cs_matrix_default.cpp File Reference
#include <stdarg.h>
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "base/cs_base.h"
#include "alge/cs_blas.h"
#include "base/cs_field.h"
#include "base/cs_halo.h"
#include "base/cs_halo_perio.h"
#include "base/cs_internal_coupling.h"
#include "base/cs_log.h"
#include "base/cs_mem.h"
#include "mesh/cs_mesh.h"
#include "mesh/cs_mesh_adjacencies.h"
#include "base/cs_numbering.h"
#include "base/cs_range_set.h"
#include "base/cs_timer.h"
#include "alge/cs_matrix.h"
#include "alge/cs_matrix_priv.h"
#include "alge/cs_matrix_tuning.h"
#include "alge/cs_matrix_default.h"
+ Include dependency graph for cs_matrix_default.cpp:
void cs_matrix_vector_native_multiply (bool symmetric, cs_lnum_t db_size, cs_lnum_t eb_size, int f_id, const cs_real_t *dam, const cs_real_t *xam, cs_real_t *vx, cs_real_t *vy)
void cs_matrix_initialize (void)
void cs_matrix_finalize (void)
void cs_matrix_update_mesh (void)
cs_matrix_t * cs_matrix_default (bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size)
cs_matrix_t * cs_matrix_msr (void)
cs_matrix_t * cs_matrix_csr (void)
cs_matrix_t * cs_matrix_native (void)
cs_matrix_t * cs_matrix_external (const char *type_name, bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size)
 Return matrix wrapper for external library for a given fill type. More...
cs_matrix_t * cs_matrix_copy_to_external (cs_matrix_t *src, bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size)
 Copy base matrix to external library matrix type for given fill type. More...
void cs_matrix_default_set_tuned (cs_matrix_t *m)
void cs_matrix_set_tuning_runs (int n_min_products)
int cs_matrix_get_tuning_runs (void)
void cs_matrix_default_set_type (cs_matrix_fill_type_t fill_type, cs_matrix_type_t type)
 Set default matrix type for a given fill type. More...
const cs_gnum_t * cs_matrix_get_block_row_g_id (const cs_matrix_t *m)
 Return a (0-based) global block row numbering for a given matrix. More...
const cs_gnum_t * cs_matrix_get_block_row_g_id (const cs_matrix_t *m, const cs_halo_t *halo)
cs_matrix_t * cs_matrix_by_assembler (const cs_field_t *f, cs_matrix_type_t type)
 Return matrix associated with a matrix assembler. More...
cs_matrix_t * cs_matrix_set_coefficients_by_assembler (const cs_field_t *f, cs_matrix_type_t type, bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size, const cs_real_t *da, const cs_real_t *xa)
 Assign coefficients to a matrix using a matrix assembler. More...
void cs_matrix_release (cs_matrix_t **m)
◆ cs_matrix_by_assembler()
cs_matrix_t * cs_matrix_by_assembler ( const cs_field_t *  f,
Coefficients are not assigned at this stage.
[in]fpointer to associated field
[in]typematrix type
pointer to associated matrix structure
◆ cs_matrix_copy_to_external()
cs_matrix_t * cs_matrix_copy_to_external ( cs_matrix_t *  src,
bool  symmetric,
Coefficients and matching structures are not copied or created.
This function is intended to allow sharing of a base structure or assembler with an external library matrix wrapper, so as to allow efficient coefficient assignment, but with external coefficient handling.
The matrix shoud be converted to the desired external type after calling this function, so that it can the be accessed using cs_matrix_external.
[in]symmetricIndicates if matrix coefficients are symmetric
[in]diag_block_sizeBlock sizes for diagonal
[in]extra_diag_block_sizeBlock sizes for extra diagonal
pointer to native matrix adapted to fill type
◆ cs_matrix_csr()
cs_matrix_t * cs_matrix_csr ( void  )
◆ cs_matrix_default()
cs_matrix_t * cs_matrix_default ( bool  symmetric,
◆ cs_matrix_default_set_tuned()
void cs_matrix_default_set_tuned ( cs_matrix_t *  m)
◆ cs_matrix_default_set_type()
void cs_matrix_default_set_type ( cs_matrix_fill_type_t  fill_type,
[in]filltype Fill type for which tuning behavior is set
[in]typeMatrix type to use
◆ cs_matrix_external()
cs_matrix_t * cs_matrix_external ( const char *  type_name,
bool  symmetric,
[in]type_nameMatrix type name
[in]symmetricIndicates if coefficients are symmetric
Pointer to matrix matching requested type
◆ cs_matrix_finalize()
void cs_matrix_finalize ( void  )
◆ cs_matrix_get_block_row_g_id() [1/2]
const cs_gnum_t * cs_matrix_get_block_row_g_id ( const cs_matrix_t *  m)
The numbering is built or updated if not previously used, or if the previous call considered a different matrix or halo, and is simply returned otherwise. In other words, this works as a matrix global numbering cache.
The matrix's halo is used for the update.
[in]massociated matrix
pointer to requested global numbering
◆ cs_matrix_get_block_row_g_id() [2/2]
const cs_gnum_t * cs_matrix_get_block_row_g_id ( const cs_matrix_t *  m,
const cs_halo_t *  halo
[in]haloassociated halo
◆ cs_matrix_get_tuning_runs()
int cs_matrix_get_tuning_runs ( void  )
◆ cs_matrix_initialize()
void cs_matrix_initialize ( void  )
◆ cs_matrix_msr()
cs_matrix_t * cs_matrix_msr ( void  )
◆ cs_matrix_native()
cs_matrix_t * cs_matrix_native ( void  )
◆ cs_matrix_release()
void cs_matrix_release ( cs_matrix_t **  m)
◆ cs_matrix_set_coefficients_by_assembler()
cs_matrix_t * cs_matrix_set_coefficients_by_assembler ( const cs_field_t *  f,
bool  symmetric,
const cs_real_t *  da,
const cs_real_t *  xa
[in]typematrix type
[in]symmetricis matrix symmetric ?
[in]diag_block_sizeblock sizes for diagonal, or nullptr
[in]extra_diag_block_sizeblock sizes for extra diagonal, or nullptr
[in]dadiagonal values (nullptr if zero)
[in]xaextradiagonal values (nullptr if zero) casts as: xa[n_edges] if symmetric, xa[n_edges][2] if non symmetric
◆ cs_matrix_set_tuning_runs()
void cs_matrix_set_tuning_runs ( int  n_min_products)
◆ cs_matrix_update_mesh()
void cs_matrix_update_mesh ( void  )
◆ cs_matrix_vector_native_multiply()
void cs_matrix_vector_native_multiply ( bool  symmetric,
cs_lnum_t  db_size,
cs_lnum_t  eb_size,
int  f_id,
const cs_real_t *  dam,
const cs_real_t *  xam,
cs_real_t *  vx,
cs_real_t *  vy
