cs_thermal_model_t Struct Reference
Thermal model descriptor. More...
#include <cs_thermal_model.h>
+ Collaboration diagram for cs_thermal_model_t:
Public Attributes
cs_thermal_model_variable_t thermal_variable
cs_temperature_scale_t temperature_scale
int has_kinetic_st
int cflt
int cflp
bool has_pdivu
bool has_dissipation
Members of this thermal model are publicly accessible, to allow for concise syntax, as it is expected to be used in many places.
Member Data Documentation
◆ cflp
cflp
Take kinetic source term in energy equation into account (see Amino, Flageul, Carissimo, Tiselj, Benhamadouche, Ferrand 2022)
  • false (default)
  • true
◆ cflt
cflt
  • false (default)
  • true
◆ has_dissipation
has_dissipation
Add to the right hand side the thermal dissipation term
◆ has_kinetic_st
has_kinetic_st
  • 0 (default)
  • 1
◆ has_pdivu
has_pdivu
Add to the right hand side the term equal to -p div(u)
◆ temperature_scale
temperature_scale
Temperature scale The specification of the temperature scale in a consistent manner with the values used (initial and boundary conditions) is especially important in case of radiation modelling.
  • 0: none
  • 1: Kelvin
  • 2: Celsius
◆ thermal_variable
thermal_variable
Thermal variable solved for this physical model.
  • 0: no thermal model
  • 1: temperature
  • 2: enthalpy
  • 3: total energy (only for compressible module)
  • 4: internal energy
