#include <errno.h>
#include <locale.h>
#include <float.h>
#include "cs_blas.h"
#include "cs_boundary.h"
#include "cs_equation.h"
#include "cs_math.h"
#include "cs_mesh_location.h"
#include "cs_post.h"
#include "cs_reco.h"
#include "cs_walldistance.h"
Macros | |
#define | _dp3 cs_math_3_dot_product |
#define | CS_WALLDISTANCE_DBG 0 |
static void | _compute_poisson_cdovcb (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_field_t *field, const cs_equation_t *eq, cs_real_t dist[]) |
Compute the wall distance for a vertex+cell-based scheme Estimation based on a Poisson equation. More... | |
static void | _compute_poisson_cdovb (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_field_t *field, cs_real_t dist[]) |
Compute the wall distance for a vertex-based scheme Estimation based on a Poisson equation. More... | |
static void | _compute_poisson_cdofb (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_equation_t *eq, const cs_field_t *field, cs_real_t dist[]) |
Compute the wall distance for a face-based scheme Estimation based on a Poisson equation. More... | |
bool | cs_walldistance_is_activated (void) |
Test if the computation of the wall distance is activated. More... | |
void | cs_walldistance_activate (void) |
Activate the future computation of the wall distance. More... | |
void | cs_walldistance_setup (void) |
Setup the equation related to the wall distance. More... | |
void | cs_walldistance_compute (const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq) |
Compute the wall distance. More... | |
static cs_equation_t * | cs_wd_poisson_eq = nullptr |
#define _dp3 cs_math_3_dot_product |
#define CS_WALLDISTANCE_DBG 0 |
static |
[in] | connect | pointer to a cs_cdo_connect_t structure |
[in] | cdoq | pointer to a cs_cdo_quantities_t structure |
[in] | eq | pointer to the associated cs_equation_t structure |
[in] | field | pointer to a cs_field_t structure |
[in,out] | dist | array storing the wall distance to compute |
static |
static |
[in] | eq | pointer to the related cs_equation_t structure |
void cs_walldistance_activate | ( | void | ) |
void cs_walldistance_compute | ( | const cs_mesh_t * | mesh, |
const cs_time_step_t * | time_step, | ||
const cs_cdo_connect_t * | connect, | ||
const cs_cdo_quantities_t * | cdoq | ||
[in] | mesh | pointer to a cs_mesh_t structure |
[in] | time_step | pointer to a cs_time_step_t structure |
bool cs_walldistance_is_activated | ( | void | ) |
void cs_walldistance_setup | ( | void | ) |
static |
