cs_ibm.cpp File Reference
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "fvm/fvm_writer.h"
#include "base/cs_array.h"
#include "alge/cs_cell_to_vertex.h"
#include "base/cs_mem.h"
#include "base/cs_medcoupling_intersector.h"
#include "meg/cs_meg_prototypes.h"
#include "mesh/cs_mesh_adjacencies.h"
#include "base/cs_post.h"
#include "mesh/cs_stl.h"
#include "base/cs_turbomachinery.h"
#include "base/cs_velocity_pressure.h"
#include "alge/cs_vertex_to_cell.h"
#include "base/cs_zone.h"
#include "base/cs_ibm.h"
+ Include dependency graph for cs_ibm.cpp:
static cs_real_t _geom_face_fraction (cs_real_t alphai, cs_real_t alphaj, cs_real_t sizei, cs_real_t sizej)
 Compute the face porosity depending on the neighbouring cells porosities based on geometry. More...
static cs_real_t _imm_lgth_cutcell (cs_real_3_t x1, cs_real_3_t x2, cs_real_t t, int num_object)
 Compute by dichotomy the length of the immersed part of a line between two points (i.e. the distance between the point in the solid and the immersed boundary) based on the cut-cell method. More...
static cs_real_t _imm_lgth_poro (cs_real_3_t x1, cs_real_t por1, cs_real_3_t x2, cs_real_t por2)
 Compute by dichotomy the length of the immersed part of a line between two points (i.e. the distance between the point in the solid and the immersed boundary) based on the input porosities. More...
static cs_real_t _tetra_vol (cs_real_3_t x1, cs_real_3_t x2, cs_real_3_t x3, cs_real_3_t x4)
 Compute the volume of a tetrahedron described by its vertices (x1,x2,x3,x4). More...
static cs_real_t _pyram_vol (cs_real_3_t x1, cs_real_3_t x2, cs_real_3_t x3, cs_real_3_t x4, cs_real_3_t x5)
 Compute the volume of a pyramid with a quadrangle base (x1,x2,x3,x4) and apex (x5). More...
static cs_real_t _prism_vol (cs_real_3_t x1, cs_real_3_t x2, cs_real_3_t x3, cs_real_3_t x4, cs_real_3_t x5, cs_real_3_t x6)
 Compute the volume of a prism with a quadrangle base (x3,x4,x5,x6) and edge (x1 x2). More...
static void _tetra_vol_poro (cs_real_t *vol, cs_real_3_t cog, cs_real_3_t x1, cs_real_t por1, cs_real_3_t x2, cs_real_t por2, cs_real_3_t x3, cs_real_t por3, cs_real_3_t x4, cs_real_t por4, int icut)
 Compute the volume and center of gravity of a tetrahedron described by its vertices (x1,x2,x3,x4) but truncated due to solid parts identified with porosities, through a recursive approach. More...
static cs_real_t _tri_surf_trunc (cs_real_3_t x1, cs_real_t por1, cs_real_3_t x2, cs_real_t por2, cs_real_3_t x3, cs_real_t por3, int icut)
 Compute by dichotomy the area of the immersed part of a triangle (x1,x2,x3) based on the input porosities at its vertices through a recursive approach. More...
static void _tetra_vol_cutcell (cs_real_t *vol, cs_real_3_t x1, cs_real_3_t x2, cs_real_3_t x3, cs_real_3_t x4, cs_real_t t, int icut, int num_object)
 Compute (using bisection) the volume of the immersed part of a tetrahedron described by its vertices (x1,x2,x3,x4) based on the cut-cell method and recursive approach. More...
static int _penal_glob (const cs_lnum_t c_id, const cs_real_3_t xyz, const cs_real_t t, const int num_object)
 Call to user function to know whether we are in the solid or not. More...
static void _compute_cell_cut_porosity (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, int *comp_cell)
 Compute cell porosity using the cut cell method. More...
static void _compute_cell_cog (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, cs_real_t *v_poro, cs_real_t *por_init, int *comp_cell)
 Compute cell cog (and cell porosity from porosity at vertices) Cut method into sub-tetras. More...
static void _compute_b_fac_porosity (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, cs_real_t *c_poro, cs_real_t *v_poro, cs_real_t *bfpro_poro)
 Compute boundary faces porosity. More...
static void _compute_i_fac_porosity (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, cs_real_t *c_poro, cs_real_t *v_poro, cs_real_t *ifpro_poro)
 Compute internal faces porosity. More...
