rayso.f90 File Reference
Functions/Subroutines
subroutine reftra (pioc, piaero, gasym, gaero, tauc, taua, ref, tra, epsc, dqqv, mui, muzero_cor)
 Compute reflexion and transmission. More...
subroutine rayso (ivertc, k1, kmray, heuray, imer1, albe, qqv, qqqv, qqvinf, zqq, zray, qvray, qlray, fneray, romray, preray, temray, fos, rayst, ncray)
 Compute solar fluxes for both clear and cloudy atmosphere following Lacis and Hansen (1974). The multiple diffusion is taken into account by an addition method and overlapping between water vapor and liquid water with k distribution method. Some improvements from original version concerns: More...
double precision function rayuoz (zh)
 Computes ozone amount above a given altitude. More...
double precision function raysve (y)
 Absorption function of the solar radiation by water vapor. More...
double precision function dzyama (y, dy)
 Absorption derivative-function of the solar radiation by water vapor. More...
double precision function raysoz (x)
 Absorption function of the solar radiation by ozone. More...
double precision function dzxaoz (x, dx)
 Absorption derivative-function of the solar radiation by ozone. More...
double precision function drayuoz (zh)
◆ drayuoz()
double precision function drayuoz ( double precision, intent(in)  zh)
◆ dzxaoz()
double precision function dzxaoz ( double precision, intent(in)  x,
double precision, intent(in)  dx
[in]x
[in]dx
◆ dzyama()
double precision function dzyama ( double precision, intent(in)  y,
double precision, intent(in)  dy
[in]yoptical depth for water vapor
[in]dyTODO?
◆ rayso()
subroutine rayso ( integer  ivertc,
integer  k1,
integer  kmray,
double precision  heuray,
integer  imer1,
double precision  albe,
double precision, dimension(kmx+1)  qqv,
double precision, dimension(kmx+1)  qqqv,
double precision  qqvinf,
double precision, dimension(kmx+1)  zqq,
double precision, dimension(kmx)  zray,
double precision, dimension(kmx)  qvray,
double precision, dimension(kmx)  qlray,
double precision, dimension(kmx)  fneray,
double precision, dimension(kmx)  romray,
double precision, dimension(kmx)  preray,
double precision, dimension(kmx)  temray,
double precision  fos,
double precision, dimension(kmx)  rayst,
double precision, dimension(kmx)  ncray
  • introduction of cloud fraction with hazardous recovering
  • introduction of aerosol diffusion in the same way as for cloud droplets but with specific optical properties for aerosols.
    [in]ivertcindex of vertical profile
    [in]k1index for ground level
    [in]kmrayvertical levels number for radiation
    [in]heurayUniversal time (Hour)
    [in]imer1sea index
    [in]albealbedo
    [in]qqvoptical depth for water vapor (0,zqq)
    [in]qqqvidem for intermediate levels
    [in]qqvinfidem qqv but for altitude above 11000m
    [in]zqqvertical levels (interfaces)
    [in]zrayvertical levels (volumes)
    [in]qvrayspecific humidity for water vapor
    [in]qlrayspecific humidity for liquid water
    [in]fneraycloud fraction
    [in]romrayair density
    [in]preraypressure
    [in]temraytemperature
    [out]fosglobal downward solar flux at the ground
    [out]raystflux divergence of solar radiation
◆ raysoz()
double precision function raysoz ( double precision, intent(in)  x)
[in]xoptical depth for ozone
◆ raysve()
double precision function raysve ( double precision, intent(in)  y)
◆ rayuoz()
double precision function rayuoz ( double precision, intent(in)  zh)
[in]zhaltitude
◆ reftra()
subroutine reftra ( double precision, intent(in)  pioc,
double precision, intent(in)  piaero,
double precision, intent(in)  gasym,
double precision, intent(in)  gaero,
double precision, intent(in)  tauc,
double precision, intent(in)  taua,
double precision, intent(inout)  ref,
double precision, intent(inout)  tra,
double precision, intent(in)  epsc,
double precision, intent(in)  dqqv,
double precision, intent(in)  mui,
double precision, intent(in)  muzero_cor
[in]piocAlbedo of simple diffusion for cloud (water)
[in]piaeroAlbedo of simple diffusion for aerosol
[in]gasymAsymmetry factor for clouds
[in]gaeroAsymmetry factor for aerosols
[in]taucOptical depth for clouds
[in]tauaOptical depth for aersols
[out]refReflexion
[out]traTransmission
[in]epscclipping threshold
[in]dqqvOptical depth for Water vapor
[in]muimui (Gauss quadrature)
[in]muzero_cormu0 corrected
