cs_lagr_aux_mean_fluid_quantities.h File Reference
+ Include dependency graph for cs_lagr_aux_mean_fluid_quantities.h:
void compute_anisotropic_prop (int iprev, int phase_id, cs_real_3_t *anisotropic_lagr_time, cs_real_3_t *anisotropic_bx, cs_real_3_t *grad_lagr_time_r_et, cs_real_3_t *grad_lagr_time)
 Compute anisotropic fluid quantities for complete model (modpl == 1). More...
void compute_particle_covariance_gradient (int phase_id, cs_real_3_t *grad_cov_skp[9], cs_real_3_t *grad_cov_sk[6])
 Compute gradient of particle covariance. More...
void cs_lagr_aux_mean_fluid_quantities (int iprev, int phase_id, cs_field_t *lagr_time, cs_real_3_t *grad_pr, cs_real_33_t *grad_vel, cs_real_3_t *grad_tempf, cs_real_3_t *anisotropic_lagr_time, cs_real_3_t *anisotropic_bx, cs_real_3_t *grad_lagr_time_r_et, cs_real_3_t *grad_lagr_time)
 Compute auxilary mean fluid quantities. More...
◆ compute_anisotropic_prop()
void compute_anisotropic_prop ( int  iprev,
int  phase_id,
cs_real_3_t *  anisotropic_lagr_time,
cs_real_3_t *  anisotropic_bx,
cs_real_3_t *  grad_lagr_time_r_et,
  • Anisotropic Lagragian time
  • Anisotropic Diffusion matrix
  • Anisotropic gradient of Lagrangian time in the relativ basis
[in]iprevtime step indicator for fields 0: use fields at current time step 1: use fields at previous time step
[in]phase_idcarrier phase id
[out]anisotropic_lagr_timeanisotropic Lagragian time scale (modcpl)
[out]anisotropic_bxanisotropic diffusion term (if modcpl)
[out]grad_lagr_time_r_etanisotropic Lagrangian time gradient in relative basis
[in]grad_lagr_timeLagrangian time gradient
◆ compute_particle_covariance_gradient()
void compute_particle_covariance_gradient ( int  phase_id,
cs_real_3_t *  grad_cov_skp[9],
cs_real_3_t *  grad_cov_sk[6]
  • particle velocity and particle velocity seen covariance
  • particle velocity seen variance
[out]grad_cov_skpgradient of particle velocity and particle velocity seen covariance
[out]grad_cov_skgradient of particle velocity seen covariance
◆ cs_lagr_aux_mean_fluid_quantities()
void cs_lagr_aux_mean_fluid_quantities ( int  iprev,
int  phase_id,
cs_field_t *  lagr_time,
cs_real_3_t *  grad_pr,
cs_real_33_t *  grad_vel,
cs_real_3_t *  grad_tempf,
  • Lagrangian time (if modcpl == 1 also anisotropic values)
  • gradient of total pressure
  • velocity gradient
  • temperature gradient
  • Lagrangian time gradient (also gradient of anisotropic values if needed)
  • diffusion matix
[out]lagr_timeLagrangian time scale
[out]grad_prpressure gradient
[out]grad_velvelocity gradient
[out]grad_tempffluid temperature gradient
[out]grad_lagr_timeLagrangian time gradient
  • velocity gradient
  • diffusion matix
[out]lagr_timeLagragian time scale
[out]anisotropic_lagr_timeanisotropic Lagrangian time scale (modcpl)
