cs_lagr.h File Reference
#include "assert.h"
#include "base/cs_base.h"
#include "base/cs_field.h"
#include "lagr/cs_lagr_injection.h"
+ Include dependency graph for cs_lagr.h:
Classes
struct  cs_lagr_const_dim_t
struct  cs_lagr_dim_t
struct  cs_lagr_time_scheme_t
struct  cs_lagr_model_t
struct  cs_lagr_particle_counter_t
struct  cs_lagr_specific_physics_t
struct  cs_lagr_reentrained_model_t
struct  cs_lagr_precipitation_model_t
struct  cs_lagr_clogging_model_t
struct  cs_lagr_shape_model_t
struct  cs_lagr_agglomeration_model_t
struct  cs_lagr_fragmentation_model_t
struct  cs_lagr_consolidation_model_t
struct  cs_lagr_time_step_t
struct  cs_lagr_injection_set_t
struct  cs_lagr_source_terms_t
struct  cs_lagr_zone_data_t
struct  cs_lagr_internal_condition_t
struct  cs_lagr_encrustation_t
struct  cs_lagr_physico_chemical_t
struct  cs_lagr_brownian_t
struct  cs_lagr_boundary_interactions_t
struct  cs_lagr_extra_module_t
Typedefs
typedef void() cs_lagr_injection_profile_compute_t(int zone_id, int location_id, const void *input, cs_lnum_t n_elts, const cs_lnum_t elt_ids[], cs_real_t profile[])
 Function pointer for computation of particle injection profile. More...
Enumerations
enum  cs_lagr_bc_type {
  CS_LAGR_BC_UNDEFINED , CS_LAGR_SYM , CS_LAGR_INLET , CS_LAGR_OUTLET ,
  CS_LAGR_REBOUND , CS_LAGR_DEPO1 , CS_LAGR_DEPO2 , CS_LAGR_DEPO_DLVO ,
  CS_LAGR_FOULING , CS_LAGR_BC_USER
enum  { CS_LAGR_IN_IMPOSED_FLUID_VALUE = -1 , CS_LAGR_IN_IMPOSED_NORM = 0 , CS_LAGR_IN_IMPOSED_COMPONENTS = 1 }
enum  cs_lagr_module_status_t { CS_LAGR_OFF = 0 , CS_LAGR_ONEWAY_COUPLING = 1 , CS_LAGR_TWOWAY_COUPLING = 2 , CS_LAGR_FROZEN_CONTINUOUS_PHASE = 3 }
enum  cs_lagr_module_shape_t { CS_LAGR_SHAPE_SPHERE_MODEL = 0 , CS_LAGR_SHAPE_SPHEROID_STOC_MODEL = 1 , CS_LAGR_SHAPE_SPHEROID_JEFFERY_MODEL = 2 }
enum  { CS_LAGR_PHYS_OFF = 0 , CS_LAGR_PHYS_HEAT = 1 , CS_LAGR_PHYS_COAL = 2 , CS_LAGR_PHYS_CTWR = 3 }
void cs_lagr_map_specific_physics (void)
 Map specific phyical model features to Lagrangian structures. More...
cs_lagr_injection_set_t * cs_lagr_get_injection_set (cs_lagr_zone_data_t *zone_data, int zone_id, int set_id)
 Provide access to injection set structure. More...
void cs_lagr_injection_set_default (cs_lagr_injection_set_t *zis)
 Initialize injection set data structure fields to defaults. More...
cs_lagr_particle_counter_t * cs_lagr_get_particle_counter (void)
 Get read/write pointer to global particle counter. More...
cs_lagr_particle_counter_t * cs_lagr_update_particle_counter (void)
 Update global particle counter. More...
cs_lagr_specific_physics_t * cs_get_lagr_specific_physics (void)
 Provide access to cs_lagr_specific_physics_t. More...
cs_lagr_reentrained_model_t * cs_get_lagr_reentrained_model (void)
 Provide access to cs_lagr_reentrained_model_t. More...
cs_lagr_precipitation_model_t * cs_get_lagr_precipitation_model (void)
 Provide access to cs_lagr_precipitation_model_t. More...
cs_lagr_clogging_model_t * cs_get_lagr_clogging_model (void)
cs_lagr_shape_model_t * cs_get_lagr_shape_model (void)
cs_lagr_agglomeration_model_t * cs_get_lagr_agglomeration_model (void)
cs_lagr_consolidation_model_t * cs_get_lagr_consolidation_model (void)
cs_lagr_time_step_t * cs_get_lagr_time_step (void)
cs_lagr_source_terms_t * cs_get_lagr_source_terms (void)
cs_lagr_encrustation_t * cs_get_lagr_encrustation (void)
cs_lagr_physico_chemical_t * cs_get_lagr_physico_chemical (void)
cs_lagr_brownian_t * cs_get_lagr_brownian (void)
cs_lagr_zone_data_t * cs_lagr_get_boundary_conditions (void)
 Return pointer to the main boundary conditions structure. More...
