cs_hho_builder.cpp File Reference
#include "base/cs_mem.h"
#include "bft/bft_error.h"
#include "base/cs_log.h"
#include "cdo/cs_hho_builder.h"
+ Include dependency graph for cs_hho_builder.cpp:
Macros
#define _dp3   cs_math_3_dot_product
#define _mv3   cs_math_33_3_product
#define CS_HHO_BUILDER_DBG   0
static void _fill_vol_reco_op (cs_sdm_t *stiffness, cs_sdm_t *rhs_c_t, cs_hho_builder_t *hhob)
 Fill the volume-related part of the matrices when building the reconstruction operator. More...
static void _add_tria_reduction (cs_real_t t_eval, const cs_xdef_analytic_context_t *ac, const cs_basis_func_t *fbf, const cs_real_3_t xv1, const cs_real_3_t xv2, const cs_real_3_t xv3, const double surf, cs_cell_builder_t *cb, cs_real_t array[])
 Compute the reduction onto the face polynomial space of a function defined by an analytical expression depending on the location and the current time. More...
static void _add_tria_reduction_v (cs_real_t t_eval, const cs_xdef_analytic_context_t *ac, const cs_basis_func_t *fbf, const cs_real_3_t xv1, const cs_real_3_t xv2, const cs_real_3_t xv3, const double surf, cs_cell_builder_t *cb, cs_real_t array[])
 Compute the reduction onto the face polynomial space of a function defined by an analytical expression depending on the location and the current time. Vector case. More...
static void _add_tetra_reduction (cs_real_t t_eval, const cs_xdef_analytic_context_t *ac, const cs_basis_func_t *cbf, const cs_real_3_t xv1, const cs_real_3_t xv2, const cs_real_3_t xv3, const cs_real_3_t xv4, const double vol, cs_cell_builder_t *cb, cs_real_t array[])
 Compute the reduction onto the cell polynomial space of a function defined by an analytical expression depending on the location and the current time. More...
static void _add_tetra_reduction_v (cs_real_t t_eval, const cs_xdef_analytic_context_t *ac, const cs_basis_func_t *cbf, const cs_real_3_t xv1, const cs_real_3_t xv2, const cs_real_3_t xv3, const cs_real_3_t xv4, const double vol, cs_cell_builder_t *cb, cs_real_t array[])
 Compute the reduction onto the cell polynomial space of a function defined by an analytical expression depending on the location and the current time.Vector case. More...
static void _add_tria_to_reco_op (const cs_real_3_t xv1, const cs_real_3_t xv2, const cs_real_3_t xv3, const double surf, const cs_basis_func_t *fbf, const cs_real_t *kappa_nfc, cs_real_3_t *gpts, cs_sdm_t *rc, cs_sdm_t *rf, cs_cell_builder_t *cb, cs_hho_builder_t *hhob)
 Routine for computing volumetric integrals over a tetrahedron which are contributions to the local stiffness matrix on the gradient basis and to the right-hand side. More...
static void _add_tetra_to_reco_op (const cs_real_3_t xv1, const cs_real_3_t xv2, const cs_real_3_t xv3, const cs_real_3_t xv4, const double vol, const cs_property_data_t *diff_pty, cs_sdm_t *stiffness, cs_real_3_t *gpts, cs_cell_builder_t *cb, cs_hho_builder_t *hhob)
static void _add_contrib_mcg (const cs_real_3_t xv1, const cs_real_3_t xv2, const cs_real_3_t xv3, const cs_real_3_t xv4, const double vol, const cs_basis_func_t *cbf_kp1, cs_sdm_t *m_cg, cs_cell_builder_t *cb, cs_hho_builder_t *hhob)
 Routine for computing volumetric integrals over a tetrahedron which are contributions to the M_cg matrix. More...
static void _add_contrib_mf_cg (const cs_real_3_t xv1, const cs_real_3_t xv2, const cs_real_3_t xv3, const double surf, const cs_basis_func_t *fbf, const cs_basis_func_t *cbf_kp1, cs_sdm_t *mf_cg, cs_cell_builder_t *cb, cs_hho_builder_t *hhob)
 Routine for computing surfacic integrals over a triangle which are contributions to the Mf_cg matrix. More...
static cs_sdm_t * _compute_mcg (const cs_cell_mesh_t *cm, cs_basis_func_t *cbf_kp1, cs_cell_builder_t *cb, cs_hho_builder_t *hhob)
 Compute the diffusion operator. The gradient reconstruction operator has to be built just before this call (cb->aux stores the rhs) More...
