8.3
cs_rad_transfer_params_t Struct Reference
Structure containing the radiation module parameters. More...
#include <cs_rad_transfer.h>
+ Collaboration diagram for cs_rad_transfer_params_t:
Data Fields
cs_rad_transfer_model_t type
int nrphas
int iimpar
int verbosity
int imodak
int imoadf
int iwrp1t
int imfsck
double xnp1mx
int idiver
int i_quadrature
int ndirec
int ndirs
cs_real_3_tvect_s
cs_real_tangsol
int restart
int nwsgg
cs_real_twq
int itpimp
int ipgrno
int iprefl
int ifgrno
int ifrefl
int itpt1d
int ifinfe
int atmo_model
int atmo_dr_id
int atmo_dr_o3_id
int atmo_df_id
int atmo_df_o3_id
int atmo_ir_id
bool dispersion
cs_real_t dispersion_coeff
cs_time_control_t time_control
Field Documentation
◆ angsol
angsol
Weight of the solid angle.
◆ atmo_df_id
int atmo_df_id
Atmospheric radiation model: id of the Diffuse Solar band or -1 if not activated (automatically computed)
◆ atmo_df_o3_id
int atmo_df_o3_id
Atmospheric radiation model: id of the Diffuse Solar O3 band (SUV) or -1 if not activated (automatically computed)
◆ atmo_dr_id
int atmo_dr_id
Atmospheric radiation model: id of the Direct Solar band or -1 if not activated (automatically computed)
◆ atmo_dr_o3_id
int atmo_dr_o3_id
Atmospheric radiation model: id of the Direct Solar O3 band or -1 if not activated (automatically computed)
◆ atmo_ir_id
int atmo_ir_id
Atmospheric radiation model: id of the InfraRed band or -1 if not activated (automatically computed)
◆ atmo_model
int atmo_model
  • Direct Solar the first bit
  • diFfuse Solar for the second bit
  • InfraRed for the third bit
◆ dispersion
bool dispersion
add dispersion (through diffusion)
◆ dispersion_coeff
dispersion coefficient. The dispersion coefficient leading to the best precision may depend on the chosen quadrature, and has been observed to be 3 for 128 directions (T4) and 5 for 32 directions (T2) on a (cube with point source) test case; the default value of 1 already improves precision in both cases.
◆ i_quadrature
i_quadrature
Index of the quadrature and number of directions for a single octant.
Sn quadrature (n(n+2) directions)
  • 1: S4 (24 directions)
  • 2: S6 (48 directions)
  • 3: S8 (80 directions)
    Tn quadrature (8n^2 directions)
  • 4: T2 (32 directions)
  • 5: T4 (128 directions)
  • 6: Tn (8*ndirec^2 directions)
  • 7: 120 directions (LC11)
  • 8: 48 directions (DCT020-2468)
◆ idiver
idiver
Explicit radiative source term computation mode -1: no renormalization 0: Semi-analytic (mandatory if transparent) 1: Conservative 2: Corrected semi-analytic (to be conservative) REMARK: if transparent, idiver = -1 automatically in DOM
Indicates the method used to calculate the radiative source term:
  • -1: no renormalization
  • 0: semi-analytic calculation (compulsory with transparent media)
  • 1: conservative calculation
  • 2: semi-analytic calculation corrected in order to be globally conservative
◆ ifgrno
ifgrno
Deprecated:
See CS_BOUNDARY_RAD_WALL_GRAY_COND_FLUX.
◆ ifinfe
ifinfe
Modeling of an infinite extrusion for open boundaries.
◆ ifrefl
ifrefl
Deprecated:
see CS_BOUNDARY_RAD_WALL_REFL_COND_FLUX.
◆ iimpar
iimpar
Verbosity level in the log concerning the calculation of the wall temperatures:
  • 0: no display
  • 1: standard
  • 2: complete
◆ imfsck
imfsck
FSCK model (0: off, 1: on)
FSCK model:
  • 0 no FSCK model
  • 1 FSCK model activated
◆ imoadf
imoadf
ADF model: 0: not used 1: with wavelength interval of a 8 2: with wavelength interval of a 50
ADF model:
  • 0 no ADF model
  • 1 ADF model with 8 intervals of wave length
  • 2 ADF model with 50 intervals of wave length
◆ imodak
imodak
Absorption coefficient computation 0: without modak 1: with modak
When gas or coal combustion is activated, imodak indicates whether the absorption coefficient shall be calculated "automatically" (=1) or read from the data file (=0).
◆ ipgrno
ipgrno
Deprecated:
See CS_BOUNDARY_RAD_WALL_GRAY_EXTERIOR_T.
◆ iprefl
iprefl
Deprecated:
See CS_BOUNDARY_RAD_WALL_REFL_EXTERIOR_T.
◆ itpimp
itpimp
Deprecated:
See CS_BOUNDARY_RAD_WALL_GRAY.
◆ itpt1d
itpt1d
See CS_BOUNDARY_RAD_WALL_GRAY_1D_T
◆ iwrp1t
iwrp1t
P1 model transparency warnings counter.
◆ ndirec
ndirec
Number of directions for the angular discretisation of the radiation propagation with the DOM model.
No other possible value, because of the way the directions are calculated.
The calculation with 32 directions may break the symmetry of physically axi-symmetric cases (but the cost in CPU time is much lower than with 128 directions).
Useful if and only if the radiation module is activated with the DOM method.
◆ ndirs
ndirs
For the Tn quadrature, ndirec squared
◆ nrphas
nrphas
Phase which radiates (bulk by default, but may be coal class or fuel droplets phase).
◆ nwsgg
nwsgg
Spectral radiation models (ADF and FSCK).
Number of ETRs to solve.
◆ restart
restart
Indicates whether the radiation variables should be initialized or read from a restart file.
◆ time_control
time_control
Determines at which time steps the variables are updated Also, in order to have proper initialization of the variables, the radiation module should always be called at the first time step of a calculation (restart or not).
◆ type
model activation and type
◆ vect_s
vect_s
Direction vectors of angular values of the quadrature sx, sy, sz.
◆ verbosity
verbosity
Radiance resolution verbosity
Verbosity level in the log concerning the calculation of the radiative transfer equation:
  • 0: no display
  • 1: standard
  • 2: complete
◆ wq
wq
Weights of the Gaussian quadrature
◆ xnp1mx
xnp1mx
For the P-1 model, percentage of cells for which we allow the optical thickness to exceed unity, although this should be avoided. (more precisely, where $ KL $ is lower than 1, where $ K $ is the absorption coefficient of the medium and $ L $ is a characteristic length of the domain).
