cs_hho_scaleq.cpp File Reference
#include <float.h>
#include "base/cs_mem.h"
#include "cdo/cs_cdo_advection.h"
#include "cdo/cs_cdo_assembly.h"
#include "cdo/cs_cdo_bc.h"
#include "cdo/cs_cdo_diffusion.h"
#include "cdo/cs_hho_builder.h"
#include "cdo/cs_hodge.h"
#include "base/cs_log.h"
#include "base/cs_math.h"
#include "base/cs_post.h"
#include "cdo/cs_reco.h"
#include "cdo/cs_scheme_geometry.h"
#include "base/cs_search.h"
#include "cdo/cs_sdm.h"
#include "cdo/cs_hho_scaleq.h"
+ Include dependency graph for cs_hho_scaleq.cpp:
Macros
#define CS_HHO_SCALEQ_DBG   0
#define _dp3   cs_math_3_dot_product
static cs_cell_builder_t * _cell_builder_create (cs_param_space_scheme_t space_scheme, const cs_cdo_connect_t *connect)
 Initialize the local builder structure used for building the system cellwise. More...
static void _shho_init_cell_system (const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_equation_builder_t *eqb, const cs_hho_scaleq_t *eqc, cs_hho_builder_t *hhob, cs_cell_sys_t *csys, cs_cell_builder_t *cb)
 Initialize the local structures for the current cell. Case of scalar-valued HHO schemes. More...
static void _condense_and_store (const cs_adjacency_t *c2f, cs_hho_scaleq_t *eqc, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
 Proceed to a static condensation of the local system and keep information inside the builder to be able to compute the values at cell centers. More...
void cs_hho_scaleq_init_sharing (cs_flag_t scheme_flag, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
 Allocate work buffer and general structures related to HHO schemes Set shared pointers. More...
void cs_hho_scaleq_get (cs_cell_sys_t **csys, cs_cell_builder_t **cb, cs_hho_builder_t **hhob)
void cs_hho_scaleq_finalize_sharing (void)
 Free buffers and generic structures related to HHO schemes. More...
void * cs_hho_scaleq_init_context (cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb)
 Initialize a cs_hho_scaleq_t structure storing data useful for building and managing such a scheme. More...
void * cs_hho_scaleq_free_context (void *data)
 Destroy a cs_hho_scaleq_t structure. More...
void cs_hho_scaleq_init_values (cs_real_t t_eval, const int field_id, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
 Set the initial values of the variable field taking into account the boundary conditions. Case of scalar-valued HHO schemes. More...
void cs_hho_scaleq_initialize_system (const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data, cs_matrix_t **system_matrix, cs_real_t **system_rhs)
 Create the matrix of the current algebraic system. Allocate and initialize the right-hand side associated to the given data structure. More...
void cs_hho_scaleq_build_system (const cs_mesh_t *mesh, const cs_real_t *field_val, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
 Build the linear system arising from a scalar convection/diffusion equation with a HHO scheme. One works cellwise and then process to the assembly. More...
void cs_hho_scaleq_update_field (const cs_real_t *solu, const cs_real_t *rhs, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data, cs_real_t *field_val)
 Store solution(s) of the linear system into a field structure Update extra-field values required for hybrid discretization. More...
cs_real_t * cs_hho_scaleq_get_face_values (void *context, bool previous)
 Get the computed values at faces (DoF used in the linear system are located at primal faces) More...
cs_real_t * cs_hho_scaleq_get_cell_values (void *context, bool previous)
 Get the computed values at cells (DoF used in the linear system are located at primal faces) More...
