cs_function.h File Reference
+ Include dependency graph for cs_function.h:
Classes
struct  cs_function_t
Macros
#define CS_FUNCTION_INTENSIVE   (1 << 0)
#define CS_FUNCTION_EXTENSIVE   (1 << 1)
#define CS_FUNCTION_TIME_INDEPENDENT   (1 << 2)
#define CS_FUNCTION_USER   (1 << 3)
#define CS_FUNCTION_NO_MPI_CALL   (1 << 4)
#define CS_FUNCTION_NO_SUB_TASK   (1 << 5)
Typedefs
typedef void() cs_eval_at_location_t(int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals)
 Function pointer for evaluation of local function values. More...
cs_function_t * cs_function_define_by_func (const char *name, int location_id, int dim, bool is_intensive, cs_datatype_t datatype, cs_eval_at_location_t *data_func, void *data_input)
 Define a function whose data values will be computed using the provided evaluation function. More...
cs_function_t * cs_function_define_by_analytic_func (const char *name, int location_id, int dim, bool is_intensive, cs_analytic_func_t *data_func, void *data_input)
 Define a function whose data values will be computed using the provided "degree of freedom" type evaluation function. More...
cs_function_t * cs_function_define_by_dof_func (const char *name, int location_id, int dim, bool is_intensive, cs_dof_func_t *data_func, void *data_input)
void cs_function_destroy_all (void)
 Destroy all functions management metadata. More...
int cs_function_n_functions (void)
 Return the number of defined functions. More...
cs_function_t * cs_function_by_id (int id)
 Return a pointer to a function object based on its id. More...
cs_function_t * cs_function_by_name (const char *name)
 Return a pointer to a function object based on its name. More...
cs_function_t * cs_function_by_name_try (const char *name)
 Return a pointer to a function object based on its name if present. More...
void cs_function_set_label (cs_function_t *f, const char *label)
 Assig a label to a function object. More...
void cs_function_log_defs (void)
 Log function definition setup information. More...
void cs_function_log_all_settings (void)
 Print info relative to all given function object settings to log file. More...
void cs_function_evaluate (const cs_function_t *f, const cs_time_step_t *ts, int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *vals)
 Evaluate function values. More...
Typedef Documentation
◆ cs_eval_at_location_t
If the matching values are multidimensional, they must be interleaved. The output values are assumed to use a dense storage (i.e. of size n_elts *
for the associated data type, in the same order as elt_ids if present.)
Note: if the input pointer is non-null, it must point to valid data when the selection function is called, so either:
  • that value or structure should not be temporary (i.e. local);
  • when a single integer identifier is needed, the input pointer can be set to that value instead of an actual address;
[in]location_idbase associated mesh location id
[in]n_eltsnumber of associated elements
[in]elt_idsids of associated elements, or NULL if no filtering is required
[in,out]inputpointer to optional (untyped) value or structure.
[in,out]valspointer to output values (size: n_elts*dimension)
◆ cs_function_by_id()
cs_function_t * cs_function_by_id ( int  id)
This function requires that a function of the given id is defined.
[in]idfunction id
pointer to the function structure
◆ cs_function_by_name()
cs_function_t * cs_function_by_name ( const char *  name)
This function requires that a function of the given name is defined.
[in]namefunction name
◆ cs_function_by_name_try()
cs_function_t * cs_function_by_name_try ( const char *  name)
If no function of the given name is defined, nullptr is returned.
pointer to the function structure, or NULL
pointer to the function structure, or nullptr
◆ cs_function_define_by_analytic_func()
cs_function_t * cs_function_define_by_analytic_func ( const char *  name,
int  location_id,
int  dim,
bool  is_intensive,
cs_analytic_func_t *  data_func,
void *  data_input
The provided function and optional associated input is of the same form as and may be shared with some boundary condition or property definitions.
[in]namename of associated function
[in]location_idid of associated mesh location
[in]dimdimension associated with element data
[in]is_intensiveis the function intensive?
[in]data_funcfunction used to define data values
[in]data_inputpointer to optional (untyped) value or structure to be used by data_func
pointer to the associated function object in case of success, or NULL in case of error
pointer to the associated function object in case of success, or nullptr in case of error
◆ cs_function_define_by_dof_func()
cs_function_t * cs_function_define_by_dof_func ( const char *  name,
int  location_id,
int  dim,
bool  is_intensive,
cs_dof_func_t *  data_func,
void *  data_input
◆ cs_function_define_by_func()
cs_function_t * cs_function_define_by_func ( const char *  name,
int  location_id,
int  dim,
bool  is_intensive,
cs_eval_at_location_t *  data_func,
void *  data_input
If of dimension > 1, the evaluated values are always interleaved.
[in]datatypeassociated data values type
◆ cs_function_destroy_all()
void cs_function_destroy_all ( void  )
◆ cs_function_evaluate()
void cs_function_evaluate ( const cs_function_t *  f,
const cs_time_step_t *  ts,
int  location_id,
cs_lnum_t  n_elts,
const cs_lnum_t *  elt_ids,
void *  vals
[in]fpointer to associated function handle
[in]elt_idsids of associated elements, or nullptr if no filtering is required
◆ cs_function_log_all_settings()
void cs_function_log_all_settings ( void  )
◆ cs_function_log_defs()
void cs_function_log_defs ( void  )
◆ cs_function_n_functions()
int cs_function_n_functions ( void  )
◆ cs_function_set_label()
void cs_function_set_label ( cs_function_t *  f,
const char *  label
[in,out]fpointer to associated function handle
[in]labelassociated label
