struct | cs_boundary_t |
| Structure storing information related to the "physical" boundaries associated with the computational domain. More...
enum | cs_boundary_category_t { CS_BOUNDARY_CATEGORY_FLOW,
CS_BOUNDARY_CATEGORY_ALE,
CS_BOUNDARY_CATEGORY_RADIATIVE
enum | cs_boundary_flow_subtype_bits_t {
CS_BOUNDARY_WALL = 1<<0,
CS_BOUNDARY_INLET = 1<<1,
CS_BOUNDARY_OUTLET = 1<<2,
CS_BOUNDARY_SYMMETRY = 1<<3,
CS_BOUNDARY_ROUGH_WALL = 1<<4,
CS_BOUNDARY_SLIDING_WALL = 1<<5,
CS_BOUNDARY_IMPOSED_VEL = 1<<6,
CS_BOUNDARY_IMPOSED_P = 1<<7,
CS_BOUNDARY_FREE_INLET_OUTLET = 1<<8,
CS_BOUNDARY_CONVECTIVE_INLET = 1<<9,
CS_BOUNDARY_INLET_QH = 1<<10,
CS_BOUNDARY_INLET_SUBSONIC_PH = 1<<11,
CS_BOUNDARY_SUBSONIC = 1<<12,
CS_BOUNDARY_SUPERSONIC = 1<<13,
CS_BOUNDARY_FREE_SURFACE = 1<<14,
CS_BOUNDARY_COUPLED = 1<<15,
CS_BOUNDARY_COUPLED_DF = 1<<16
enum | cs_boundary_ale_subtype_bits_t {
CS_BOUNDARY_ALE_FIXED = 1<<0,
CS_BOUNDARY_ALE_SLIDING = 1<<1,
CS_BOUNDARY_ALE_IMPOSED_VEL = 1<<2,
CS_BOUNDARY_ALE_IMPOSED_DISP = 1<<3,
CS_BOUNDARY_ALE_INTERNAL_COUPLING = 1<<4,
CS_BOUNDARY_ALE_EXTERNAL_COUPLING = 1<<5,
CS_BOUNDARY_ALE_FREE_SURFACE = 1<<6
bool | cs_boundary_has_type (const cs_boundary_t *boundaries, int type_flag) |
| Check if a boundary with a given flag is present. More...
int | cs_boundary_id_by_zone_id (const cs_boundary_t *boundaries, int z_id) |
| Retrieve the related id associated to a boundary from its zone id. More...
void | cs_boundary_set_default (cs_boundary_t *boundaries, cs_boundary_type_t type) |
| Set the default boundary related to the given cs_boundary_t structure. More...
cs_boundary_t * | cs_boundary_create (cs_boundary_category_t category, cs_boundary_type_t default_type) |
| Create a default boundary structure for the computational domain. More...
void | cs_boundary_free (cs_boundary_t **p_boundaries) |
| Free all metadate related to the domain boundaries. More...
void | cs_boundary_add (cs_boundary_t *bdy, cs_boundary_type_t type, const char *zone_name) |
| Add a new boundary type for a given boundary zone. More...
void | cs_boundary_build_type_array (const cs_boundary_t *boundaries, cs_lnum_t n_b_faces, cs_boundary_type_t bf_type[]) |
| Build an array on boundary faces which specifies the boundary type for each face. More...
void | cs_boundary_def_wall_zones (cs_boundary_t *boundaries) |
| Add a new zone gathering all CS_BOUNDARY_WALL type zones. More...
int | cs_boundary_need_pressure_rescaling (cs_lnum_t n_b_faces, const cs_boundary_type_t bf_type[]) |
| Check if one needs to perform a pressure rescaling (in case of a Dirichlet on the velocity for the whole boundary) Use in CDO schemes for Navier–Stokes. More...
void | cs_boundary_get_type_descr (const cs_boundary_t *bdy, cs_boundary_type_t b_type, int descr_len_max, char descr[]) |
| Build a boundary type description. More...
void | cs_boundary_log_setup (const cs_boundary_t *bdy) |
| Summarize the setup of the boundary of the computational domain. More...
