bft_printf.cpp File Reference
#include <stdarg.h>
#include "bft/bft_printf.h"
+ Include dependency graph for bft_printf.cpp:
int bft_printf (const char *const format,...)
 Replacement for printf() with modifiable behavior. More...
int bft_printf_flush (void)
 Flush for output of bft_printf() with modifiable behavior. More...
bft_printf_proxy_t * bft_printf_proxy_get (void)
 Returns function associated with the bft_printf() function. More...
void bft_printf_proxy_set (bft_printf_proxy_t *const fct)
 Associates a vprintf() type function with the bft_printf() function. More...
bft_printf_flush_proxy_t * bft_printf_flush_proxy_get (void)
 Returns function associated with bft_printf_flush(). More...
void bft_printf_flush_proxy_set (bft_printf_flush_proxy_t *const fct)
 Associates a proxy function with bft_printf_flush(). More...
◆ bft_printf()
int bft_printf ( const char *const  format,
This function calls vprintf() by default, or a function with similar arguments indicated by bft_printf_proxy_set().
[in]formatformat string, as printf() and family.
[in]...variable arguments based on format string.
number of characters printed, not counting the trailing '\0' used to end output strings
◆ bft_printf_flush()
int bft_printf_flush ( void  )
This function calls fflush(stdout) if bft_printf()'s default behavior is used. If bft_printf's behavior is modified with bft_printf_proxy_set(), bft_printf_flush()'s behavior may have to be also adjusted with bft_printf_flush_proxy_set().
using the default behavior, the return value is that of fflush(stdout): O upon successful completion, EOF otherwise (with errno set to indicate the error).
◆ bft_printf_flush_proxy_get()
bft_printf_flush_proxy_t * bft_printf_flush_proxy_get ( void  )
pointer to the bft_printf_flush() proxy.
◆ bft_printf_flush_proxy_set()
void bft_printf_flush_proxy_set ( bft_printf_flush_proxy_t *const  fct)
Warning
bft_printf() is called by the default bft_error() error handler (so as to ensure that the error text appears at the end of the program output), so a bft_print_flush replacement must not itself call (directly or indirectly) bft_error() if the default error handler is used.
[in]fctpointer to a function similar to {return fflush(stdout)}.
◆ bft_printf_proxy_get()
bft_printf_proxy_t * bft_printf_proxy_get ( void  )
pointer to the vprintf() or replacement function.
◆ bft_printf_proxy_set()
void bft_printf_proxy_set ( bft_printf_proxy_t *const  fct)
[in]fctpointer to a vprintf() type function.
