cs_lagr_stat.cpp File Reference
#include <ctype.h>
#include <stdarg.h>
#include "bft/bft_printf.h"
#include "bft/bft_error.h"
#include "base/cs_base.h"
#include "base/cs_dispatch.h"
#include "base/cs_file.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "mesh/cs_mesh.h"
#include "base/cs_order.h"
#include "base/cs_parall.h"
#include "base/cs_restart_default.h"
#include "base/cs_timer_stats.h"
#include "base/cs_log.h"
#include "base/cs_array_reduce.h"
#include "base/cs_field.h"
#include "lagr/cs_lagr_tracking.h"
#include "lagr/cs_lagr.h"
#include "lagr/cs_lagr_stat.h"
+ Include dependency graph for cs_lagr_stat.cpp:
int cs_lagr_stat_particle_define (const char *name, int location_id, int stat_type, cs_lagr_stat_moment_t m_type, int class_id, int dim, int component_id, cs_lagr_moment_p_data_t *data_func, void *data_input, cs_lagr_moment_p_data_t *w_data_func, void *w_data_input, int nt_start, double t_start, cs_lagr_stat_restart_t restart_mode)
 Define a particle-based statistic. More...
int cs_lagr_stat_event_define (const char *name, int location_id, int stat_type, cs_lagr_stat_group_t stat_group, cs_lagr_stat_moment_t m_type, int class_id, int dim, int component_id, cs_lagr_moment_e_data_t *data_func, void *data_input, cs_lagr_moment_e_data_t *w_data_func, void *w_data_input, int nt_start, double t_start, cs_lagr_stat_restart_t restart_mode)
 Define an event-based statistic. More...
int cs_lagr_stat_mesh_define (const char *name, int location_id, cs_lagr_stat_group_t stat_group, int class_id, int dim, cs_lagr_moment_m_data_t *data_func, void *data_input, int nt_start, double t_start)
 Define mesh-based statistic based on particles or particle events. More...
int cs_lagr_stat_accumulator_define (const char *name, int location_id, cs_lagr_stat_group_t stat_group, int class_id, cs_lagr_moment_p_data_t *p_data_func, cs_lagr_moment_e_data_t *e_data_func, void *data_input, int nt_start, double t_start, cs_lagr_stat_restart_t restart_mode)
 Define a particle weight type statistic. More...
int cs_lagr_stat_time_moment_define (const char *name, int location_id, int stat_type, cs_lagr_stat_moment_t m_type, int class_id, int dim, int component_id, cs_lagr_moment_m_data_t *data_func, void *data_input, int nt_start, double t_start, cs_lagr_stat_restart_t restart_mode)
 Define a time moment associated to particle statistics. More...
void cs_lagr_stat_activate (int stat_type)
 Activate Lagrangian statistics for a given statistics type. More...
void cs_lagr_stat_activate_time_moment (int stat_type, cs_lagr_stat_moment_t moment)
 Activate time moment for some predefined Lagrangian statistics types. More...
void cs_lagr_stat_deactivate (int stat_type)
 Deactivate Lagrangian statistics for a given statistics type. More...
void cs_lagr_stat_activate_attr (int attr_id)
 Activate Lagrangian statistics for a given particle attribute. More...
void cs_lagr_stat_deactivate_attr (int attr_id)
 Deactivate Lagrangian statistics for a given particle attribute. More...
int cs_lagr_stat_type_from_attr_id (int attr_id)
 Return statistics type associated with a given particle attribute id. More...
int cs_lagr_stat_type_to_attr_id (int stat_type)
 Return attribute id associated with a given statistics type. More...
int cs_lagr_stat_type_by_name (const char *name)
 Determine a basic statistic type by its base name. More...
void cs_lagr_stat_map_cell_dt (const cs_real_t *dt)
 Map time step values array for Lagrangian statistics. More...
void cs_lagr_stat_initialize (void)
 Lagrangian statistics initialization. More...
bool cs_lagr_stat_is_active (cs_lagr_stat_group_t group)
 Indicate if a given statistics type has active statistics. More...
void cs_lagr_stat_restart_read (void)
 Read particle statistics restart info if needed. More...
void cs_lagr_stat_prepare (void)
 Prepare particle statistics for a given time step. More...
void cs_lagr_stat_update (void)
 Update particle statistics for a given time step. More...
void cs_lagr_stat_update_event (cs_lagr_event_set_t *events, cs_lagr_stat_group_t group)
 Update event-based moment accumulators. More...
