cs_ibm.h File Reference
+ Include dependency graph for cs_ibm.h:
Classes
struct  cs_porosity_ibm_opt_t
struct  cs_ibm_object_t
struct  cs_ibm_t
Typedefs
typedef int() cs_cutcell_func_t(const cs_lnum_t c_id, const cs_real_3_t xyz, const cs_real_t t, const int num_object)
Enumerations
enum  cs_ibm_model_type_t { CS_IBM_OFF = 0 , CS_IBM_FIXED_SOLID = 1 }
enum  cs_ibm_prob_dim_type_t { CS_IBM_3D = -1 , CS_IBM_2D_X = 0 , CS_IBM_2D_Y = 1 , CS_IBM_2D_Z = 2 }
enum  cs_ibm_algo_type_t {
  CS_IBM_ALGO_NONE , CS_IBM_ALGO_CUT_CELLS , CS_IBM_ALGO_MEDCOUPLING , CS_IBM_ALGO_STL ,
  CS_N_VAR_PORO_ALGO_TYPES
enum  cs_ibm_wall_cond_type_t { CS_IBM_SLIP_WALL_CONDITION , CS_IBM_NO_SLIP_WALL_CONDITION , CS_IBM_WALL_LAW_WALL_CONDITION }
enum  cs_ibm_object_property_type_t {
  CS_IBM_OBJ_PROP_DENSITY , NC_IBM_OBJ_PROP_MASS , NC_IBM_OBJ_PROP_INERTIA_MATRIX , CS_IBM_OBJ_PROP_CP ,
  CS_IBM_OBJ_PROP_LAMBDA , CS_IBM_OBJ_PROP_STIFFNESS , CS_IBM_OBJ_PROP_DAMPING , CS_IBM_OBJ_PROP_YOUNG_MODULE ,
  CS_IBM_OBJ_PROP_INERTIA_MOM , CS_IBM_OBJ_PROP_CROSS_SECTION , CS_IBM_OBJ_PROP_RAYLEIGH_DAMP_A , CS_IBM_OBJ_PROP_RAYLEIGH_DAMP_B ,
  CS_N_IBM_OBJ_PROP_TYPES
enum  cs_ibm_object_init_param_t {
  CS_IBM_OBJ_INIT_COG_EQ , CS_IBM_OBJ_INIT_COG , CS_IBM_OBJ_INIT_ANGLE , CS_IBM_OBJ_INIT_VELOCITY ,
  CS_IBM_OBJ_INIT_ACCELERATION , CS_IBM_OBJ_INIT_ANGULAR_VEL , CS_IBM_OBJ_INIT_FLUID_FORCE , CS_N_IBM_OBJ_INIT_TYPES
cs_ibm_object_t * cs_ibm_object_by_id (int obj_id)
 Get an object based on its id. More...
cs_ibm_object_t * cs_ibm_object_by_name_try (const char *name)
 Try to get an object based on its name. Returns NULL if not found. More...
cs_ibm_object_t * cs_ibm_object_by_name (const char *name)
 Get an object based on its name. Error if not found. More...
cs_ibm_t * cs_ibm_create (void)
void cs_ibm_finalize (void)
void cs_immersed_boundaries (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities)
 Define immersed boundaries in time and space (solid(s) interior part). More...
void cs_volumic_zone_porosity (const cs_mesh_quantities_t *mesh_quantities)
int cs_ibm_object_compute_cut_porosity (const cs_lnum_t c_id, const cs_real_3_t xyz, const cs_real_t t, const int num_object)
 Check if a point is solid or fluid based on the cut-cell method. More...
void cs_ibm_add_object_from_file (const char *name, cs_ibm_algo_type_t method, const char *file_name, bool solve_fsi)
 Define an object from a file using STL or MED formats. More...
void cs_ibm_add_object_from_func (const char *name, cs_cutcell_func_t *cutcell_func, bool solve_fsi, int n_nodes)
 Define an object from a function used in the cutcell algorithm. More...
void cs_ibm_stl_define_ext_points (const char *name, const int n_pts, cs_real_t *pts_coords)
 Define exterior points for an STL object. More...
