Flags specifying metadata related to the
Macros
#define CS_PROPERTY_ISO   (1 << 0)
#define CS_PROPERTY_ORTHO   (1 << 1)
#define CS_PROPERTY_ANISO   (1 << 2)
#define CS_PROPERTY_ANISO_SYM   (1 << 3)
#define CS_PROPERTY_BY_PRODUCT   (1 << 4)
#define CS_PROPERTY_SCALED   (1 << 5)
#define CS_PROPERTY_SUBCELL_DEFINITION   (1 << 6)
the type of property
◆ CS_PROPERTY_ANISO
4: Anisotropic behavior (a 3x3 tensor describe the behavior). This tensor should be symmetric positive definite (i.e 6 real numbers describe the behavior) but by default a 3x3 tensor is used.
◆ CS_PROPERTY_ANISO_SYM
8: Anisotropic behavior. This tensor is represented with 6 real numbers since the tensor is symmetric
◆ CS_PROPERTY_BY_PRODUCT
16: The property is defined as the product of two other properties
◆ CS_PROPERTY_ISO
1: Isotropic behavior (one real number is sufficient to describe the property)
◆ CS_PROPERTY_ORTHO
2: Orthotropic behavior (three real numbers describe the behavior assuming that the different behavior is aligned with Cartesian axis)
◆ CS_PROPERTY_SCALED
32: The property is defined up to a scaling factor
◆ CS_PROPERTY_SUBCELL_DEFINITION
64: The property is defined such that one wants to evaluate the definition on entities which are a partition of a cell. By default, one perfoms only one evaluation in each cell