static void _compute_iso_vol_porosity (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, cs_real_t *c_poro, int *comp_cell)
 Iso-volume porosity check. More...
static void _compute_solid_porosity (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, cs_real_t *c_poro, int *comp_cell)
 Take into account internal solid porosity. More...
static void _compute_cell_list_porosity (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, cs_lnum_t *comp_cell)
 Compute list of cells for porosity computing. More...
static void _compute_solid_surface_vector (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, cs_real_t *i_poro, cs_real_t *b_poro)
 Compute porosity solid surface. More...
static void _compute_solid_surface_cog (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, cs_real_t *c_poro, cs_real_t *v_poro, cs_real_t *i_poro, cs_real_t *b_poro)
 Compute porosity solid surface cog (dist and ponderation coeff) More...
static cs_ibm_object_t * _create_ibm_object (const char *name, cs_ibm_algo_type_t method)
 Create a new immersed boundary object with a given name and method. More...
static int _add_ibm_object (const char *name, cs_ibm_algo_type_t method)
 Adds a new immersed boundary object with a given name and method. More...
static void _free_ibm_object (cs_ibm_object_t *obj)
 Free a cs_ibm_object_t structure. More...
static void _ibm_object_define_property_def (cs_ibm_object_t *obj, cs_ibm_object_property_type_t ppty_id, int n_vals, cs_real_t *vals)
 Define a new property definition for an object. More...
static void _ibm_object_define_initial_val_def (cs_ibm_object_t *obj, cs_ibm_object_init_param_t p_id, int n_vals, cs_real_t *vals)
 Set initial value xdef for an object. More...
static cs_real_t _get_xdef_val_at_object_elt (const cs_xdef_t *def, const int elt_id)
 Get xdef value at object element. More...
cs_ibm_object_t * cs_ibm_object_by_id (int obj_id)
 Get an object based on its id. More...
cs_ibm_object_t * cs_ibm_object_by_name_try (const char *name)
 Try to get an object based on its name. Returns null if not found. More...
cs_ibm_object_t * cs_ibm_object_by_name (const char *name)
 Get an object based on its name. Error if not found. More...
cs_ibm_t * cs_ibm_create (void)
void cs_ibm_finalize (void)
void cs_immersed_boundaries (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities)
 Define immersed boundaries in time and space (solid(s) interior part). More...
int cs_ibm_object_compute_cut_porosity (const cs_lnum_t c_id, const cs_real_3_t xyz, const cs_real_t t, const int num_object)
 Check if a point is solid or fluid based on the cut-cell method. More...
void cs_ibm_add_object_from_file (const char *name, cs_ibm_algo_type_t method, const char *file_name, bool solve_fsi)
 Define an object from a file using STL or MED formats. More...
void cs_ibm_add_object_from_func (const char *name, cs_cutcell_func_t *cutcell_func, bool solve_fsi, int n_nodes)
 Define an object from a function used in the cutcell algorithm. More...
void cs_ibm_stl_define_ext_points (const char *name, const int n_pts, cs_real_t *pts_coords)
 Define exterior points for an stl object. More...
void cs_ibm_object_rotate (const char *name, cs_real_t angle, cs_real_t axis[3], cs_real_t center[3])
 Rotate an object based on the STL or MED algorithms. More...
void cs_ibm_object_set_property_const (cs_ibm_object_t *obj, cs_ibm_object_property_type_t ppty_id, cs_real_t val)
 Define a new constant property definition for an object. More...
void cs_ibm_object_translate (const char *name, cs_real_t vector[3])
 Translate an object based on the STL or MED algorithms. More...
void cs_ibm_object_scale (const char *name, cs_real_t factor)
 Scale an object based on a factor. More...
void cs_ibm_user_parameters (void)
 Apply user parameters. More...
void cs_ibm_init_writer (void)
 Init writers for STL or MED objects. More...
void cs_ibm_object_transform_from_init (cs_ibm_object_t *obj, cs_real_34_t matrix)
 Transform an object from its initial state using a transformation matrix. More...
void cs_ibm_object_compute_intersect_vol (cs_ibm_object_t *obj, const cs_mesh_t *m, const cs_real_t *cell_vol, cs_real_t *obj_frac_tot, int *indic)
 Compute the volume fraction of an object over all cells. More...
void cs_ibm_volumic_zone (const cs_mesh_quantities_t *mesh_quantities)
 Define space immersed boundaries on a set of zones defined by the user in the GUI. More...
static cs_porosity_ibm_opt_t _porosity_ibm_opt
cs_porosity_ibm_opt_t * cs_glob_porosity_ibm_opt = &(_porosity_ibm_opt)
cs_ibm_t * cs_ibm = nullptr
const char * _ibm_algo_names []
const char * _ibm_obj_property_names []
const char * _ibm_obj_init_vals_names []
Define immersed boundaries based on user inputs (experimental). Cloud of points are dealt with porosity from scan files.
