cs_iter_algo_default_t Struct Reference
#include <cs_iter_algo.h>
+ Collaboration diagram for cs_iter_algo_default_t:
Public Attributes
cs_sles_convergence_state_t cvg_status
double normalization
double tol
double prev_res
double res
double res0
int n_algo_iter
int n_inner_iter
int last_inner_iter
Member Data Documentation
◆ cvg_status
cvg_status
Converged, iterating or diverged status
◆ last_inner_iter
last_inner_iter
Last number of iterations for the inner solver
◆ n_algo_iter
n_algo_iter
Current number of iterations for the algorithm
◆ n_inner_iter
n_inner_iter
Curent cumulated number of inner iterations (sum over the outer iterations)
◆ normalization
normalization
Value of the normalization for the relative tolerance.
The stopping criterion is such that res < rtol * normalization. By default, the normalization is set to 1.
◆ prev_res
prev_res
Value of the previous residual achieved during the iterative process
◆ res
res
Value of the residual for the iterative algorithm
◆ res0
res0
Value of the first residual of the iterative process. This is used for detecting the divergence of the algorithm.
◆ tol
tol
Tolerance computed as tol = max(atol, normalization*rtol) where atol and rtol are respectively the absolute and relative tolerance associated to the algorithm
