◆ CS_COMBUSTION_COAL_MAX_ATOMIC_SPECIES
#define CS_COMBUSTION_COAL_MAX_ATOMIC_SPECIES 5 |
Maximum number of atomic species
◆ CS_COMBUSTION_COAL_MAX_CLASSES
#define CS_COMBUSTION_COAL_MAX_CLASSES |
Value:
#define CS_COMBUSTION_MAX_CLASSES_PER_COAL
Definition: cs_coal.h:62
#define CS_COMBUSTION_MAX_COALS
Definition: cs_coal.h:50
Maximum total number of coal classes
◆ CS_COMBUSTION_COAL_MAX_ELEMENTARY_COMPONENTS
#define CS_COMBUSTION_COAL_MAX_ELEMENTARY_COMPONENTS 20 |
Maximum number of elementary gas components
◆ CS_COMBUSTION_COAL_MAX_GLOBAL_SPECIES
#define CS_COMBUSTION_COAL_MAX_GLOBAL_SPECIES 25 |
Maximum number of global species
◆ CS_COMBUSTION_COAL_MAX_OXYDANTS
#define CS_COMBUSTION_COAL_MAX_OXYDANTS 3 |
Maximum number of oxydants
◆ CS_COMBUSTION_COAL_MAX_SOLIDS
Maximum number of solid constituants
◆ CS_COMBUSTION_COAL_MAX_TABULATION_POINTS
#define CS_COMBUSTION_COAL_MAX_TABULATION_POINTS 8 |
Maximum number of tabulation points
◆ CS_COMBUSTION_MAX_CLASSES_PER_COAL
#define CS_COMBUSTION_MAX_CLASSES_PER_COAL 20 |
Maximum number of coal classes per coal
◆ CS_COMBUSTION_MAX_COALS
#define CS_COMBUSTION_MAX_COALS 5 |
◆ cs_coal_model_type_t
Coal combustion model type
Enumerator |
CS_COMBUSTION_COAL_NONE | |
CS_COMBUSTION_COAL_STANDARD | |
CS_COMBUSTION_COAL_WITH_DRYING | |
◆ cs_coal_mass_transfer()
void cs_coal_mass_transfer |
void |
◆ cs_coal_model_get_type()
Return coal combustion model type.
- Returns
- type of active coal combustion model (CS_COMBUSTION_COAL_NONE if model not active)
◆ cs_coal_model_set_model()
Activate coal combustion model.
- Returns
- pointer to coal combustion model structure.
- Parameters
[in] | type | coal combustion model type |
◆ cs_coal_rad_transfer_st()
Take in account the radiative source terms in the particle equation of a given class for pulverized coal flame.
- Parameters
[in] | f | pointer to scalar field |
[in,out] | smbrs | right and side (explicit ST contribution) |
[in,out] | rovsdt | system diagonal (implicit ST contribution) |
◆ cs_coal_setup()
void cs_coal_setup |
void |
Specific setup operations for pulverized coal combustion model.
◆ cs_coal_atom_id_c
const int cs_coal_atom_id_c |
extern |
◆ cs_coal_atom_id_h
const int cs_coal_atom_id_h |
extern |
◆ cs_coal_atom_id_n
const int cs_coal_atom_id_n |
extern |
◆ cs_coal_atom_id_o
const int cs_coal_atom_id_o |
extern |
◆ cs_coal_atom_id_s
const int cs_coal_atom_id_s |
extern |
◆ cs_coal_epsilon
const double cs_coal_epsilon |
extern |
◆ cs_coal_prefth
const double cs_coal_prefth |
extern |
reference pressure for molar volume
◆ cs_coal_trefth
const double cs_coal_trefth |
extern |
molar volume under normal pressure and temperature conditions
(1 atmosphere, 0 degres C) in m-3
reference temperature for molar volume
◆ cs_coal_volmol
const double cs_coal_volmol |
extern |
molar volume under normal pressure and temperature conditions (1 atmosphere, 0
) in
◆ cs_glob_coal_model
Combustion model parameters structure
Coal combustion model parameters structure