cs_hho_builder_t * cs_hho_builder_create (int order, int n_fc)
 Allocate a cs_hho_builder_t structure. More...
void cs_hho_builder_free (cs_hho_builder_t **p_builder)
 Free a cs_hho_builder_t structure. More...
void cs_hho_builder_cellwise_setup (const cs_cell_mesh_t *cm, cs_cell_builder_t *cb, cs_hho_builder_t *hhob)
 Set-up the basis functions related to a cell, its gradient and to the faces of this cell. Compute cell and face projection and its related modified Cholesky factorization. More...
void cs_hho_builder_compute_grad_reco (const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_cell_builder_t *cb, cs_hho_builder_t *hhob)
 Compute the gradient operator stemming from the relation stiffness * grad_op = rhs where stiffness is a square matrix of size grd_size rhs is matrix of size (n_fc*f_size + c_size) * grd_size Hence, grad_op a matrix grd_size * (n_fc*f_size + c_size) More...
void cs_hho_builder_diffusion (const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_cell_builder_t *cb, cs_hho_builder_t *hhob)
void cs_hho_builder_reduction_from_analytic (const cs_xdef_t *def, const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_cell_builder_t *cb, cs_hho_builder_t *hhob, cs_real_t red[])
 Compute the reduction onto the polynomial spaces (cell and faces) of a function defined by an analytical expression depending on the location and the current time red array has to be allocated before calling this function. More...
void cs_hho_builder_reduction_from_analytic_v (const cs_xdef_t *def, const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_cell_builder_t *cb, cs_hho_builder_t *hhob, cs_real_t red[])
 Compute the reduction onto the polynomial spaces (cell and faces) of a function defined by an analytical expression depending on the location and the current time This function handles the vector case. More...
void cs_hho_builder_compute_dirichlet (const cs_xdef_t *def, short int f, const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_cell_builder_t *cb, cs_hho_builder_t *hhob, cs_real_t res[])
 Compute the projection of the Dirichlet boundary conditions onto the polynomial spaces on faces. More...
void cs_hho_builder_compute_dirichlet_v (const cs_xdef_t *def, short int f, const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_cell_builder_t *cb, cs_hho_builder_t *hhob, cs_real_t res[])
 Compute the projection of the Dirichlet boundary conditions onto the polynomial spaces on faces. Vector case. More...
◆ _dp3
◆ _mv3
◆ CS_HHO_BUILDER_DBG
◆ _add_contrib_mcg()
static void _add_contrib_mcg ( const cs_real_3_t  xv1,
const double  vol,
const cs_basis_func_t *  cbf_kp1,
cs_sdm_t *  m_cg,
cs_cell_builder_t *  cb,
cs_hho_builder_t *  hhob
inlinestatic
[in]xv1first vertex
[in]xv2second vertex
[in]xv3third vertex
[in]xv4fourth vertex
[in]volvolume of the tetrahedron
[in]cbf_kp1pointer to a cell basis function order:k+1
[in,out]m_cgmatrix to compute
[in,out]cbpointer to a cs_cell_builder_structure_t
[in,out]hhobpointer to a cs_hho_builder_t structure
◆ _add_contrib_mf_cg()
static void _add_contrib_mf_cg ( const cs_real_3_t  xv1,
const double  surf,
const cs_basis_func_t *  fbf,
cs_sdm_t *  mf_cg,
inlinestatic
[in]xv1first vertex
[in]xv3third vertex
[in]surfsurface of the triangle to consider
[in]fbfpointer to a set of face basis functions
[in]cbf_kp1pointer to a set of cell basis functions (k+1)
[in,out]mf_cgmatrix to compute
◆ _add_tetra_reduction()
static void _add_tetra_reduction ( cs_real_t  t_eval,
const cs_xdef_analytic_context_t *  ac,
const cs_basis_func_t *  cbf,
const double  vol,
cs_real_t  array[]
inlinestatic
[in]acpointer to an analytical definition
[in]cbfpointer to a structure for face basis functions
