fvm_writer_priv.h
1#ifndef FVM_WRITER_PRIV_H
2#define FVM_WRITER_PRIV_H
5 * Private types for mesh and field writers
30#include "base/cs_defs.h"
33 * Local headers
36#include "base/cs_timer.h"
38#include "fvm/fvm_defs.h"
39#include "fvm/fvm_nodal.h"
40#include "fvm/fvm_writer.h"
42/*----------------------------------------------------------------------------*/
45
46/*=============================================================================
47 * Macro definitions
49
50/*
51 * Writer format implementation and functionality info
52 */
53
54#define FVM_WRITER_FORMAT_USE_EXTERNAL (1 << 0)
55
56#define FVM_WRITER_FORMAT_HAS_POLYGON (1 << 1)
57#define FVM_WRITER_FORMAT_HAS_POLYHEDRON (1 << 2)
58
59#define FVM_WRITER_FORMAT_SEPARATE_MESHES (1 << 3)
60#define FVM_WRITER_FORMAT_NO_SEPARATE_MESHES (1 << 4)
61
62#define FVM_WRITER_FORMAT_NAME_IS_OPTIONAL (1 << 5)
63
64/*============================================================================
65 * Type definitions
66 *============================================================================*/
67
68/*----------------------------------------------------------------------------
69 * Function pointer types
70 *----------------------------------------------------------------------------*/
71
72typedef int
74
75typedef const char *
76(fvm_writer_version_string_t)(int string_index,
77 int compile_time_version);
78
79#if defined(HAVE_MPI)
80
81typedef void *
82(fvm_writer_init_t) (const char *name,
83 const char *path,
84 const char *options,
85 fvm_writer_time_dep_t time_dependency,
86 MPI_Comm comm);
87
88#else
89
90typedef void *
91(fvm_writer_init_t) (const char *name,
92 const char *path,
93 const char *options,
94 fvm_writer_time_dep_t time_dependency);
95
96#endif /* defined(HAVE_MPI) */
97
98typedef void *
99(fvm_writer_finalize_t) (void *this_writer);
100
101typedef void
102(fvm_writer_set_mesh_time_t) (void *this_writer,
103 int time_step,
104 double time_value);
105
106typedef int
107(fvm_writer_needs_tesselation_t) (void *this_writer,
108 const fvm_nodal_t *mesh,
109 fvm_element_t element_type);
110
111typedef void
112(fvm_writer_export_nodal_t) (void *this_writer,
113 const fvm_nodal_t *mesh);
114
115typedef void
116(fvm_writer_export_field_t) (void *this_writer,
117 const fvm_nodal_t *mesh,
118 const char *name,
119 fvm_writer_var_loc_t location,
120 int dimension,
121 cs_interlace_t interlace,
122 int n_parent_lists,
123 const cs_lnum_t parent_num_shift[],
124 cs_datatype_t datatype,
125 int time_step,
126 double time_value,
127 const void *const field_values[]);
128
129typedef void
130(fvm_writer_flush_t) (void *this_writer);
131
132/*----------------------------------------------------------------------------
133 * Format information structure
134 *----------------------------------------------------------------------------*/
135
136typedef struct {
137
138 char name[32]; /* Format name */
139 char version[16]; /* Format version (if defined) */
140 int info_mask; /* Additional format info */
141 fvm_writer_time_dep_t max_time_dep; /* Maximum time dependency level
142 possible with this format */
143
144 int dl_count; /* Number of writers using the
145 dynamically loadable library
146 for this format, if relevant */
147 int dl_flags; /* dlopen flags for dynamically
148 loadable library, if used
149 (0 for default) */
150 void *dl_lib; /* Pointer to dynamically loadable
151 library, if used */
152 const char *dl_name; /* Prefix for name of dynamically
153 loadable library, or NULL */
154 const char *dl_prefix; /* Prefix for exported symbols of
155 dynamically loadable library,
156 or NULL */
157
167
169
170/*----------------------------------------------------------------------------
171 * Structure defining a writer definition
172 *----------------------------------------------------------------------------*/
173
175
176 char *name; /* Writer name */
