Physical properties are using the field API. See cs_user_boundary_conditions for some examples. More...
integer, save | irom |
Density at the current time step (equal to icrom, kept for compatibility) More... | |
integer, save | iviscl |
dynamic molecular viscosity (in kg/(m.s)) More... | |
integer, save | ivisct |
dynamic turbulent viscosity More... | |
integer, dimension(nestmx), save | iestim |
error estimator for Navier-Stokes More... | |
integer, save | kimasf |
interior and boundary convective mass flux key ids of the variables More... | |
integer, save | kbmasf |
integer, save | kvisl0 |
constant diffusivity field id key for scalars More... | |
integer, save | kivisl |
variable diffusivity field id key for scalars More... | |
integer, save | kscacp |
do scalars behave as a temperature (regarding multiplication by Cp) ? More... | |
integer, save | kromsl |
variable density field id key for scalars More... | |
integer, save | kstprv |
source terms at previous time step for 2nd order More... | |
integer, save | kst |
source terms at the current time step (used for limiters) More... | |
integer, save | ksigmas |
turbulent schmidt key for scalars More... | |
integer, save | kctheta |
turbulent flow models GGDH and AFM key for scalar More... | |
integer, dimension(nvarmx), save | ifluaa |
convective mass flux of the variables at the previous time-step More... | |
integer, save | icrom |
cell density field ids of the variables More... | |
integer, save | ibrom |
boundary density field ids of the variables More... | |
integer, save | ipori |
field ids of the cell porosity More... | |
integer, save | iporf |
integer, save | ismago |
dynamic constant of Smagorinsky More... | |
integer, save | ivsten |
field ids of the anisotropic viscosity More... | |
integer, save | ivstes |
integer, save | icour |
Courant number. More... | |
integer, save | ifour |
Fourier number. More... | |
integer, save | iprtot |
Total pressure at cell centers . More... | |
integer, save | ivisma |
Mesh velocity viscosity for the ALE module. More... | |
integer, dimension(nscamx), save | iustdy |
pointer for dilatation source terms More... | |
integer, save | itsrho |
pointer for global dilatation source terms More... | |
integer, save | ibeta |
pointer for thermal expansion coefficient More... | |
integer, save | iddgas |
pointer for deduced mass fraction in case of gas mix More... | |
integer, save | igmxml |
pointer for gas mix molar mass More... | |
integer, save | iforbr |
field id of the stresses at boundary (if post-processed) More... | |
integer, save | iyplbr |
field id of at boundary (if post-processed) More... | |
integer, save | itempb |
field id of temperature at boundary More... | |
integer, save | is2kw |
field id of the square of the norm of the deviatoric part of the deformation rate tensor ( ). Field defined only with the (SST) turbulence model More... | |
integer, save | idivukw |
field id of the divergence of the velocity. More precisely, it is the trace of the velocity gradient (and not a finite volume divergence term). In the cell iel , is given by divukw(iel1) . This array is defined only with the SST turbulence model (because in this case it may be calculated at the same time as ) More... | |
integer, save | istraio |
field id of the strain rate tensor at the previous time step More... | |
integer, save ibeta |
integer, save ibrom |
integer, save icour |
Courant number.
integer, save icrom |
integer, save iddgas |
integer, save idivukw |
integer, dimension(nestmx), save iestim |
integer, dimension(nvarmx), save ifluaa |
integer, save iforbr |
integer, save ifour |
Fourier number.
integer, save igmxml |
integer, save iporf |
integer, save ipori |
integer, save iprtot |
integer, save irom |
integer, save is2kw |
integer, save ismago |
integer, save istraio |
integer, save itempb |
integer, save itsrho |
integer, dimension(nscamx), save iustdy |
integer, save iviscl |
integer, save ivisct |
integer, save ivisma |
integer, save ivsten |
integer, save ivstes |
integer, save iyplbr |
integer, save kbmasf |
integer, save kctheta |
integer, save kimasf |
integer, save kivisl |
integer, save kromsl |
integer, save kscacp |
integer, save ksigmas |
integer, save kst |
integer, save kstprv |
integer, save kvisl0 |
