Flags specifying bad cells treatment
Macros
#define CS_BAD_CELLS_WARPED_CORRECTION   (1 << 0)
#define CS_BAD_CELLS_REGULARISATION   (1 << 1)
#define CS_CELL_FACE_CENTER_CORRECTION   (1 << 2)
#define CS_CELL_CENTER_CORRECTION   (1 << 3)
#define CS_FACE_DISTANCE_CLIP   (1 << 4)
#define CS_FACE_RECONSTRUCTION_CLIP   (1 << 5)
#define CS_CELL_VOLUME_RATIO_CORRECTION   (1 << 6)
#define CS_FACE_CENTER_REFINE   (1 << 7)
#define CS_FACE_NULL_SURFACE   (1 << 8)
◆ CS_BAD_CELLS_REGULARISATION
Regularise on bad cells
◆ CS_BAD_CELLS_WARPED_CORRECTION
Correct bad cells warping for gradients
◆ CS_CELL_CENTER_CORRECTION
Recompute cell centers
◆ CS_CELL_FACE_CENTER_CORRECTION
Recompute face centers
◆ CS_CELL_VOLUME_RATIO_CORRECTION
Limit cells volume ratio
◆ CS_FACE_CENTER_REFINE
Refine face center computation for warped cells (iteratively compute center using previous position instead of using only the initial estimate based on the vertices center)
◆ CS_FACE_DISTANCE_CLIP
Clip face distance when negative or too small
◆ CS_FACE_NULL_SURFACE
Regularization for faces if null surface value
◆ CS_FACE_RECONSTRUCTION_CLIP
Clip geometrical quantities used in flux reconstuction