void cs_ibm_object_rotate (const char *name, cs_real_t angle, cs_real_t axis[3], cs_real_t center[3])
 Rotate an object based on the STL or MED algorithms. More...
void cs_ibm_object_set_property_const (cs_ibm_object_t *obj, cs_ibm_object_property_type_t ppty_id, cs_real_t val)
 Define a new constant property definition for an object. More...
void cs_ibm_object_translate (const char *name, cs_real_t vector[3])
 Translate an object based on the STL or MED algorithms. More...
void cs_ibm_object_scale (const char *name, cs_real_t factor)
 Scale an object based on a factor. More...
void cs_ibm_user_parameters (void)
 Apply user parameters. More...
void cs_ibm_init_writer (void)
 Init writers for STL or MED objects. More...
void cs_ibm_object_transform_from_init (cs_ibm_object_t *obj, cs_real_34_t matrix)
 Transform an object from its initial state using a transformation matrix. More...
void cs_ibm_object_compute_intersect_vol (cs_ibm_object_t *obj, const cs_mesh_t *m, const cs_real_t *cell_vol, cs_real_t *obj_frac_tot, int *indic)
 Compute the volume fraction of an object over all cells. More...
void cs_ibm_volumic_zone (const cs_mesh_quantities_t *mesh_quantities)
 Define space immersed boundaries on a set of zones defined by the user in the GUI. More...
void cs_user_ibm_define_objects (void)
 User function in which the user defines the objects to model. More...
void cs_user_ibm_parameters (void)
 User function to set global parameters for the immersed boundaries module. More...
void cs_user_ibm_object_transformations (const cs_real_t time)
 User function where to apply predefined transformations to MED/STL based objects. More...
void cs_user_ibm_solid_por (const cs_lnum_t c_id, const cs_real_3_t xyz, const cs_real_t t, const int num_object)
 User function which allows the definition of a 'porous' object. More...
void cs_user_ibm_modify (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities)
 User function. Locally modify a given porosity to take into account erosion effect (for instance). More...
cs_porosity_ibm_opt_t * cs_glob_porosity_ibm_opt
cs_ibm_t * cs_ibm
Typedef Documentation
◆ cs_cutcell_func_t
◆ cs_ibm_algo_type_t
Enumerator
CS_IBM_ALGO_NONE
CS_IBM_ALGO_STL
◆ cs_ibm_model_type_t
Enumerator
CS_IBM_OFF
CS_IBM_FIXED_SOLID
◆ cs_ibm_object_init_param_t
Enumerator
CS_IBM_OBJ_INIT_COG
◆ cs_ibm_object_property_type_t
Enumerator
CS_IBM_OBJ_PROP_CP
◆ cs_ibm_prob_dim_type_t
Enumerator
CS_IBM_3D
CS_IBM_2D_X
CS_IBM_2D_Y
CS_IBM_2D_Z
◆ cs_ibm_wall_cond_type_t
Enumerator
◆ cs_ibm_add_object_from_file()
void cs_ibm_add_object_from_file ( const char *  name,
const char *  file_name,
bool  solve_fsi
[in]namename of the object
[in]methodPorosity computation method
[in]file_namefile name
[in]solve_fsiIs the object used in the FSI resolution ? (currently ignored)
◆ cs_ibm_add_object_from_func()
void cs_ibm_add_object_from_func ( const char *  name,
cs_cutcell_func_t *  cutcell_func,
bool  solve_fsi,
int  n_nodes
[in]cutcell_funcpointer to the cutcell function of the object
[in]n_nodesNumber of nodes if the object is deformable (currently ignored)
◆ cs_ibm_create()
cs_ibm_t * cs_ibm_create ( void  )
◆ cs_ibm_finalize()
void cs_ibm_finalize ( void  )
◆ cs_ibm_init_writer()
void cs_ibm_init_writer ( void  )
◆ cs_ibm_object_by_id()
cs_ibm_object_t * cs_ibm_object_by_id ( int  obj_id)
[in]obj_idid of the object
pointer to object structure.