void cs_lagr_stat_finalize (void)
 Destroy all moments management metadata. More...
void cs_lagr_stat_log_setup (void)
 Log moment definition setup information. More...
void cs_lagr_stat_log_iteration (void)
 Log moment definition information for a given iteration. More...
void cs_lagr_stat_restart_write (cs_restart_t *restart)
 Checkpoint moment data. More...
cs_field_t * cs_lagr_stat_get_moment (int stat_type, cs_lagr_stat_group_t stat_group, cs_lagr_stat_moment_t m_type, int class_id, int component_id)
 Return field associated with a given Lagrangian statistic, given a statistics type (i.e. variable), group (particles or event), moment order, statistical class, and component id. More...
cs_field_t * cs_lagr_stat_get_stat_weight (int class_id)
 Return statistical weight. More...
cs_real_t cs_lagr_stat_get_age (void)
 Return global volume statistics age. More...
cs_real_t cs_lagr_stat_get_moment_age (cs_field_t *f)
 Return statistics age for a given moment. More...
◆ cs_lagr_stat_accumulator_define()
int cs_lagr_stat_accumulator_define ( const char *  name,
int  location_id,
int  class_id,
cs_lagr_moment_p_data_t *  p_data_func,
cs_lagr_moment_e_data_t *  e_data_func,
void *  data_input,
int  nt_start,
double  t_start,
Weights are automatically associated to general statitistics, but defining them explicitely allows activation of standard logging and postprocessing for those weights, as well as defining specific weights.
[in]namestatistics base name
[in]location_idid of associated mesh location
[in]stat_groupstatistics group (particle or event)
[in]class_idparticle class id, or 0 for all
[in]p_data_funcpointer to function to compute particle weight (if nullptr, statistic weight assumed)
[in]e_data_funcpointer to function to compute event weight (if nullptr, statistic weight assumed)
[in]data_inputassociated input for data_func
[in]nt_startstarting time step (or -1 to use t_start, 0 to use idstnt)
[in]t_startstarting time
[in]restart_modebehavior in case of restart (reset, automatic, or strict)
id of new moment in case of success, -1 in case of error.
◆ cs_lagr_stat_activate()
void cs_lagr_stat_activate ( int  stat_type)
This function is ignored if called after cs_lagr_stat_initialize.
[in]stat_typeparticle statistics type
◆ cs_lagr_stat_activate_attr()
void cs_lagr_stat_activate_attr ( int  attr_id)
[in]attr_idparticle attribute id
◆ cs_lagr_stat_activate_time_moment()
void cs_lagr_stat_activate_time_moment ( int  stat_type,
By default, statistics such as mass flows are based on a current time step, and time moments are not computed by default. This function allows forcing the associated moment level so that it is computed also.
Note that requesting a higher order moment will automatically include lower order moments, so activating the variance also activates the mean.
[in]momentassociated time moment level
◆ cs_lagr_stat_deactivate()
void cs_lagr_stat_deactivate ( int  stat_type)
◆ cs_lagr_stat_deactivate_attr()
void cs_lagr_stat_deactivate_attr ( int  attr_id)
◆ cs_lagr_stat_event_define()
int cs_lagr_stat_event_define ( const char *  name,
int  location_id,
int  stat_type,
int  class_id,
int  dim,
int  component_id,
cs_lagr_moment_e_data_t *  data_func,
void *  data_input,
cs_lagr_moment_e_data_t *  w_data_func,
void *  w_data_input,
int  nt_start,
double  t_start,
If dimension > 1, the val array is interleaved
[in]stat_typepredefined statistics type, or -1
[in]stat_groupstatistics group (event type)
[in]m_typemoment type
[in]dimdimension associated with element data
[in]component_idattribute component id, or < 0 for all
[in]data_funcpointer to function to compute statistics (if stat_type < 0)
[in]w_data_funcpointer to function to compute weight (if nullptr, statistic weight assumed)
[in]w_data_inputassociated input for w_data_func
◆ cs_lagr_stat_finalize()
void cs_lagr_stat_finalize ( void  )
◆ cs_lagr_stat_get_age()
cs_real_t cs_lagr_stat_get_age ( void  )
age of volume statistics, or -1 if statistics not active yet
◆ cs_lagr_stat_get_moment()
cs_field_t * cs_lagr_stat_get_moment ( int  stat_type,
int  class_id,
int  component_id
[in]stat_typestatistics type
[in]m_typemoment type (mean or variance)
[in]class_idparticle statistical class
[in]component_idcomponent id, or -1 for all
pointer to the field associated to the corresponding moment
◆ cs_lagr_stat_get_moment_age()
cs_real_t cs_lagr_stat_get_moment_age ( cs_field_t *  f)
[in]ffield associated with given statistic
age of given statistic, or -1 if not active yet
◆ cs_lagr_stat_get_stat_weight()
cs_field_t * cs_lagr_stat_get_stat_weight ( int  class_id)
pointer to the field associated to the corresponding weight
◆ cs_lagr_stat_initialize()
void cs_lagr_stat_initialize ( void  )
Statistics activated or deactivated by previous calls to cs_lagr_stat_activate, cs_lagr_stat_deactivate, cs_lagr_stat_activate_attr, and cs_lagr_stat_deactivate_attr will be initialized here.
