cs_lagr_source_terms_t Struct Reference
#include <cs_lagr.h>
+ Collaboration diagram for cs_lagr_source_terms_t:
Public Attributes
int ltsdyn
int ltsmas
int ltsthe
int nstits
int npts
int ntxerr
cs_real_t vmax
cs_real_t tmamax
cs_real_t * volp
cs_real_t * volm
cs_real_t * t_st_p
cs_real_3_t * t_st_vel
cs_real_t * t_st_imp_vel
cs_real_t * t_st_k
cs_real_6_t * t_st_rij
cs_real_t * t_st_t_e
cs_real_t * t_st_t_i
2-way coupling and source term information.
Member Data Documentation
◆ ltsdyn
int ltsdyn
activation (=1) or not (=0) of the two-way coupling on the dynamics of the continuous phase. Useful if iilagr = CS_LAGR_TWOWAY_COUPLING and iccvfg = 0
◆ ltsmas
int ltsmas
activation (=1) or not (=0) of the two-way coupling on the mass. Useful if iilagr = CS_LAGR_TWOWAY_COUPLING, physical_model = 1 and solve_mass = 1
◆ ltsthe
int ltsthe
◆ npts
int npts
number of time steps for source terms accumulations
◆ nstits
int nstits
number of absolute time steps (including the restarts) after which a time-average of the two-way coupling source terms is calculated. Indeed, if the flow is steady (isttio=1), the average quantities that appear in the two-way coupling source terms can be calculated over different time steps, in order to get a better precision. if the number of absolute time steps is strictly inferior to nstits, the code considers that the flow has not yet reached its steady state (transition period) and the averages appearing in the source terms are reinitialized at each time step, as it is the case for unsteady flows (isttio=0). Useful if iilagr = CS_LAGR_TWOWAY_COUPLING and isttio=1
◆ ntxerr
int ntxerr
number of cells, whose volumetric rate DODO (concentration ?)is greater than 0.8
◆ t_st_imp_vel
cs_real_t* t_st_imp_vel
◆ t_st_k
cs_real_t* t_st_k
◆ t_st_p
cs_real_t* t_st_p
◆ t_st_rij
cs_real_6_t* t_st_rij
◆ t_st_t_e
cs_real_t* t_st_t_e
◆ t_st_t_i
cs_real_t* t_st_t_i
◆ t_st_vel
cs_real_3_t* t_st_vel
◆ tmamax
cs_real_t tmamax
maximum mass concentration reached
◆ vmax
cs_real_t vmax
maximum volumetric concentration reached
◆ volm
cs_real_t* volm
◆ volp
cs_real_t* volp