void cs_hho_scaleq_read_restart (cs_restart_t *restart, const char *eqname, void *scheme_context)
void cs_hho_scaleq_write_restart (cs_restart_t *restart, const char *eqname, void *scheme_context)
void cs_hho_scaleq_extra_post (const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
static cs_cell_sys_t ** cs_hho_cell_sys = nullptr
static cs_cell_builder_t ** cs_hho_cell_bld = nullptr
static cs_hho_builder_t ** cs_hho_builders = nullptr
static const cs_cdo_quantities_t * cs_shared_quant
static const cs_cdo_connect_t * cs_shared_connect
static const cs_time_step_t * cs_shared_time_step
◆ _dp3
◆ CS_HHO_SCALEQ_DBG
◆ _cell_builder_create()
static cs_cell_builder_t * _cell_builder_create ( cs_param_space_scheme_t  space_scheme,
const cs_cdo_connect_t *  connect
static
[in]space_schemediscretization scheme
a pointer to a new allocated cs_cell_builder_t structure
◆ _condense_and_store()
static void _condense_and_store ( const cs_adjacency_t *  c2f,
cs_hho_scaleq_t *  eqc,
cs_cell_builder_t *  cb,
cs_cell_sys_t *  csys
static
[in]c2fpointer to a cs_adjacency_t structure
[in,out]eqcpointer to a cs_hho_scaleq_t structure
[in,out]csyspointer to a cs_cell_sys_t structure
◆ _shho_init_cell_system()
static void _shho_init_cell_system ( const cs_cell_mesh_t *  cm,
const cs_equation_builder_t *  eqb,
const cs_hho_scaleq_t *  eqc,
cs_hho_builder_t *  hhob,
cs_cell_sys_t *  csys,
static
[in]cmpointer to a cellwise view of the mesh
[in]eqbpointer to a cs_equation_builder_t structure
[in]eqcpointer to a cs_hho_vecteq_t structure
[in,out]hhobpointer to a cs_hho_builder_t structure
◆ cs_hho_scaleq_build_system()
void cs_hho_scaleq_build_system ( const cs_mesh_t *  mesh,
const cs_real_t *  field_val,
void *  context
[in]field_valpointer to the current value of the field
[in,out]contextpointer to cs_hho_scaleq_t structure
◆ cs_hho_scaleq_extra_post()
void cs_hho_scaleq_extra_post ( const cs_equation_param_t *  eqp,
void *  context
◆ cs_hho_scaleq_finalize_sharing()
void cs_hho_scaleq_finalize_sharing ( void  )
◆ cs_hho_scaleq_free_context()
void * cs_hho_scaleq_free_context ( void *  data)
[in,out]datapointer to a cs_hho_scaleq_t structure
a null pointer
◆ cs_hho_scaleq_get()
void cs_hho_scaleq_get ( cs_cell_sys_t **  csys,
cs_cell_builder_t **  cb,
cs_hho_builder_t **  hhob
[out]hhobpointer to a pointer on a cs_hho_builder_t structure
◆ cs_hho_scaleq_get_cell_values()
cs_real_t * cs_hho_scaleq_get_cell_values ( void *  context,
bool  previous
a pointer to an array of cs_real_t
◆ cs_hho_scaleq_get_face_values()
cs_real_t * cs_hho_scaleq_get_face_values ( void *  context,
bool  previous
◆ cs_hho_scaleq_init_context()
void * cs_hho_scaleq_init_context ( cs_equation_param_t *  eqp,
int  var_id,
int  bflux_id,
a pointer to a new allocated cs_hho_scaleq_t structure
◆ cs_hho_scaleq_init_sharing()
void cs_hho_scaleq_init_sharing ( cs_flag_t  scheme_flag,
[in]scheme_flagflag to identify which kind of numerical scheme is requested to solve the computational domain
◆ cs_hho_scaleq_init_values()
void cs_hho_scaleq_init_values ( cs_real_t  t_eval,
const int  field_id,
void *  context
◆ cs_hho_scaleq_initialize_system()
void cs_hho_scaleq_initialize_system ( const cs_equation_param_t *  eqp,
void *  data,
cs_matrix_t **  system_matrix,
cs_real_t **  system_rhs
[in,out]datapointer to generic data structure
[in,out]system_matrixpointer of pointer to a cs_matrix_t struct.
[in,out]system_rhspointer of pointer to an array of double
◆ cs_hho_scaleq_read_restart()
void cs_hho_scaleq_read_restart ( cs_restart_t *  restart,
const char *  eqname,
void *  scheme_context
◆ cs_hho_scaleq_update_field()
void cs_hho_scaleq_update_field ( const cs_real_t *  solu,
const cs_real_t *  rhs,
void *  data,
[in]solusolution array
[in]rhsrhs associated to this solution array
[in,out]datapointer to cs_hho_scaleq_t structure
[in,out]field_valpointer to the current value of the field
◆ cs_hho_scaleq_write_restart()
void cs_hho_scaleq_write_restart ( cs_restart_t *  restart,
◆ cs_hho_builders
cs_hho_builder_t** cs_hho_builders = nullptr
static
◆ cs_hho_cell_bld
cs_cell_builder_t** cs_hho_cell_bld = nullptr
static
◆ cs_hho_cell_sys
cs_cell_sys_t** cs_hho_cell_sys = nullptr
static
◆ cs_shared_connect
const cs_cdo_connect_t* cs_shared_connect
static
◆ cs_shared_quant
const cs_cdo_quantities_t* cs_shared_quant
static
◆ cs_shared_time_step
const cs_time_step_t* cs_shared_time_step
static
