cs_ctwr.cpp File Reference
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "atmo/cs_air_props.h"
#include "atmo/cs_atmo.h"
#include "base/cs_base.h"
#include "base/cs_field.h"
#include "base/cs_log.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "mesh/cs_mesh.h"
#include "base/cs_parall.h"
#include "base/cs_post.h"
#include "base/cs_volume_zone.h"
#include "ctwr/cs_ctwr.h"
#include "ctwr/cs_ctwr_source_terms.h"
+ Include dependency graph for cs_ctwr.cpp:
cs_ctwr_option_t * cs_get_glob_ctwr_option (void)
cs_ctwr_zone_t ** cs_get_glob_ctwr_zone (void)
int * cs_get_glob_ctwr_n_zones (void)
void cs_ctwr_define (const char zone_criteria[], int z_id, cs_ctwr_zone_type_t zone_type, cs_real_t delta_t, cs_real_t relax, cs_real_t t_l_bc, cs_real_t q_l_bc, cs_real_t xap, cs_real_t xnp, cs_real_t surface, cs_real_t xleak_fac)
 Define a cooling tower exchange zone. More...
void cs_ctwr_define_zones (void)
 Define cooling tower zones. More...
void cs_ctwr_build_all (void)
 Define the cells belonging to the different packing zones. More...
void cs_ctwr_all_destroy (void)
 Destroy cs_ctwr_t structures. More...
void cs_ctwr_log_setup (void)
 Log Packing zone definition setup information. More...
void cs_ctwr_log_balance (void)
 Perform balances in packing zones. More...
◆ cs_ctwr_all_destroy()
void cs_ctwr_all_destroy ( void  )
◆ cs_ctwr_build_all()
void cs_ctwr_build_all ( void  )
◆ cs_ctwr_define()
void cs_ctwr_define ( const char  zone_criteria[],
int  z_id,
cs_real_t  delta_t,
cs_real_t  relax,
cs_real_t  t_l_bc,
cs_real_t  q_l_bc,
cs_real_t  xap,
cs_real_t  xnp,
cs_real_t  surface,
cs_real_t  xleak_fac
[in]zone_criteriazone selection criteria (or nullptr)
[in]z_idz_id if zone already created (-1 otherwise)
[in]zone_typeexchange zone type
[in]delta_timposed delta temperature delta between inlet and outlet of the zone
[in]relaxrelaxation of the imposed delta temperature
[in]t_l_bcliquid water temperature at the inlet
[in]q_l_bcmass flow rate at the inlet
[in]xapbeta_x_0 of the exchange law
[in]xnpexponent n of the exchange law
[in]surfacetotal Surface of ingoing water
[in]xleak_facleakage factor (ratio of outlet/inlet flow rate)
◆ cs_ctwr_define_zones()
void cs_ctwr_define_zones ( void  )
Define zones.
TODO rename this: definition (at setup stage) and build (instanciation on actual mesh are not the same).
◆ cs_ctwr_log_balance()
void cs_ctwr_log_balance ( void  )
◆ cs_ctwr_log_setup()
void cs_ctwr_log_setup ( void  )
◆ cs_get_glob_ctwr_n_zones()
int * cs_get_glob_ctwr_n_zones ( void  )
◆ cs_get_glob_ctwr_option()
cs_ctwr_option_t * cs_get_glob_ctwr_option ( void  )
◆ cs_get_glob_ctwr_zone()
cs_ctwr_zone_t ** cs_get_glob_ctwr_zone ( void  )
