cs_coal_boundary_conditions.h File Reference
#include "comb/cs_coal.h"
#include "base/cs_zone.h"
+ Include dependency graph for cs_coal_boundary_conditions.h:
Classes
struct  cs_coal_bc_inlet_t
 Inlet definition for pulverized coal combustion. More...
Typedefs
typedef struct _cs_coal_bc_inlet_state_t cs_coal_bc_inlet_state_t
 Inlet model state data. More...
cs_coal_bc_inlet_t * cs_coal_boundary_conditions_get_inlet (const cs_zone_t *zone)
 Return pointer to coal boundary conditions inlet structure. More...
void cs_coal_boundary_conditions_inlet_set_air_mass_flow_rate_by_value (const cs_zone_t *z, cs_real_t q)
 Assign a constant air mass flow rate to an inlet. More...
void cs_coal_boundary_conditions_inlet_set_air_mass_flow_rate_by_func (const cs_zone_t *z, cs_eval_at_location_t *func, void *input)
void cs_coal_boundary_conditions (int bc_type[])
 Automatic boundary condition for pulverized coal combustion. More...
void cs_coal_boundary_conditions_density (void)
 Compute density at inlets for pulverized coal combustion. More...
Typedef Documentation
◆ cs_coal_bc_inlet_state_t
◆ cs_coal_boundary_conditions()
void cs_coal_boundary_conditions ( int  bc_type[])
[in]bc_typetype of boundary for each face
◆ cs_coal_boundary_conditions_density()
void cs_coal_boundary_conditions_density ( void  )
This is based on boundary condition definitions, but is called at an earlier stage in the time step.
◆ cs_coal_boundary_conditions_get_inlet()
cs_coal_bc_inlet_t * cs_coal_boundary_conditions_get_inlet ( const cs_zone_t *  zone)
If no such structure was previously present, it is created and linked to the matching open boundary condition inlet.
[in]zonepointer to associated zone
: pointer to structure associated with zone
◆ cs_coal_boundary_conditions_inlet_set_air_mass_flow_rate_by_func()
void cs_coal_boundary_conditions_inlet_set_air_mass_flow_rate_by_func ( const cs_zone_t *  z,
cs_eval_at_location_t *  func,
void *  input
◆ cs_coal_boundary_conditions_inlet_set_air_mass_flow_rate_by_value()
void cs_coal_boundary_conditions_inlet_set_air_mass_flow_rate_by_value ( const cs_zone_t *  z,
cs_real_t  q
The total mass flow rate will also include that of the pulverized coals.
This is otherwise similar to cs_boundary_conditions_open_set_mass_flow_rate_by_value.
[in]zpointer to associated zone
[in]qassociated constant mass flow rate