◆ CS_BOUNDARY_PRESSURE_NO_RESCALING
#define CS_BOUNDARY_PRESSURE_NO_RESCALING 1 |
◆ CS_BOUNDARY_PRESSURE_RESCALING
#define CS_BOUNDARY_PRESSURE_RESCALING 0 |
◆ CS_BOUNDARY_UNDEFINED
#define CS_BOUNDARY_UNDEFINED 0 |
◆ CS_BOUNDARY_WALLS_NAME
#define CS_BOUNDARY_WALLS_NAME "auto:wall" |
◆ cs_boundary_type_t
Flag values defining boundary condition subtypes (0 for none)
◆ cs_boundary_ale_subtype_bits_t
Enumerator |
CS_BOUNDARY_ALE_FIXED | fixed
CS_BOUNDARY_ALE_SLIDING | sliding
CS_BOUNDARY_ALE_IMPOSED_VEL | imposed velocity
CS_BOUNDARY_ALE_IMPOSED_DISP | imposed displacement
CS_BOUNDARY_ALE_INTERNAL_COUPLING | internal coupling
CS_BOUNDARY_ALE_EXTERNAL_COUPLING | external coupling
CS_BOUNDARY_ALE_FREE_SURFACE | free surface
◆ cs_boundary_category_t
Enumerator |
CS_BOUNDARY_CATEGORY_FLOW | |
CS_BOUNDARY_CATEGORY_ALE | |
CS_BOUNDARY_CATEGORY_RADIATIVE | |
◆ cs_boundary_flow_subtype_bits_t
Enumerator |
CS_BOUNDARY_WALL | wall
CS_BOUNDARY_INLET | inlet
CS_BOUNDARY_OUTLET | outlet
CS_BOUNDARY_SYMMETRY | symmetry
CS_BOUNDARY_ROUGH_WALL | rough wall
CS_BOUNDARY_SLIDING_WALL | sliding wall
CS_BOUNDARY_IMPOSED_VEL | imposed velocity
CS_BOUNDARY_IMPOSED_P | imposed pressure
CS_BOUNDARY_FREE_INLET_OUTLET | free inlet-outlet
CS_BOUNDARY_CONVECTIVE_INLET | convective inlet
CS_BOUNDARY_INLET_QH | compressible inlet, imposed flux and enthalpy
CS_BOUNDARY_INLET_SUBSONIC_PH | compressible (subsonic) inlet, imposed pressure and enthalpy
CS_BOUNDARY_SUBSONIC | compressible subsonic
CS_BOUNDARY_SUPERSONIC | compressible supersonic
CS_BOUNDARY_FREE_SURFACE | free surface
CS_BOUNDARY_COUPLED | coupled
CS_BOUNDARY_COUPLED_DF | coupled with decentered flux
◆ cs_boundary_add()
- Parameters
[in,out] | bdy | pointer to a structure storing boundary info |
[in] | type | type of boundary to set |
[in] | zone_name | name of the zone related to this boundary |
◆ cs_boundary_build_type_array()
- Parameters
[in] | boundaries | pointer to the domain boundaries |
[in] | n_b_faces | number of boundaries faces |
[in,out] | bf_type | boundary type flag |
[in,out] | bf_type | array to define the type of boundary |
◆ cs_boundary_create()
- Parameters
[in] | category | default type of boundary to set |
[in] | default_type | default type of boundary to set |
- Returns
- a pointer to the new allocated structure
◆ cs_boundary_def_wall_zones()
- Parameters
[in,out] | boundaries | pointer to the domain boundaries |
- Parameters
◆ cs_boundary_free()
- Parameters
[in,out] | p_boundaries | pointer to the structure to free |
◆ cs_boundary_get_type_descr()
- Parameters
[in] | bdy | pointer to a structure storing boundary info |
[in] | b_type | type flag |
[in] | descr_len_max | maximum name length |
[out] | descr | subtype name |
◆ cs_boundary_has_type()
bool cs_boundary_has_type |
const cs_boundary_t * |
boundaries, |
int |
type_flag |
- Parameters
[in] | boundaries | pointer to a cs_boundary_t structure |
[in] | type_flag | boundary type flag |
- Returns
- true or false
◆ cs_boundary_id_by_zone_id()
int cs_boundary_id_by_zone_id |
boundaries, |
int |
z_id |
- Parameters
[in] | z_id | id of the related zone |
- Returns
- the associated boundary id in the boundary list
◆ cs_boundary_log_setup()
- Parameters
◆ cs_boundary_need_pressure_rescaling()
- Parameters
[in] | n_b_faces | number of border faces |
[in] | bf_type | array of types of boundary for each boundary face |
- Returns
- 1 if a pressure rescaling is needed otherwise 0
- Parameters
- Returns
- CS_BOUNDARY_PRESSURE_RESCALING (=0) or CS_BOUNDARY_PRESSURE_NO_RESCALING (=1)
◆ cs_boundary_set_default()
- Parameters
[in,out] | boundaries | pointer to a structure storing boundary info |
◆ cs_glob_boundaries