Restart info will be used after to fill in the moments structure
◆ cs_lagr_stat_is_active()
bool cs_lagr_stat_is_active ( cs_lagr_stat_group_t  group)
[in]groupevent group to update
true if statistics are active for the given group
◆ cs_lagr_stat_log_iteration()
void cs_lagr_stat_log_iteration ( void  )
◆ cs_lagr_stat_log_setup()
void cs_lagr_stat_log_setup ( void  )
◆ cs_lagr_stat_map_cell_dt()
void cs_lagr_stat_map_cell_dt ( const cs_real_t *  dt)
If this function is not called, the field referenced by field pointer CS_F_(dt) will be used instead.
[in]dtpointer to time step values array
◆ cs_lagr_stat_mesh_define()
int cs_lagr_stat_mesh_define ( const char *  name,
int  location_id,
int  class_id,
int  dim,
cs_lagr_moment_m_data_t *  data_func,
void *  data_input,
int  nt_start,
double  t_start
This type of statistic is reinitialized and evaluated during each time step, but may be computed incrementally when based on particle events, so the associated data function must uptate the statistics without reinitializing them at each call.
As this type of statistic does not need to keep state between time steps, it is ignored by the Lagrangian statistics checkpoint/restart mechanism.
◆ cs_lagr_stat_particle_define()
int cs_lagr_stat_particle_define ( const char *  name,
int  location_id,
int  stat_type,
int  class_id,
int  dim,
int  component_id,
cs_lagr_moment_p_data_t *  data_func,
void *  data_input,
cs_lagr_moment_p_data_t *  w_data_func,
int  nt_start,
double  t_start,
◆ cs_lagr_stat_prepare()
void cs_lagr_stat_prepare ( void  )
◆ cs_lagr_stat_restart_read()
void cs_lagr_stat_restart_read ( void  )
◆ cs_lagr_stat_restart_write()
void cs_lagr_stat_restart_write ( cs_restart_t *  restart)
[in]restartassociated restart file pointer
◆ cs_lagr_stat_time_moment_define()
int cs_lagr_stat_time_moment_define ( const char *  name,
int  location_id,
int  stat_type,
int  class_id,
int  dim,
int  component_id,
void *  data_input,
int  nt_start,
double  t_start,
This is similar to general time moments (see cs_time_moment.c), with restart, logging, and unsteady reinitialization behavior aligned with other particle statistics.
Time moments must be based on values available at the end of each time step, so they cannot be based directly on events (though they can be based on fields defined through cs_lagr_stat_mesh_define, as the matching event-based fields will be updated first).
◆ cs_lagr_stat_type_by_name()
int cs_lagr_stat_type_by_name ( const char *  name)
[in]nameparticle statistics base name (without class id)
matching stat type id, or -1 if not found
◆ cs_lagr_stat_type_from_attr_id()
int cs_lagr_stat_type_from_attr_id ( int  attr_id)
associated particle statistics type id
◆ cs_lagr_stat_type_to_attr_id()
int cs_lagr_stat_type_to_attr_id ( int  stat_type)
attribute id, or -1 if not applicable
◆ cs_lagr_stat_update()
void cs_lagr_stat_update ( void  )
◆ cs_lagr_stat_update_event()
void cs_lagr_stat_update_event ( cs_lagr_event_set_t *  events,
Partial updates are allowed, so as to balance memory cost for storing events and repetition of mesh-location-based weigh updates.
[in]eventspointer to event set