cs_lagr_zone_data_t * cs_lagr_get_volume_conditions (void)
 Return pointer to the main volume conditions structure. More...
cs_lagr_internal_condition_t * cs_lagr_get_internal_conditions (void)
 Return pointer to the main internal conditions structure. More...
void cs_lagr_finalize_zone_conditions (void)
 Finalize the global boundary and volume condition structures. More...
void cs_lagr_finalize_internal_cond (void)
cs_lagr_boundary_interactions_t * cs_get_lagr_boundary_interactions (void)
cs_lagr_extra_module_t * cs_get_lagr_extra_module (void)
void cs_lagr_solve_initialize (const cs_real_t *dt)
void cs_lagr_init_arrays (void)
void cs_lagr_finalize (void)
void cs_lagr_initialize_extra (cs_lnum_t n_continuous_phases)
void cs_lagr_add_fields (void)
 Create additional fields needed by the Lagrangien model. More...
void cs_lagr_solve_time_step (const int itypfb[], const cs_real_t *dt)
const cs_lagr_const_dim_t * cs_glob_lagr_const_dim
cs_lagr_dim_t * cs_glob_lagr_dim
cs_lagr_time_scheme_t * cs_glob_lagr_time_scheme
cs_lagr_model_t * cs_glob_lagr_model
const cs_lagr_particle_counter_t * cs_glob_lagr_particle_counter
int cs_glob_lagr_log_frequency_n
cs_real_t * bound_stat
cs_lagr_specific_physics_t * cs_glob_lagr_specific_physics
cs_lagr_reentrained_model_t * cs_glob_lagr_reentrained_model
cs_lagr_precipitation_model_t * cs_glob_lagr_precipitation_model
cs_lagr_clogging_model_t * cs_glob_lagr_clogging_model
cs_lagr_shape_model_t * cs_glob_lagr_shape_model
cs_lagr_agglomeration_model_t * cs_glob_lagr_agglomeration_model
cs_lagr_fragmentation_model_t * cs_glob_lagr_fragmentation_model
cs_lagr_consolidation_model_t * cs_glob_lagr_consolidation_model
cs_lagr_time_step_t * cs_glob_lagr_time_step
cs_lagr_source_terms_t * cs_glob_lagr_source_terms
cs_lagr_encrustation_t * cs_glob_lagr_encrustation
cs_lagr_physico_chemical_t * cs_glob_lagr_physico_chemical
cs_lagr_brownian_t * cs_glob_lagr_brownian
cs_lagr_boundary_interactions_t * cs_glob_lagr_boundary_interactions
cs_lagr_extra_module_t * cs_glob_lagr_extra_module
const cs_lagr_zone_data_t * cs_glob_lagr_boundary_conditions
const cs_lagr_zone_data_t * cs_glob_lagr_volume_conditions
cs_lagr_internal_condition_t * cs_glob_lagr_internal_conditions
cs_real_33_t * cs_glob_lagr_b_face_proj
Typedef Documentation
◆ cs_lagr_injection_profile_compute_t
Note: if the input pointer is non-null, it must point to valid data when the selection function is called, so that value or structure should not be temporary (i.e. local);
[in]zone_idid of associated mesh zone
[in]location_idid of associated mesh location
[in]inputpointer to optional (untyped) value or structure.
[in]n_eltsnumber of zone elements
[in]elt_idsids of zone elements
[out]profileweight of a given zone element (size: n_elts)
◆ anonymous enum
anonymous enum
Lagrangian injection condition types
Enumerator
impose fluid value for the injected particles
impose norm
impose components (for vectors)
◆ anonymous enum
anonymous enum
Lagrangian additional physical model
Enumerator
CS_LAGR_PHYS_OFF
CS_LAGR_PHYS_HEAT
CS_LAGR_PHYS_COAL
CS_LAGR_PHYS_CTWR
◆ cs_lagr_bc_type
Lagrangian boundary condition types
Enumerator
undefined conditions
CS_LAGR_SYM
symmetry
CS_LAGR_INLET
inlet
CS_LAGR_OUTLET
outlet
CS_LAGR_REBOUND
elastic rebound
CS_LAGR_DEPO1
immediate deposition and elimination
CS_LAGR_DEPO2
deposition
CS_LAGR_DEPO_DLVO
deposition based on DLVO theory
CS_LAGR_FOULING
fouling (combustion)
CS_LAGR_BC_USER
user-defined
◆ cs_lagr_module_shape_t
Particle shape condition types
Enumerator
Impose spherical particles
Impose spheroids (stochastic model for transport)
◆ cs_lagr_module_status_t
Lagrangian module status. the different values correspond to the following coupling:
  • CS_LAGR_OFF: Lagrangian module off
  • CS_LAGR_ONEWAY_COUPLING: Lagrangian two-phase flow in one-way coupling (no influence of the particles on the continuous phase)
  • CS_LAGR_TWOWAY_COUPLING: Lagrangian two-phase flow with two-way coupling (influence of the particles on the dynamics of the continuous phase). Dynamics, temperature and mass may be coupled independently.
