+ Collaboration diagram for Mixture properties:
Classes
struct  cs_vof_parameters_t
 VOF model parameters. Void fraction variable tracks fluid 2. More...
unsigned vof_model
double rho1
double rho2
double mu1
double mu2
double sigma_s
int idrift
double cdrift
double kdrift
◆ cdrift
cdrift
Flux factor parameter. In case of drift flux, factor of the local flux compared to the global max flux.
◆ idrift
idrift
drift velocity model
  • 0: drift model disable
  • 1: field inner_drift_velocity_flux is used Deshpande's model
  • 2: field drift_velocity is used User-defined drift velocity field
◆ kdrift
kdrift
Turbulent like diffusion effect (m2/s). In case of drift velocity, factor of a volume fraction gradient
◆ mu1
mu1
reference molecular viscosity of fluid 1 (kg/(m s))
◆ mu2
mu2
reference molecular viscosity of fluid 2 (kg/(m s))
◆ rho1
rho1
reference density of fluid 1 (kg/m3). By convention, liquid phase for cavitation model.
◆ rho2
rho2
reference density of fluid 2 (kg/m3). By convention, gas phase for cavitation model.
◆ sigma_s
sigma_s
reference surface tension (N/m)
◆ vof_model
vof_model
Volume of Fluid model - sum of masks defining VoF model and submodels. See defined masks in Masks used to specify Volume of Fluid models.
