cs_cdocb_scaleq_sles.cpp File Reference
Functions dedicated to to the linear algebra settings and operations in case of CDO cell-based schemes with a scalar-valued equations. More...
#include "base/cs_mem.h"
#include "base/cs_array.h"
#include "alge/cs_blas.h"
#include "cdo/cs_cdo_blas.h"
#include "cdo/cs_cdo_solve.h"
#include "cdo/cs_equation.h"
#include "cdo/cs_cdocb_scaleq.h"
#include "base/cs_fp_exception.h"
#include "alge/cs_matrix_default.h"
#include "base/cs_parall.h"
#include "alge/cs_saddle_solver.h"
#include "cdo/cs_saddle_system.h"
#include "base/cs_timer.h"
#include "cdo/cs_cdocb_scaleq_sles.h"
+ Include dependency graph for cs_cdocb_scaleq_sles.cpp:
void cs_cdocb_scaleq_sles_init_sharing (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant)
 Set pointers to shared structures. More...
void cs_cdocb_scaleq_sles_init_system_helper (const cs_param_saddle_t *saddlep, cs_cdocb_scaleq_t *eqc)
 Define the system helper for a CDO-Cb scheme solving a scalar-valued equation (saddle-point system) More...
void cs_cdocb_scaleq_sles_init_solver (const cs_equation_param_t *eqp, const cs_param_saddle_t *saddlep, cs_cdocb_scaleq_t *eqc)
 Define the saddle solver and its context for a CDO-Cb scheme solving a scalar-valued equation (saddle-point problem) More...
int cs_cdocb_scaleq_sles_alu (cs_saddle_solver_t *solver, cs_real_t *flux, cs_real_t *pot)
 Solve a linear system arising from the discretization of a scalar-valed equation stemming from CDO cell-based schemes. Solve the saddle-point system using the Augmented Lagrangian-Uzawa algorithm. More...
int cs_cdocb_scaleq_sles_block_krylov (cs_saddle_solver_t *solver, cs_real_t *flux, cs_real_t *pot)
 Solve a linear system arising from the discretization of a scalar-valed equation stemming from CDO cell-based schemes. The system is split into a flux block and the (unassembled) divergence operator. Block preconditioning using a Schur approximation on a Krylov solver such as the GCR or MINRES is available. More...
int cs_cdocb_scaleq_sles_full_system (cs_saddle_solver_t *solver, cs_real_t *flux, cs_real_t *pot)
 Solve the saddle-point linear system arising from the discretization of the scalar-valued CDO cell-based scheme. The full system is treated as one block and solved as it is. In this situation, PETSc or MUMPS are usually considered. More...
int cs_cdocb_scaleq_sles_gkb_inhouse (cs_saddle_solver_t *solver, cs_real_t *flux, cs_real_t *pot)
 Solve a linear system arising from the discretization of a scalar-valed equation stemming from CDO cell-based schemes. Solve this system using the Golub-Kahan Bidiagonalization algorithm. In-house implementation. The PETSc implementation is also available but appears less efficient in our tests. More...
int cs_cdocb_scaleq_sles_notay (cs_saddle_solver_t *solver, cs_real_t *flux, cs_real_t *pot)
 Solve a linear system arising from the discretization of a scalar-valed equation stemming from CDO cell-based schemes. Solve this system using the Notay's algebraic transformation. The full system is treated as one block and solved as it is. In this situation, PETSc or MUMPS are usually considered. More...
int cs_cdocb_scaleq_sles_uzawa_cg (cs_saddle_solver_t *solver, cs_real_t *flux, cs_real_t *pot)
 Solve a linear system arising from the discretization of a scalar-valed equation stemming from CDO cell-based schemes. Solve this system using the Uzawa-CG algorithm. More...
◆ cs_cdocb_scaleq_sles_alu()
int cs_cdocb_scaleq_sles_alu ( cs_saddle_solver_t *  solver,
cs_real_t *  flux,
cs_real_t *  pot
[in,out]solverpointer to a cs_saddle_solver_t structure
[in,out]fluxvalues of the flux at faces (scalar)
[in,out]potvalues of the potential in cells
the (cumulated) number of iterations of the solver
◆ cs_cdocb_scaleq_sles_block_krylov()
int cs_cdocb_scaleq_sles_block_krylov ( cs_saddle_solver_t *  solver,
cs_real_t *  flux,
cs_real_t *  pot
◆ cs_cdocb_scaleq_sles_full_system()
int cs_cdocb_scaleq_sles_full_system ( cs_saddle_solver_t *  solver,
cs_real_t *  flux,
cs_real_t *  pot
[in,out]solverpointer to a saddle-point solver
◆ cs_cdocb_scaleq_sles_gkb_inhouse()
int cs_cdocb_scaleq_sles_gkb_inhouse ( cs_saddle_solver_t *  solver,
cs_real_t *  flux,
cs_real_t *  pot
◆ cs_cdocb_scaleq_sles_init_sharing()
void cs_cdocb_scaleq_sles_init_sharing ( const cs_mesh_t *  mesh,
const cs_cdo_quantities_t *  quant
[in]meshpointer to the mesh structure
[in]connectpointer to additional CDO connectivities
[in]quantpointer to additional CDO mesh quantities
◆ cs_cdocb_scaleq_sles_init_solver()
void cs_cdocb_scaleq_sles_init_solver ( const cs_equation_param_t *  eqp,
const cs_param_saddle_t *  saddlep,
cs_cdocb_scaleq_t *  eqc
[in]eqpset of equation parameters
[in]saddlepparameters for solving a saddle-point problem
[in,out]eqcpointer to a context structure cast on-the-fly
◆ cs_cdocb_scaleq_sles_init_system_helper()
void cs_cdocb_scaleq_sles_init_system_helper ( const cs_param_saddle_t *  saddlep,
◆ cs_cdocb_scaleq_sles_notay()
int cs_cdocb_scaleq_sles_notay ( cs_saddle_solver_t *  solver,
cs_real_t *  flux,
cs_real_t *  pot
◆ cs_cdocb_scaleq_sles_uzawa_cg()
int cs_cdocb_scaleq_sles_uzawa_cg ( cs_saddle_solver_t *  solver,
cs_real_t *  flux,
cs_real_t *  pot