  • CS_LAGR_FROZEN_CONTINUOUS_PHASE: Lagrangian two-phase flow on frozen i continuous phase. This option only only be used in case of a calculation restart. All the Eulerian fields are frozen (including the scalar fields). This option automatically implies iccvfg = 1
Enumerator
CS_LAGR_OFF
◆ cs_get_lagr_agglomeration_model()
cs_lagr_agglomeration_model_t * cs_get_lagr_agglomeration_model ( void  )
◆ cs_get_lagr_boundary_interactions()
cs_lagr_boundary_interactions_t * cs_get_lagr_boundary_interactions ( void  )
◆ cs_get_lagr_brownian()
cs_lagr_brownian_t * cs_get_lagr_brownian ( void  )
◆ cs_get_lagr_clogging_model()
cs_lagr_clogging_model_t * cs_get_lagr_clogging_model ( void  )
◆ cs_get_lagr_consolidation_model()
cs_lagr_consolidation_model_t * cs_get_lagr_consolidation_model ( void  )
◆ cs_get_lagr_encrustation()
cs_lagr_encrustation_t * cs_get_lagr_encrustation ( void  )
◆ cs_get_lagr_extra_module()
cs_lagr_extra_module_t * cs_get_lagr_extra_module ( void  )
◆ cs_get_lagr_physico_chemical()
cs_lagr_physico_chemical_t * cs_get_lagr_physico_chemical ( void  )
◆ cs_get_lagr_precipitation_model()
cs_lagr_precipitation_model_t * cs_get_lagr_precipitation_model ( void  )
pointer to lagrangian precipitation model options
◆ cs_get_lagr_reentrained_model()
cs_lagr_reentrained_model_t * cs_get_lagr_reentrained_model ( void  )
pointer to lagrangian reentrained model options
◆ cs_get_lagr_shape_model()
cs_lagr_shape_model_t * cs_get_lagr_shape_model ( void  )
◆ cs_get_lagr_source_terms()
cs_lagr_source_terms_t * cs_get_lagr_source_terms ( void  )
◆ cs_get_lagr_specific_physics()
cs_lagr_specific_physics_t * cs_get_lagr_specific_physics ( void  )
pointer to lagrangian specific physics options
◆ cs_get_lagr_time_step()
cs_lagr_time_step_t * cs_get_lagr_time_step ( void  )
◆ cs_lagr_add_fields()
void cs_lagr_add_fields ( void  )
Most additional fields can be defined directly in cs_lagr_options_definition, but some fields may be mapped to different fields based on the calling module (i.e. code_saturne or neptune_cfd), and possibly defined after that call.
◆ cs_lagr_finalize()
void cs_lagr_finalize ( void  )
◆ cs_lagr_finalize_internal_cond()
void cs_lagr_finalize_internal_cond ( void  )
◆ cs_lagr_finalize_zone_conditions()
void cs_lagr_finalize_zone_conditions ( void  )
pointer to current internal conditions structure
◆ cs_lagr_get_boundary_conditions()
cs_lagr_zone_data_t * cs_lagr_get_boundary_conditions ( void  )
pointer to current boundary zone data structure
◆ cs_lagr_get_injection_set()
cs_lagr_injection_set_t * cs_lagr_get_injection_set ( cs_lagr_zone_data_t *  zone_data,
int  zone_id,
int  set_id
This access method ensures the strucure is initialized for the given zone and injection set.
