What if I can't access Code-Saturne ?
Brother PE800 Sewing And Embroidery Machine Reviews
If you are willing to take your sewing game to another level, then it’s time to move on to the embroidery machine to polish skills. To take your first step, you can start by buying a good sewing machine for beginners
and get yourself in practice constantly. Today we are discussing Brother PE800 embroidery machine to bring professionalism in your work as a home sewer.
Built-in Embroidery Designs:
This machine has come up with 138 built-in embroidery designs along with 11 lettering fonts and border designs to add a fancy look to your work. Other than these 138 embroidery designs, you can also connect this machine to the computer and transfer as many designs as you want to add an embellishment or any fancy touch. You can store transferred designs permanently in this machine.
Color LCD Touch Screen:
Brother SE800 embroidery machine has come up with a large LCD touch screen which will help you in previewing embroidery designs on screen before you copy that to the fabric. You can make necessary changes in the design as well as thread color by built-in thread palette, mirror image, rotation and minor changes in design as well.
Embroidery Area:
This model is just not allowing doing embroidery with complete freedom but it is also providing you an embroidery area for comfortable working. If you are willing to decorate a bigger project like home décor or some shirt then it has enough embroidery area to help you. You will be provided a 5x7” area to create a design neatly and professionally.
Bobbin Thread Supply:
If your best entry level sewing machine
doesn’t have an embroidery feature then Brother PE800 is providing you everything you were looking for. In case, while working on the major projects, if you are running out of the thread then the message will get flash on the LCD screen. This is a useful feature for beginners as they can immediately change the bobbin without delaying work for a long time.
Stitching Speed and Needle Threading:
The stitching speed of this machine is quite impressive which is 650 stitches per minute so if you are working on the small design as a beginner then you can complete in 30 minutes. When it comes to the needle threading system then this sewing machine has advanced needle threader. It’s not difficult anymore for anyone to push the thread to the needle’s eye.
Bobbin Winding:
The bobbin winding system in Brother PE800 is exceptional and easy to use for beginners. This system has come up with the clear cover so you can always keep an eye on the thread supply as well as it will take a few seconds to replace bobbin with another one. You just have to set up the machine and start working on your first project.
Conclusion:
Along with the embroidery machine, you should also work on the
coverstitch sewing machine to secure every stitch inside the garment. Brother PE800 embroidery machine has all the advanced features as well as exceptional performances for all the beginners and intermediate sewers.
Please follow the forum usage recommendations so as to provide exploitable information.