◆ cs_ibm_object_by_name()
cs_ibm_object_t * cs_ibm_object_by_name ( const char *  name)
[in]namename of the object to get
pointer to object structure, NULL if not found
pointer to object structure, null if not found
◆ cs_ibm_object_by_name_try()
cs_ibm_object_t * cs_ibm_object_by_name_try ( const char *  name)
◆ cs_ibm_object_compute_cut_porosity()
int cs_ibm_object_compute_cut_porosity ( const cs_lnum_t  c_id,
const cs_real_t  t,
[in]c_idlocal cell number
[out]ipenalindicator for cut cells algo
[in]xyzx, y, z coordinates of the current position
[in]ttime value for the current time step
[in]num_objectnum of fsi object (if fsi activated)
◆ cs_ibm_object_compute_intersect_vol()
void cs_ibm_object_compute_intersect_vol ( cs_ibm_object_t *  obj,
const cs_mesh_t *  m,
const cs_real_t *  cell_vol,
cs_real_t *  obj_frac_tot,
int *  indic
[in]objpointer to object structure
[in]mpointer to mesh structure
[in]cell_volpointer to cell volume array
[out]obj_frac_totarray containing the total vol fraction of solids
[in]indicindicator array
[in]indicindicator array (currently ignored)
◆ cs_ibm_object_rotate()
void cs_ibm_object_rotate ( const char *  name,
cs_real_t  angle,
cs_real_t  axis[3],
cs_real_t  center[3]
[in]angleangle of rotation
[in]axisaxis of rotation
[in]centercenter of rotation
◆ cs_ibm_object_scale()
void cs_ibm_object_scale ( const char *  name,
cs_real_t  factor
[in]factorscaling factor
◆ cs_ibm_object_set_property_const()
void cs_ibm_object_set_property_const ( cs_ibm_object_t *  obj,
cs_real_t  val
[in]ppty_idproperty id (si enum for list)
[in]valproperty constant value
◆ cs_ibm_object_transform_from_init()
void cs_ibm_object_transform_from_init ( cs_ibm_object_t *  obj,
cs_real_34_t  matrix
[in]matrixtransformation matrix
◆ cs_ibm_object_translate()
void cs_ibm_object_translate ( const char *  name,
cs_real_t  vector[3]
[in]vectortranslation vector
◆ cs_ibm_stl_define_ext_points()
void cs_ibm_stl_define_ext_points ( const char *  name,
const int  n_pts,
cs_real_t *  pts_coords
[in]n_ptsnumber of points
[in]pts_coordscoordinates of the points
◆ cs_ibm_user_parameters()
void cs_ibm_user_parameters ( void  )
◆ cs_ibm_volumic_zone()
void cs_ibm_volumic_zone ( const cs_mesh_quantities_t *  mesh_quantities)
[in]mesh_quantitiespointer to associated mesh quantities structure
◆ cs_immersed_boundaries()
void cs_immersed_boundaries ( const cs_mesh_t *  mesh,
This function is called several times during each time step.
Ipenal: 1 means only solid and 0 only fluid.
Warning, porosity values have to be 0 or 1.
The solid(s) velocities and porosity are prescirbed within the user function (cs_user_ibm).
[in]meshpointer to associated mesh structure
◆ cs_user_ibm_define_objects()
void cs_user_ibm_define_objects ( void  )
◆ cs_user_ibm_modify()
void cs_user_ibm_modify ( const cs_mesh_t *  mesh,
This function is called for each time step. Porosity will be modified if cs_ibm->porosity_user_source_term_modification = true
◆ cs_user_ibm_object_transformations()
void cs_user_ibm_object_transformations ( const cs_real_t  time)
◆ cs_user_ibm_parameters()
void cs_user_ibm_parameters ( void  )
◆ cs_user_ibm_solid_por()
void cs_user_ibm_solid_por ( const cs_lnum_t  c_id,
const cs_real_t  t,
◆ cs_volumic_zone_porosity()
void cs_volumic_zone_porosity ( const cs_mesh_quantities_t *  mesh_quantities)
◆ cs_glob_porosity_ibm_opt
cs_porosity_ibm_opt_t* cs_glob_porosity_ibm_opt
extern
◆ cs_ibm
cs_ibm_t* cs_ibm
extern