[in]zone_datapointer to boundary or volume conditions structure
[in]zone_idzone id
[in]set_idinjection set id
pointer to injection set data structure
◆ cs_lagr_get_internal_conditions()
cs_lagr_internal_condition_t * cs_lagr_get_internal_conditions ( void  )
The structure is allocated on demand, when this function is first called.
pointer to current internal_conditions structure
◆ cs_lagr_get_particle_counter()
cs_lagr_particle_counter_t * cs_lagr_get_particle_counter ( void  )
pointer to lagrangian particle counter structure
◆ cs_lagr_get_volume_conditions()
cs_lagr_zone_data_t * cs_lagr_get_volume_conditions ( void  )
pointer to current volume zone data structure
◆ cs_lagr_init_arrays()
void cs_lagr_init_arrays ( void  )
◆ cs_lagr_initialize_extra()
void cs_lagr_initialize_extra ( cs_lnum_t  n_continuous_phases)
◆ cs_lagr_injection_set_default()
void cs_lagr_injection_set_default ( cs_lagr_injection_set_t *  zis)
[in,out]zispointer to structure to initialize
◆ cs_lagr_map_specific_physics()
void cs_lagr_map_specific_physics ( void  )
◆ cs_lagr_solve_initialize()
void cs_lagr_solve_initialize ( const cs_real_t *  dt)
◆ cs_lagr_solve_time_step()
void cs_lagr_solve_time_step ( const int  itypfb[],
◆ cs_lagr_update_particle_counter()
cs_lagr_particle_counter_t * cs_lagr_update_particle_counter ( void  )
All fields handled in the local particle set are updated relative to that data (using global sums).
◆ bound_stat
cs_real_t* bound_stat
extern
◆ cs_glob_lagr_agglomeration_model
cs_lagr_agglomeration_model_t* cs_glob_lagr_agglomeration_model
extern
◆ cs_glob_lagr_b_face_proj
cs_real_33_t* cs_glob_lagr_b_face_proj
extern
◆ cs_glob_lagr_boundary_conditions
const cs_lagr_zone_data_t* cs_glob_lagr_boundary_conditions
extern
◆ cs_glob_lagr_boundary_interactions
cs_lagr_boundary_interactions_t* cs_glob_lagr_boundary_interactions
extern
◆ cs_glob_lagr_brownian
cs_lagr_brownian_t* cs_glob_lagr_brownian
extern
◆ cs_glob_lagr_clogging_model
cs_lagr_clogging_model_t* cs_glob_lagr_clogging_model
extern
◆ cs_glob_lagr_consolidation_model
cs_lagr_consolidation_model_t* cs_glob_lagr_consolidation_model
extern
◆ cs_glob_lagr_const_dim
const cs_lagr_const_dim_t* cs_glob_lagr_const_dim
extern
Fixed constants
◆ cs_glob_lagr_dim
cs_lagr_dim_t* cs_glob_lagr_dim
extern
General dimensions
◆ cs_glob_lagr_encrustation
cs_lagr_encrustation_t* cs_glob_lagr_encrustation
extern
◆ cs_glob_lagr_extra_module
cs_lagr_extra_module_t* cs_glob_lagr_extra_module
extern
◆ cs_glob_lagr_fragmentation_model
cs_lagr_fragmentation_model_t* cs_glob_lagr_fragmentation_model
extern
◆ cs_glob_lagr_internal_conditions
cs_lagr_internal_condition_t* cs_glob_lagr_internal_conditions
extern
◆ cs_glob_lagr_log_frequency_n
extern
◆ cs_glob_lagr_model
cs_lagr_model_t* cs_glob_lagr_model
extern
Main Lagragian physical model parameters
◆ cs_glob_lagr_particle_counter
const cs_lagr_particle_counter_t* cs_glob_lagr_particle_counter
extern
Read-only pointer to global particle counter
◆ cs_glob_lagr_physico_chemical
cs_lagr_physico_chemical_t* cs_glob_lagr_physico_chemical
extern
◆ cs_glob_lagr_precipitation_model
cs_lagr_precipitation_model_t* cs_glob_lagr_precipitation_model
extern
◆ cs_glob_lagr_reentrained_model
cs_lagr_reentrained_model_t* cs_glob_lagr_reentrained_model
extern
◆ cs_glob_lagr_shape_model
cs_lagr_shape_model_t* cs_glob_lagr_shape_model
extern
◆ cs_glob_lagr_source_terms
cs_lagr_source_terms_t* cs_glob_lagr_source_terms
extern
◆ cs_glob_lagr_specific_physics
cs_lagr_specific_physics_t* cs_glob_lagr_specific_physics
extern
◆ cs_glob_lagr_time_scheme
cs_lagr_time_scheme_t* cs_glob_lagr_time_scheme
extern
Time and Lagrangian-Eulerian coupling scheme
◆ cs_glob_lagr_time_step
cs_lagr_time_step_t* cs_glob_lagr_time_step
extern
◆ cs_glob_lagr_volume_conditions
const cs_lagr_zone_data_t* cs_glob_lagr_volume_conditions
extern