177 fvm_writer_format_t *format; /* Output format */
178 char *options; /* Output options */
179 char *path; /* Output path */
180 fvm_writer_time_dep_t time_dep; /* Geometry time dependency */
181 int n_format_writers; /* number of actual writers */
182 void **format_writer; /* Format-specific writers */
183 char **mesh_names; /* List of mesh names if one
184 writer per mesh is required */
185
186 cs_timer_counter_t mesh_time; /* Meshes output timer */
187 cs_timer_counter_t field_time; /* Fields output timer */
188 cs_timer_counter_t flush_time; /* output "completion" timer */
189
190};
191
192/*----------------------------------------------------------------------------*/
193
195
196#endif /* FVM_WRITER_PRIV_H */
cs_datatype_t
Definition: cs_defs.h:290
Definition: cs_defs.h:528
cs_interlace_t
Definition: cs_defs.h:504
Definition: cs_defs.h:529
Definition: cs_defs.h:325
fvm_element_t
Definition: fvm_defs.h:44
Definition: fvm_writer.h:57
Definition: fvm_writer.h:69
void() fvm_writer_flush_t(void *this_writer)
Definition: fvm_writer_priv.h:130
void() fvm_writer_export_field_t(void *this_writer, const fvm_nodal_t *mesh, const char *name, fvm_writer_var_loc_t location, int dimension, cs_interlace_t interlace, int n_parent_lists, const cs_lnum_t parent_num_shift[], cs_datatype_t datatype, int time_step, double time_value, const void *const field_values[])
Definition: fvm_writer_priv.h:116
void() fvm_writer_set_mesh_time_t(void *this_writer, int time_step, double time_value)
Definition: fvm_writer_priv.h:102
int() fvm_writer_n_version_strings_t(void)
Definition: fvm_writer_priv.h:73
void() fvm_writer_export_nodal_t(void *this_writer, const fvm_nodal_t *mesh)
Definition: fvm_writer_priv.h:112
void *() fvm_writer_init_t(const char *name, const char *path, const char *options, fvm_writer_time_dep_t time_dependency, MPI_Comm comm)
Definition: fvm_writer_priv.h:82
const char *() fvm_writer_version_string_t(int string_index, int compile_time_version)
Definition: fvm_writer_priv.h:76
int() fvm_writer_needs_tesselation_t(void *this_writer, const fvm_nodal_t *mesh, fvm_element_t element_type)
Definition: fvm_writer_priv.h:107
void *() fvm_writer_finalize_t(void *this_writer)
Definition: fvm_writer_priv.h:99
Definition: mesh.f90:26
Definition: fvm_writer_priv.h:174
char * path
Definition: fvm_writer_priv.h:179
char * name
Definition: fvm_writer_priv.h:176
fvm_writer_format_t * format
Definition: fvm_writer_priv.h:177
void ** format_writer
Definition: fvm_writer_priv.h:182
Definition: fvm_writer_priv.h:187
Definition: fvm_writer_priv.h:180
Definition: fvm_writer_priv.h:186
char ** mesh_names
Definition: fvm_writer_priv.h:183
char * options
Definition: fvm_writer_priv.h:178
Definition: fvm_writer_priv.h:188
Definition: fvm_writer_priv.h:181
Definition: cs_timer.h:51
Definition: fvm_writer_priv.h:136
fvm_writer_needs_tesselation_t * needs_tesselation_func
Definition: fvm_writer_priv.h:163
const char * dl_prefix
Definition: fvm_writer_priv.h:154
fvm_writer_set_mesh_time_t * set_mesh_time_func
Definition: fvm_writer_priv.h:162
Definition: fvm_writer_priv.h:141
fvm_writer_export_field_t * export_field_func
Definition: fvm_writer_priv.h:165
int dl_count
Definition: fvm_writer_priv.h:144
int dl_flags
Definition: fvm_writer_priv.h:147
fvm_writer_flush_t * flush_func
Definition: fvm_writer_priv.h:166
fvm_writer_version_string_t * version_string_func
Definition: fvm_writer_priv.h:159
int info_mask
Definition: fvm_writer_priv.h:140
const char * dl_name
Definition: fvm_writer_priv.h:152
void * dl_lib
Definition: fvm_writer_priv.h:150
fvm_writer_export_nodal_t * export_nodal_func
Definition: fvm_writer_priv.h:164
fvm_writer_n_version_strings_t * n_version_strings_func
Definition: fvm_writer_priv.h:158
fvm_writer_init_t * init_func
Definition: fvm_writer_priv.h:160
fvm_writer_finalize_t * finalize_func
Definition: fvm_writer_priv.h:161
