Manage a computational domain. More...
#include <ctype.h>
#include <errno.h>
#include <float.h>
#include <locale.h>
#include <bft_mem.h>
#include "cs_boundary_zone.h"
#include "cs_coupling.h"
#include "cs_math.h"
#include "cs_mesh_location.h"
#include "cs_property.h"
#include "cs_prototypes.h"
#include "cs_quadrature.h"
#include "cs_restart.h"
#include "cs_time_step.h"
#include "cs_domain.h"
cs_domain_t * | cs_domain_create (void) |
Create and initialize by default a cs_domain_t structure. More... | |
void | cs_domain_free (cs_domain_t **p_domain) |
Free a cs_domain_t structure. More... | |
void | cs_domain_set_cdo_mode (cs_domain_t *domain, int mode) |
Set the global variable storing the mode of activation to apply to CDO/HHO schemes. More... | |
int | cs_domain_get_cdo_mode (const cs_domain_t *domain) |
Get the mode of activation for the CDO/HHO schemes. More... | |
void | cs_domain_set_stage (cs_domain_t *domain, cs_domain_stage_t stage) |
Set the computation stage in the domain structure. More... | |
cs_domain_stage_t | cs_domain_get_stage (const cs_domain_t *domain) |
Retrieve the computation stage from the domain structure. More... | |
bool | cs_domain_needs_iteration (cs_domain_t *domain) |
Check if one needs to continue iterations in time. More... | |
bool | cs_domain_needs_log (const cs_domain_t *domain, bool oneplus) |
Check if an output is requested according to the domain setting. More... | |
void | cs_domain_increment_time (cs_domain_t *domain) |
Update the simulated time after one temporal iteration. More... | |
void | cs_domain_cdo_log (const cs_domain_t *domain) |
Print a welcome message indicating which mode of CDO is activated. More... | |
cs_domain_t * | cs_glob_domain = NULL |
static const char | _err_empty_domain [] |
static double | cs_domain_kahan_time_compensation = 0.0 |
void cs_domain_cdo_log | ( | const cs_domain_t * | domain | ) |
[in] | domain | pointer to a cs_domain_t structure |
cs_domain_t* cs_domain_create | ( | void | ) |
void cs_domain_free | ( | cs_domain_t ** | p_domain | ) |
[in,out] | p_domain | pointer of pointer to a cs_domain_t structure |
int cs_domain_get_cdo_mode | ( | const cs_domain_t * | domain | ) |
cs_domain_stage_t cs_domain_get_stage | ( | const cs_domain_t * | domain | ) |
void cs_domain_increment_time | ( | cs_domain_t * | domain | ) |
Update time step after one temporal iteration.
[in,out] | domain | pointer to a cs_domain_t structure |
bool cs_domain_needs_iteration | ( | cs_domain_t * | domain | ) |
bool cs_domain_needs_log | ( | const cs_domain_t * | domain, |
bool | oneplus | ||
[in] | oneplus | add or not plus one to the current time step |
void cs_domain_set_cdo_mode | ( | cs_domain_t * | domain, |
int | mode | ||
[in] | mode | type of activation for the CDO/HHO module |
void cs_domain_set_stage | ( | cs_domain_t * | domain, |
cs_domain_stage_t | stage | ||
[in] | stage | stage in the computation run |
static |
static |
cs_domain_t* cs_glob_domain = NULL |
