I’m facing a weird issue as i’m trying to run a restarted calculation, setting up the restart folder in the cs_user_scripts.py file. Every time i try to run the simulation, it immediately ends with the error:
Premature end of file "restart/main.csc"
When checking the reference simulation from where the “wrong” checkpoint has been taken i see at the end of the listing file:
Write final restart files
checkpoint at iteration 7401, Physical time 0.37005E-01
** Writing the main restart file
Start writing
Wrote field names and types to checkpoint at iteration 7401: checkpoint/main.csc
End writing the options
Wrote main variables to checkpoint: checkpoint/main.csc
End writing
** Writing the auxiliary restart file
Start writing
End writing the dimensions and options
End writing the physical properties
End writing the time step
Wrote boundary condition coefficients to checkpoint: checkpoint/auxiliary.csc
End writing the source terms
End writing combustion information (COD3P)
End writing
** Information on the radiative module
Writing a restart file
Write start
End of output for dimensions
End of output for data
End of output to restart file
So i don’t really get where the error could be, considering that until that moment i was restarting some other simulations correctly (i’m running on a cluster, so to avoid allocation time problems, every once in a while the simulation is stopped and then restarted using the previously saved checkpoint).
Any idea on how to fix it?
Thanks in advance,
Francesco
