The install of code_saturne 2.0.2 is ok, but when we did a check-mesh on a mesh file we have an error :
/usr/local/bin/cs_preprocess: error while loading shared libraries: libhdf5.so.0: cannot open shared object file: No such file or directory
We don’t understand this error because the library libhdf5.so.0 exists but not in the directory /usr/local/bin.
Besides, cs_preprocess is not install in this directory. Where can we change this link ?
In which directory is the code installed ? Do you have multiple installs (or traces from previous failed install attempts) ?
Did you use the installer or a manual install ?
I use CAELinux and the version 2.0.1 of code_saturne was already installed and it use python and hdf5 of salome.
I resolve the problem installing the new version of HDF5 and now all is ok.
Thank you
Romain
To solve the problem such as
./cs_solver: error while loading shared libraries: libhdf5.so.103: cannot open shared object file: No such file or directory,
we have to run
export LD_LIBRARY_PATH=“/usr/local/lib:$LD_LIBRARY_PATH”,
before lunching code saturne.
Yes, I understand that, also from the other threads on this forum. My question was related to which version of the code you are using, since you are posting on an old thread related to code_saturne 2.0. It is better to only use the more current threads, to avoid confusing everyone.
I will probably end up deleting the recent messages on this thread, since they are redundant with other threads, and only add confusion.
