cs_macfb_monolithic.cpp File Reference
Build an algebraic MAC face-based system for the Navier-Stokes equations and solved it with a monolithic approach. More...
#include <float.h>
#include "base/cs_mem.h"
#include "base/cs_array.h"
#include "alge/cs_blas.h"
#include "cdo/cs_cdo_bc.h"
#include "cdo/cs_cdo_blas.h"
#include "cdo/cs_cdofb_monolithic.h"
#include "cdo/cs_cdofb_monolithic_sles.h"
#include "cdo/cs_cdofb_navsto.h"
#include "cdo/cs_equation_builder.h"
#include "cdo/cs_evaluate.h"
#include "base/cs_log.h"
#include "cdo/cs_macfb_builder.h"
#include "cdo/cs_macfb_monolithic_sles.h"
#include "cdo/cs_macfb_navsto.h"
#include "cdo/cs_macfb_priv.h"
#include "cdo/cs_macfb_vecteq.h"
#include "cdo/cs_navsto_coupling.h"
#include "base/cs_parall.h"
#include "base/cs_post.h"
#include "cdo/cs_sdm.h"
#include "cdo/cs_solid_selection.h"
#include "base/cs_timer.h"
#include "cdo/cs_macfb_monolithic.h"
#include "cdo/cs_macfb_monolithic_priv.h"
+ Include dependency graph for cs_macfb_monolithic.cpp:
Macros
#define CS_MACFB_MONOLITHIC_DBG   0
void cs_macfb_monolithic_init_sharing (const cs_equation_param_t *eqp, const cs_mesh_t *mesh, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
void cs_macfb_monolithic_finalize_common (void)
 Free shared pointers with lifecycle dedicated to this file. More...
void * cs_macfb_monolithic_init_scheme_context (const cs_navsto_param_t *nsp, cs_adv_field_t *adv_field, cs_real_t *mflux, cs_real_t *mflux_pre, cs_boundary_type_t *bf_type, void *cc_context)
 Initialize a cs_macfb_monolithic_t structure. More...
void * cs_macfb_monolithic_free_scheme_context (void *scheme_context)
 Destroy a cs_macfb_monolithic_t structure. More...
void cs_macfb_monolithic_steady (const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
 Solve the steady Stokes or Oseen system with a MAC face-based scheme using a monolithic approach. More...
void cs_macfb_monolithic_steady_nl (const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
 Solve the steady Navier-Stokes system with a MAC face-based scheme using a monolithic approach and a non-linear algorithm (Picard or Anderson) to solve the non-linearities arising from the advection term. More...
void cs_macfb_monolithic (const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
 Solve the unsteady Navier-Stokes system with a MAC face-based scheme using a monolithic approach. According to the settings, this function can handle either an implicit Euler time scheme or more generally a theta time scheme. More...
void cs_macfb_monolithic_nl (const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
 Solve the unsteady Navier-Stokes system with a MAC face-based scheme using a monolithic approach. According to the settings, this function can handle either an implicit Euler time scheme or more generally a theta time scheme. Rely on Picard iterations to solve the non-linearities arising from the advection term. More...
◆ CS_MACFB_MONOLITHIC_DBG
◆ cs_macfb_monolithic()
void cs_macfb_monolithic ( const cs_mesh_t *  mesh,
const cs_navsto_param_t *  nsp,
void *  scheme_context
[in]scheme_contextpointer to a structure cast on-the-fly
◆ cs_macfb_monolithic_finalize_common()
void cs_macfb_monolithic_finalize_common ( void  )
◆ cs_macfb_monolithic_free_scheme_context()
void * cs_macfb_monolithic_free_scheme_context ( void *  scheme_context)
[in]scheme_contextpointer to a scheme context structure to free
a null pointer
◆ cs_macfb_monolithic_init_scheme_context()
void * cs_macfb_monolithic_init_scheme_context ( const cs_navsto_param_t *  nsp,
cs_adv_field_t *  adv_field,
cs_real_t *  mflux,
cs_real_t *  mflux_pre,
cs_boundary_type_t *  bf_type,
void *  cc_context
[in]mfluxcurrent values of the mass flux across primal faces
[in]mflux_precurrent values of the mass flux across primal faces
[in]bf_typetype of boundary for each boundary face
[in]cc_contextpointer to a cs_navsto_monolithic_t structure
a pointer to a new allocated cs_macfb_monolithic_t structure
◆ cs_macfb_monolithic_init_sharing()
void cs_macfb_monolithic_init_sharing ( const cs_equation_param_t *  eqp,
[in]eqpequation parameter settings
◆ cs_macfb_monolithic_nl()
void cs_macfb_monolithic_nl ( const cs_mesh_t *  mesh,
[in,out]scheme_contextpointer to a structure cast on-the-fly
◆ cs_macfb_monolithic_steady()
void cs_macfb_monolithic_steady ( const cs_mesh_t *  mesh,
Solve the steady Navier-Stokes system with a MAC face-based scheme using a monolithic approach.
◆ cs_macfb_monolithic_steady_nl()
void cs_macfb_monolithic_steady_nl ( const cs_mesh_t *  mesh,
Solve the steady Navier-Stokes system with a MAC face-based scheme using a monolithic approach and Picard iterations to solve the non-linearities arising from the advection term.
