆ cs_navsto_add_source_term_by_value()
cs_xdef_t * cs_navsto_add_source_term_by_value ( cs_navsto_param_t *  nsp,
[in]valvector value to set
◆ cs_navsto_add_velocity_ic_by_analytic()
cs_xdef_t * cs_navsto_add_velocity_ic_by_analytic ( cs_navsto_param_t *  nsp,
void *  input
◆ cs_navsto_add_velocity_ic_by_value()
cs_xdef_t * cs_navsto_add_velocity_ic_by_value ( cs_navsto_param_t *  nsp,
[in]valvector values to set
◆ cs_navsto_param_add_boussinesq_term()
cs_navsto_param_boussinesq_t * cs_navsto_param_add_boussinesq_term ( cs_navsto_param_t *  nsp,
[in,out]nsppointer to a cs_navsto_param_t struct.
[in]dilatation_coefvalue of the dilatation coefficient
[in]reference_valuereference value of the associated variable
a pointer to the newly added structure
◆ cs_navsto_param_create()
cs_navsto_param_t * cs_navsto_param_create ( const cs_boundary_t *  boundaries,
[in]boundariespointer to a cs_boundary_t structure
[in]modeltype of model related to the NS system
[in]model_flagadditional high-level model options
[in]algo_couplingalgorithm used for solving the NS system
[in]post_flagpredefined post-processings options
a pointer to a new allocated structure
◆ cs_navsto_param_free()
cs_navsto_param_t * cs_navsto_param_free ( cs_navsto_param_t *  param)
[in,out]parampointer to a cs_navsto_param_t structure
a null pointer
◆ cs_navsto_param_get_coupling_name()
const char * cs_navsto_param_get_coupling_name ( cs_navsto_param_coupling_t  coupling)
[in]couplinga cs_navsto_param_coupling_t
the name
◆ cs_navsto_param_get_model_name()
const char * cs_navsto_param_get_model_name ( cs_navsto_param_model_t  model)
[in]modela cs_navsto_param_model_t
the corresponding name
◆ cs_navsto_param_get_velocity_param()
cs_equation_param_t * cs_navsto_param_get_velocity_param ( const cs_navsto_param_t *  nsp)
a pointer to the set of parameters related to the momentum equation
◆ cs_navsto_param_log()
void cs_navsto_param_log ( const cs_navsto_param_t *  nsp)
◆ cs_navsto_param_set()
void cs_navsto_param_set ( cs_navsto_param_t *  nsp,
const char *  keyval
[in,out]nsppointer to a cs_navsto_param_t structure to set
[in]keykey related to the member of eq to set
[in]keyvalaccessor to the value to set
◆ cs_navsto_param_set_boussinesq_array()
void cs_navsto_param_set_boussinesq_array ( cs_navsto_param_boussinesq_t *  bp,
const cs_real_t *  var
[in,out]bppointer to a cs_navsto_param_boussinesq_t structure
[in]varshared pointer to the array of values to consider
◆ cs_navsto_param_set_quadrature_to_all()
void cs_navsto_param_set_quadrature_to_all ( cs_navsto_param_t *  nsp,
[in]qtypetype of quadrature to apply
◆ cs_navsto_param_transfer()
void cs_navsto_param_transfer ( const cs_navsto_param_t *  nsp,
cs_equation_param_t *  eqp
[in,out]eqppointer to a cs_equation_param_t structure
◆ cs_navsto_set_fixed_walls()
void cs_navsto_set_fixed_walls ( cs_navsto_param_t *  nsp)
◆ cs_navsto_set_outlets()
void cs_navsto_set_outlets ( cs_navsto_param_t *  nsp)
◆ cs_navsto_set_pressure_bc_by_value()
cs_xdef_t * cs_navsto_set_pressure_bc_by_value ( cs_navsto_param_t *  nsp,
cs_real_t  values
[in]z_namename of the associated zone (if null or "" all boundary faces are considered)
[in]valuesvalue to set
◆ cs_navsto_set_reference_pressure()
void cs_navsto_set_reference_pressure ( cs_navsto_param_t *  nsp,
cs_real_t  pref
[in]prefvalue of the reference pressure
◆ cs_navsto_set_symmetries()
void cs_navsto_set_symmetries ( cs_navsto_param_t *  nsp)
◆ cs_navsto_set_velocity_inlet_by_analytic()
cs_xdef_t * cs_navsto_set_velocity_inlet_by_analytic ( cs_navsto_param_t *  nsp,
void *  input
◆ cs_navsto_set_velocity_inlet_by_array()
cs_xdef_t * cs_navsto_set_velocity_inlet_by_array ( cs_navsto_param_t *  nsp,
cs_flag_t  loc,
cs_real_t *  array,
bool  is_owner,
bool  full_length
[in]full_lengthif true, the size of "array" should be allocated to the total numbers of entities related to the given location. If false, a new list is allocated and filled with the related subset indirection.
◆ cs_navsto_set_velocity_inlet_by_dof_func()
cs_xdef_t * cs_navsto_set_velocity_inlet_by_dof_func ( cs_navsto_param_t *  nsp,
cs_flag_t  dof_loc,
cs_dof_func_t *  func,
void *  func_input
[in]dof_locwhere are located DoFs
[in]funcpointer to a cs_dof_function_t
[in]func_inputnull or pointer to a structure cast on-the-fly
◆ cs_navsto_set_velocity_inlet_by_value()
cs_xdef_t * cs_navsto_set_velocity_inlet_by_value ( cs_navsto_param_t *  nsp,
[in]valuesarray of three real values
◆ cs_navsto_set_velocity_wall_by_value()
cs_xdef_t * cs_navsto_set_velocity_wall_by_value ( cs_navsto_param_t *  nsp,