[in]xv1first vertex
[in]xv3third vertex
[in]xv4third vertex
[in,out]arrayarray storing values to compute
◆ _add_tetra_reduction_v()
static void _add_tetra_reduction_v ( cs_real_t  t_eval,
const double  vol,
cs_real_t  array[]
inlinestatic
[in]xv1first vertex
[in]xv3third vertex
[in]xv4third vertex
◆ _add_tetra_to_reco_op()
static void _add_tetra_to_reco_op ( const cs_real_3_t  xv1,
const double  vol,
const cs_property_data_t *  diff_pty,
cs_sdm_t *  stiffness,
cs_real_3_t *  gpts,
static
[in]xv1first vertex
[in]xv3third vertex
[in]diff_ptypointer to a cs_property_data_t
[in,out]stiffnessstiffness matrix to compute
[in,out]gptscoordinates of the Gauss points
◆ _add_tria_reduction()
static void _add_tria_reduction ( cs_real_t  t_eval,
const double  surf,
cs_real_t  array[]
inlinestatic
[in]fbfpointer to a structure for face basis functions
[in]xv1first vertex
[in]xv3third vertex
[in]surfarea of the triangle
◆ _add_tria_reduction_v()
static void _add_tria_reduction_v ( cs_real_t  t_eval,
const double  surf,
cs_real_t  array[]
inlinestatic
[in]xv1first vertex
[in]xv3third vertex
◆ _add_tria_to_reco_op()
static void _add_tria_to_reco_op ( const cs_real_3_t  xv1,
const double  surf,
const cs_real_t *  kappa_nfc,
cs_real_3_t *  gpts,
cs_sdm_t *  rc,
cs_sdm_t *  rf,
static
[in]xv1first vertex
[in]xv3third vertex
[in]fbfpointer to the related set of face basis functions
[in]kappa_nfcpermeability tensor times the related face normal
[in,out]rcright-hand side matrix to compute (cell part)
[in,out]rfright-hand side matrix to compute (face part)
[in,out]kappa_nfccoordinates of the Gauss points
◆ _compute_mcg()
static cs_sdm_t * _compute_mcg ( const cs_cell_mesh_t *  cm,
static
[in]cbf_kp1pointer to a set of cell basis functions order=k+1
[in,out]cbpointer to a cell builder_t structure
a pointer to a cs_sdm_t structure storing m_cg
◆ _fill_vol_reco_op()
static void _fill_vol_reco_op ( cs_sdm_t *  stiffness,
cs_sdm_t *  rhs_c_t,
static
[in,out]stiffnesspointer to the stiffness matrix
[in,out]rhs_c_tpointer to the right-hand side (matrix)
◆ cs_hho_builder_cellwise_setup()
void cs_hho_builder_cellwise_setup ( const cs_cell_mesh_t *  cm,
[in]cbpointer to a cell builder_t structure
◆ cs_hho_builder_compute_dirichlet()
void cs_hho_builder_compute_dirichlet ( const cs_xdef_t *  def,
short int  f,
cs_real_t  t_eval,
cs_hho_builder_t *  hhob,
cs_real_t  res[]
[in]defpointer to a cs_xdef_t structure
[in]flocal face id in the cellwise view of the mesh
[in,out]resvector containing the result
◆ cs_hho_builder_compute_dirichlet_v()
void cs_hho_builder_compute_dirichlet_v ( const cs_xdef_t *  def,
short int  f,
cs_real_t  t_eval,
cs_real_t  res[]
◆ cs_hho_builder_compute_grad_reco()
void cs_hho_builder_compute_grad_reco ( const cs_cell_mesh_t *  cm,
[in]diff_ptypointer to a cs_property_data_t structure
◆ cs_hho_builder_create()
cs_hho_builder_t * cs_hho_builder_create ( int  order,
int  n_fc
[in]orderorder of the polynomial basis function
[in]n_fcmax. number of faces in a cell
a pointer to a new allocated cs_hho_builder_t structure
◆ cs_hho_builder_diffusion()
void cs_hho_builder_diffusion ( const cs_cell_mesh_t *  cm,
◆ cs_hho_builder_free()
void cs_hho_builder_free ( cs_hho_builder_t **  p_builder)
[in,out]p_builderpointer of pointer on a cs_hho_builder_t struct.
◆ cs_hho_builder_reduction_from_analytic()
void cs_hho_builder_reduction_from_analytic ( const cs_xdef_t *  def,
cs_real_t  t_eval,
cs_real_t  red[]
[in,out]redvector containing the reduction
◆ cs_hho_builder_reduction_from_analytic_v()
void cs_hho_builder_reduction_from_analytic_v ( const cs_xdef_t *  def,
cs_real_t  t_eval,
cs_real_t  red[]
