CS & PGI compiler
I’ve failed to add compiler flags( the standard CFLAGS=“-ta=tesla:managed”) three times for using PGI Unified BinaryTM technology(like CUDA unified memory).
(1) Using the low-level installer of course.
(2) Using the automatic installer.(revise and re-run the configure options from the top of the config.log file)
(3) Modify config/cs_auto_flags.sh in the code sources ( I delete all compiler types other than pgcc. after all, I revise conditional statements to simple statements)
I put 2 log in attachment. I want to know the technology to see if it works. (I just want to use unified memory of SpMV products)
best regards,
Jackie
error2.log (103 KB)
error1.log (902 KB)
You can also use the --disable-auto-flags configure option followed by you choice of CFLAGS, … for quicker tests.
In any case, what seems to be missing is a Fortran compiler option to use the C preprocessor to handle #define options and such. For versions of the PGI compilers we used some years ago, it was “-Mpreprocess”, so I recommend testing if last option is still valid by adding it tou your “FCFLAGS” options.
Thank you Yvan for the question.
If I want to get the PGI Compiler Feedback, which file and location should I look for?
best
Jackie
I’m not sure I understand you question. You can edit config/cs_auto_flags.sh to edit the default PGI compiler flags (search for PGI in that file) before running “configure”, but otherwise, you need to redirect the output of “make” to a file and check that.
Thanks a lot!
I’ve already edited config/cs_auto_flags.sh to edit the default PGI compiler flags, including “added to $CFLAGS for profiling”. So I want to get the information about PGI Compiler Feedback after compiling “the Code”.
best regards,
Jackie
I have not used a PGI compiler for quite a few years, so I can’t help you here. You’ll probably need to look at the PGI compiler documentation.
