cs_field_pointer.cpp File Reference
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "base/cs_field.h"
#include "base/cs_mem.h"
+ Include dependency graph for cs_field_pointer.cpp:
void cs_field_pointer_ensure_init (void)
 Ensure field pointer array is initialized. More...
void cs_field_pointer_destroy_all (void)
 Free all field pointer data. More...
void cs_field_pointer_map (cs_field_pointer_id_t e, cs_field_t *f)
 Map a simple field to an enumerated pointer. More...
void cs_field_pointer_map_indexed (cs_field_pointer_id_t e, int index, cs_field_t *f)
 Map a field to an (enumerated pointer, index) couple. More...
void cs_field_pointer_map_base (void)
 Map base fields to enumerated pointers. More...
void cs_field_pointer_map_boundary (void)
 Map some boundary fields to enumerated pointers. More...
void cs_field_pointer_map_atmospheric (int n_chem_species, const int species_f_id[])
 Map base fields to enumerated pointers for atmospheric models. More...
struct cs_field_pointer_array_t * cs_glob_field_pointers = nullptr
Field pointers and ids for standard and model fields.
◆ cs_field_pointer_destroy_all()
void cs_field_pointer_destroy_all ( void  )
◆ cs_field_pointer_ensure_init()
void cs_field_pointer_ensure_init ( void  )
◆ cs_field_pointer_map()
void cs_field_pointer_map ( cs_field_pointer_id_t  e,
cs_field_t *  f
The associated field pointer may then be retreived using CS_F_(e).
[in]efield enumerator value
[in]fpointer to field structure
◆ cs_field_pointer_map_atmospheric()
void cs_field_pointer_map_atmospheric ( int  n_chem_species,
[in]n_chem_speciesnumber of chemical species
[in]species_f_idfield id for each chemical species
◆ cs_field_pointer_map_base()
void cs_field_pointer_map_base ( void  )
◆ cs_field_pointer_map_boundary()
void cs_field_pointer_map_boundary ( void  )
◆ cs_field_pointer_map_indexed()
void cs_field_pointer_map_indexed ( cs_field_pointer_id_t  e,
int  index,
cs_field_t *  f
This sort of mapping may be used for sets of fields whose size is not known in advance.
The associated field pointer may then be retreived using CS_FI_(e, i).
[in]indexfield enumerator index
◆ cs_glob_field_pointers
struct cs_field_pointer_array_t* cs_glob_field_pointers = nullptr