◆ _add_ibm_object()
static int _add_ibm_object ( const char *  name,
static
[in]namename of the new object
[in]methodmethod used to compute the object porosity
id of the new object (int)
◆ _compute_b_fac_porosity()
static void _compute_b_fac_porosity ( const cs_mesh_t *  mesh,
const cs_mesh_quantities_t *  mesh_quantities,
cs_real_t *  c_poro,
cs_real_t *  v_poro,
cs_real_t *  bfpro_poro
static
[in]meshpointer to associated mesh structure
[in]mesh_quantitiespointer to associated mesh quantities
[in]c_porocell porosity
[in]v_porovertex porosity
[out]bfpro_poroboundary face porosity
◆ _compute_cell_cog()
static void _compute_cell_cog ( const cs_mesh_t *  mesh,
cs_real_t *  v_poro,
cs_real_t *  por_init,
int *  comp_cell
static
[in]por_vtxvertex porosity
[in]por_initinitialization porosity
[in]comp_celllist of cells to recompute porosity
◆ _compute_cell_cut_porosity()
static void _compute_cell_cut_porosity ( const cs_mesh_t *  mesh,
int *  comp_cell
static
◆ _compute_cell_list_porosity()
static void _compute_cell_list_porosity ( const cs_mesh_t *  mesh,
cs_lnum_t *  comp_cell
static
[out]comp_celllist of cells to recompute porosity
◆ _compute_i_fac_porosity()
static void _compute_i_fac_porosity ( const cs_mesh_t *  mesh,
cs_real_t *  c_poro,
cs_real_t *  v_poro,
cs_real_t *  ifpro_poro
static
[out]ifpro_porointernal face porosity
◆ _compute_iso_vol_porosity()
static void _compute_iso_vol_porosity ( const cs_mesh_t *  mesh,
cs_real_t *  c_poro,
int *  comp_cell
static
◆ _compute_solid_porosity()
static void _compute_solid_porosity ( const cs_mesh_t *  mesh,
cs_real_t *  c_poro,
int *  comp_cell
static
◆ _compute_solid_surface_cog()
static void _compute_solid_surface_cog ( const cs_mesh_t *  mesh,
cs_real_t *  c_poro,
cs_real_t *  v_poro,
cs_real_t *  i_poro,
cs_real_t *  b_poro
static
[in]i_porointernal face porosity
[in]b_poroboundary face porosity
◆ _compute_solid_surface_vector()
static void _compute_solid_surface_vector ( const cs_mesh_t *  mesh,
cs_real_t *  i_poro,
cs_real_t *  b_poro
static
◆ _create_ibm_object()
static cs_ibm_object_t * _create_ibm_object ( const char *  name,
static
pointer to new object structure
◆ _free_ibm_object()
static void _free_ibm_object ( cs_ibm_object_t *  obj)
static
[in]objpointer to structure to free
◆ _geom_face_fraction()
static cs_real_t _geom_face_fraction ( cs_real_t  alphai,
cs_real_t  alphaj,
cs_real_t  sizei,
cs_real_t  sizej
static
[in]alphaivalue at neighbouring cell i
[in]alphajvalue at neighbouring cell j
[in]sizeidistance face - center of gravity cell i
[in]sizejdistance face - center of gravity cell j
◆ _get_xdef_val_at_object_elt()
static cs_real_t _get_xdef_val_at_object_elt ( const cs_xdef_t *  def,
const int  elt_id
inlinestatic
[in]defPointer to cs_xdef_t definition
[in]elt_idElement id (int)
◆ _ibm_object_define_initial_val_def()
static void _ibm_object_define_initial_val_def ( cs_ibm_object_t *  obj,
int  n_vals,
cs_real_t *  vals
static
[in]objPointer to object
[in]p_idProperty id (enum)
[in]n_valsNumber of values (array size)
[in]valsValues array (size n_vals)
◆ _ibm_object_define_property_def()
static void _ibm_object_define_property_def ( cs_ibm_object_t *  obj,
int  n_vals,
cs_real_t *  vals
static
[in]objpointer to object
