bft_error.cpp File Reference
#include <stdarg.h>
#include "bft/bft_printf.h"
#include "bft/bft_error.h"
+ Include dependency graph for bft_error.cpp:
void bft_error (const char *const file_name, const int line_num, const int sys_error_code, const char *const format,...)
 Calls the error handler (set by bft_error_handler_set() or default). More...
bft_error_handler_t * bft_error_handler_get (void)
 Returns the error handler associated with the bft_error() function. More...
void bft_error_handler_set (bft_error_handler_t *const handler)
 Associates an error handler with the bft_error() function. More...
◆ bft_error()
void bft_error ( const char *const  file_name,
const int  line_num,
With the default error handler, bft_print_flush() is called, an error message is output to stderr, and the current process exits with an EXIT_FAILURE code.
[in]file_namename of source file from which error handler called.
[in]line_numline of source file from which error handler called.
[in]sys_error_codeerror code if error in system or libc call, 0 otherwise.
[in]formatformat string, as printf() and family.
[in]...variable arguments based on format string.
◆ bft_error_handler_get()
bft_error_handler_t * bft_error_handler_get ( void  )
pointer to the error handler function.
◆ bft_error_handler_set()
void bft_error_handler_set ( bft_error_handler_t *const  handler)
[in]handlerpointer to the error handler function.
