cs_cdofb_predco.cpp File Reference
Build an algebraic CDO face-based system for the Navier-Stokes equations and solved it with a prediction/correction algorithm. A first equation related to the velocity prediction is solved and then a second equation related to the pressure correction is solved to project the velocity field into the space of divergence-free field. More...
#include <float.h>
#include "base/cs_mem.h"
#include "base/cs_array.h"
#include "alge/cs_blas.h"
#include "cdo/cs_cdo_assembly.h"
#include "cdo/cs_cdo_bc.h"
#include "cdo/cs_cdo_solve.h"
#include "cdo/cs_cdofb_priv.h"
#include "cdo/cs_cdofb_scaleq.h"
#include "cdo/cs_cdofb_vecteq.h"
#include "cdo/cs_cdofb_navsto.h"
#include "cdo/cs_evaluate.h"
#include "base/cs_log.h"
#include "base/cs_math.h"
#include "base/cs_post.h"
#include "cdo/cs_reco.h"
#include "cdo/cs_static_condensation.h"
#include "base/cs_timer.h"
#include "cdo/cs_cdofb_predco.h"
+ Include dependency graph for cs_cdofb_predco.cpp:
void cs_cdofb_predco_init_common (const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
void * cs_cdofb_predco_init_scheme_context (const cs_navsto_param_t *nsp, cs_adv_field_t *adv_field, cs_real_t *mflux, cs_real_t *mflux_pre, cs_boundary_type_t *fb_type, void *nsc_input)
 Initialize a cs_cdofb_predco_t structure. More...
void * cs_cdofb_predco_free_scheme_context (void *scheme_context)
 Destroy a cs_cdofb_predco_t structure. More...
void cs_cdofb_predco_compute_implicit (const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
 Solve the unsteady Navier-Stokes system with a CDO face-based scheme using a prediction/correction approach and an implicit Euler time scheme. More...
◆ cs_cdofb_predco_compute_implicit()
void cs_cdofb_predco_compute_implicit ( const cs_mesh_t *  mesh,
const cs_navsto_param_t *  nsp,
void *  scheme_context
Solve the unsteady Navier-Stokes system with a CDO face-based scheme using a Artificial Compressibility approach and an Euler time scheme.
[in,out]scheme_contextpointer to a structure cast on-the-fly
◆ cs_cdofb_predco_free_scheme_context()
void * cs_cdofb_predco_free_scheme_context ( void *  scheme_context)
[in]scheme_contextpointer to a scheme context structure to free
a null pointer
◆ cs_cdofb_predco_init_common()
void cs_cdofb_predco_init_common ( const cs_cdo_quantities_t *  quant,
◆ cs_cdofb_predco_init_scheme_context()
void * cs_cdofb_predco_init_scheme_context ( const cs_navsto_param_t *  nsp,
cs_adv_field_t *  adv_field,
cs_real_t *  mflux,
cs_real_t *  mflux_pre,
cs_boundary_type_t *  fb_type,
void *  nsc_input
[in]mfluxcurrent values of the mass flux across primal faces
[in]mflux_preprevious values of the mass flux across primal faces
[in]fb_typetype of boundary for each boundary face
[in]nsc_inputpointer to a cs_navsto_projection_t structure
a pointer to a new allocated cs_cdofb_predco_t structure