[in]ppty_idproperty id (si enum for list)
[in]n_valsnumber of values (array size)
[in]valsarray of values
◆ _imm_lgth_cutcell()
static cs_real_t _imm_lgth_cutcell ( cs_real_3_t  x1,
cs_real_3_t  x2,
cs_real_t  t,
int  num_object
static
[in]x1point 1
[in]x2point 2
[in]ttime value for the current time step
[in]num_objectnum of fsi object (if fsi activated)
◆ _imm_lgth_poro()
static cs_real_t _imm_lgth_poro ( cs_real_3_t  x1,
cs_real_t  por1,
cs_real_3_t  x2,
cs_real_t  por2
inlinestatic
[in]x1point 1
[in]por1porosity at 1
[in]x2point 2
[in]por2porosity at 2
◆ _penal_glob()
static int _penal_glob ( const cs_lnum_t  c_id,
const cs_real_t  t,
static
[in]c_idlocal cell number
[in]xyzx, y, z coordinates of the current position
◆ _prism_vol()
static cs_real_t _prism_vol ( cs_real_3_t  x1,
cs_real_3_t  x2,
cs_real_3_t  x3,
cs_real_3_t  x4,
cs_real_3_t  x5,
cs_real_3_t  x6
static
[in]x1point 1
[in]x2point 2
[in]x3point 3
[in]x4point 4
[in]x5point 5
[in]x6point 6
◆ _pyram_vol()
static cs_real_t _pyram_vol ( cs_real_3_t  x1,
cs_real_3_t  x2,
cs_real_3_t  x3,
cs_real_3_t  x4,
cs_real_3_t  x5
static
[in]x1point 1
[in]x2point 2
[in]x3point 3
[in]x4point 4
[in]x5point 5 (apex)
◆ _tetra_vol()
static cs_real_t _tetra_vol ( cs_real_3_t  x1,
cs_real_3_t  x2,
cs_real_3_t  x3,
cs_real_3_t  x4
inlinestatic
[in]x1point 1
[in]x2point 2
[in]x3point 3
[in]x4point 4
◆ _tetra_vol_cutcell()
static void _tetra_vol_cutcell ( cs_real_t *  vol,
cs_real_3_t  x1,
cs_real_3_t  x2,
cs_real_3_t  x3,
cs_real_3_t  x4,
cs_real_t  t,
int  icut,
int  num_object
static
[out]volvolume
[in]x1point 1
[in]x2point 2
[in]x3point 3
[in]x4point 4
[in]icutnumber of bisections
◆ _tetra_vol_poro()
static void _tetra_vol_poro ( cs_real_t *  vol,
cs_real_3_t  cog,
cs_real_3_t  x1,
cs_real_t  por1,
cs_real_3_t  x2,
cs_real_t  por2,
cs_real_3_t  x3,
cs_real_t  por3,
cs_real_3_t  x4,
cs_real_t  por4,
int  icut
static
[out]volvolume
[out]cogcenter of gravity
[in]x1point 1
[in]por1porosity at point 1
[in]x2point 2
[in]por2porosity at point 2
[in]x3point 3
[in]por3porosity at point 3
[in]x4point 4
[in]por4porosity at point 4
[in]icutnumber of sub-cut for cells in cut-cells algorithm
◆ _tri_surf_trunc()
static cs_real_t _tri_surf_trunc ( cs_real_3_t  x1,
cs_real_t  por1,
cs_real_3_t  x2,
cs_real_t  por2,
cs_real_3_t  x3,
cs_real_t  por3,
int  icut
static
[in]x1point 1
[in]x2point 2
[in]x3point 3
[in]por3porosity at 3
◆ cs_ibm_add_object_from_file()
void cs_ibm_add_object_from_file ( const char *  name,
const char *  file_name,
bool  solve_fsi
[in]namename of the object
[in]methodPorosity computation method
[in]file_namefile name
[in]solve_fsiIs the object used in the FSI resolution ? (currently ignored)
◆ cs_ibm_add_object_from_func()
void cs_ibm_add_object_from_func ( const char *  name,
cs_cutcell_func_t *  cutcell_func,
bool  solve_fsi,
int  n_nodes
[in]cutcell_funcpointer to the cutcell function of the object
[in]n_nodesNumber of nodes if the object is deformable (currently ignored)
◆ cs_ibm_create()
cs_ibm_t * cs_ibm_create ( void  )
◆ cs_ibm_finalize()
void cs_ibm_finalize ( void  )
◆ cs_ibm_init_writer()
void cs_ibm_init_writer ( void  )
◆ cs_ibm_object_by_id()
cs_ibm_object_t * cs_ibm_object_by_id ( int  obj_id)
[in]obj_idid of the object
pointer to object structure.
