cs_field_default.h File Reference
+ Include dependency graph for cs_field_default.h:
int cs_variable_cdo_field_create (const char *name, const char *label, int location_id, int dim, int has_previous)
 Add a field shared between CDO and legacy schemes. This field is related to a general solved variable, with default options. More...
int cs_variable_field_create (const char *name, const char *label, int location_id, int dim)
 Add field defining a general solved variable, with default options. More...
cs_equation_param_t * cs_field_get_equation_param (cs_field_t *f)
 Access a field's equation parameters. More...
const cs_equation_param_t * cs_field_get_equation_param_const (const cs_field_t *f)
 Access a field's equation parameters for read only. More...
cs_field_t * cs_field_get_variance (const cs_field_t *f)
 For a given field, returns field defined as its variance, if present. More...
void cs_field_map_and_init_bcs (void)
 Initialize all field BC coefficients. More...
int cs_field_n_scalar_fields (void)
 Return the number of defined scalar fields. More...
◆ cs_field_get_equation_param()
cs_equation_param_t * cs_field_get_equation_param ( cs_field_t *  f)
If the equation parameters were never initialized, they will be initialized based on the current defaults.
If the field does not have associated equation paremeters (i.e. is not a variable field or is a CDO field (which is referenced by but does not directly reference equations), nullptr is returned.
[in,out]fpointer to associated field
pointer to field's equation parameters, or nullptr
◆ cs_field_get_equation_param_const()
const cs_equation_param_t * cs_field_get_equation_param_const ( const cs_field_t *  f)
If the equation parameters were never initialized, the current default parameters will be returned instead.
If the field does not have associated equation parameters (i.e. is not a variable field or is a CDO field (which is referenced by but does not directly reference equations), nullptr is returned.
[in]fpointer to associated field
const-qualified pointer to field's equation parameters, or nullptr
◆ cs_field_get_variance()
cs_field_t * cs_field_get_variance ( const cs_field_t *  f)
[in]ffield
pointer to matching variance (variable) field, or nullptr.
◆ cs_field_map_and_init_bcs()
void cs_field_map_and_init_bcs ( void  )
◆ cs_field_n_scalar_fields()
int cs_field_n_scalar_fields ( void  )
number of legacy FV scalar variavble fields.
◆ cs_variable_cdo_field_create()
int cs_variable_cdo_field_create ( const char *  name,
const char *  label,
int  location_id,
int  dim,
int  has_previous
[in]namefield name
[in]labelfield default label, or empty
[in]location_idid of associated location
[in]dimfield dimension
[in]has_previousno if lower than 1
newly defined field id
◆ cs_variable_field_create()
int cs_variable_field_create ( const char *  name,
const char *  label,
int  location_id,
int  dim
[in]namefield name