◆ cs_ibm_object_by_name()
cs_ibm_object_t * cs_ibm_object_by_name ( const char *  name)
[in]namename of the object to get
pointer to object structure, null if not found
◆ cs_ibm_object_by_name_try()
cs_ibm_object_t * cs_ibm_object_by_name_try ( const char *  name)
Try to get an object based on its name. Returns NULL if not found.
◆ cs_ibm_object_compute_cut_porosity()
int cs_ibm_object_compute_cut_porosity ( const cs_lnum_t  c_id,
const cs_real_t  t,
◆ cs_ibm_object_compute_intersect_vol()
void cs_ibm_object_compute_intersect_vol ( cs_ibm_object_t *  obj,
const cs_mesh_t *  m,
const cs_real_t *  cell_vol,
cs_real_t *  obj_frac_tot,
int *  indic
[in]objpointer to object structure
[in]mpointer to mesh structure
[in]cell_volpointer to cell volume array
[out]obj_frac_totarray containing the total vol fraction of solids
[in]indicindicator array (currently ignored)
◆ cs_ibm_object_rotate()
void cs_ibm_object_rotate ( const char *  name,
cs_real_t  angle,
cs_real_t  axis[3],
cs_real_t  center[3]
[in]angleangle of rotation
[in]axisaxis of rotation
[in]centercenter of rotation
◆ cs_ibm_object_scale()
void cs_ibm_object_scale ( const char *  name,
cs_real_t  factor
[in]factorscaling factor
◆ cs_ibm_object_set_property_const()
void cs_ibm_object_set_property_const ( cs_ibm_object_t *  obj,
cs_real_t  val
[in]valproperty constant value
◆ cs_ibm_object_transform_from_init()
void cs_ibm_object_transform_from_init ( cs_ibm_object_t *  obj,
cs_real_34_t  matrix
[in]matrixtransformation matrix
◆ cs_ibm_object_translate()
void cs_ibm_object_translate ( const char *  name,
cs_real_t  vector[3]
[in]vectortranslation vector
◆ cs_ibm_stl_define_ext_points()
void cs_ibm_stl_define_ext_points ( const char *  name,
const int  n_pts,
cs_real_t *  pts_coords
Define exterior points for an STL object.
[in]n_ptsnumber of points
[in]pts_coordscoordinates of the points
◆ cs_ibm_user_parameters()
void cs_ibm_user_parameters ( void  )
◆ cs_ibm_volumic_zone()
void cs_ibm_volumic_zone ( const cs_mesh_quantities_t *  mesh_quantities)
[in]mesh_quantitiespointer to associated mesh quantities structure
◆ cs_immersed_boundaries()
void cs_immersed_boundaries ( const cs_mesh_t *  mesh,
This function is called several times during each time step.
Ipenal: 1 means only solid and 0 only fluid.
Warning, porosity values have to be 0 or 1.
The solid(s) velocities and porosity are prescirbed within the user function (cs_user_ibm).
◆ _ibm_algo_names
const char* _ibm_algo_names[]
Initial value:
= {"CS_IBM_ALGO_NONE",
"CS_IBM_ALGO_CUT_CELLS",
"CS_IBM_ALGO_MEDCOUPLING",
"CS_IBM_ALGO_STL"}
◆ _ibm_obj_init_vals_names
const char* _ibm_obj_init_vals_names[]
Initial value:
= {"Equilibrium Center of gravity",
"Center of gravity",
"Angle",
"Velocity",
"Acceleration",
"Angular velocity",
"Fluid force"}
◆ _ibm_obj_property_names
const char* _ibm_obj_property_names[]
Initial value:
= {"density",
"mass",
"inertia matrix",
"cp",
"lambda",
"stiffness",
"damping",
"Young module",
"Inertia momentum",
"cross section",
"rayleigh_coeff_a",
"rayleigh_coeff_b"}
◆ _porosity_ibm_opt
static
Initial value:
.porosity_mode = 0
◆ cs_glob_porosity_ibm_opt
cs_porosity_ibm_opt_t* cs_glob_porosity_ibm_opt = &(_porosity_ibm_opt)
◆ cs_ibm
cs_ibm_t* cs_ibm = nullptr
