fvm_to_plot.h
1#ifndef FVM_TO_PLOT_H
2#define FVM_TO_PLOT_H
5 * Write a nodal representation associated with a mesh and associated
6 * variables to plot (whitepace-separated or csv) files
7 *============================================================================*/
8
9/*
10 This file is part of code_saturne, a general-purpose CFD tool.
11
12 Copyright (C) 1998-2026 EDF S.A.
13
14 This program is free software; you can redistribute it and/or modify it under
15 the terms of the GNU General Public License as published by the Free Software
16 Foundation; either version 2 of the License, or (at your option) any later
17 version.
18
19 This program is distributed in the hope that it will be useful, but WITHOUT
20 ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
21 FOR A PARTICULAR PURPOSE. See the GNU General Public License for more
22 details.
23
24 You should have received a copy of the GNU General Public License along with
25 this program; if not, write to the Free Software Foundation, Inc., 51 Franklin
26 Street, Fifth Floor, Boston, MA 02110-1301, USA.
27*/
28
29/*----------------------------------------------------------------------------*/
30
31#include "base/cs_defs.h"
32
33/*----------------------------------------------------------------------------
34 * Local headers
35 *----------------------------------------------------------------------------*/
36
37#include "fvm/fvm_defs.h"
38#include "fvm/fvm_nodal.h"
39#include "fvm/fvm_writer.h"
45/*=============================================================================
46 * Macro definitions
48
50 * Type definitions
52
53/*=============================================================================
54 * Public function prototypes
55 *============================================================================*/
56
57/*----------------------------------------------------------------------------
58 * Initialize FVM to plot file writer.
59 *
60 * Options are:
61 * dat output .dat files
62 * csv output .csv files (default)
63 * no_time_step do not add time step id to file name
64 *
65 * parameters:
66 * name <-- base output case name.
67 * options <-- whitespace separated, lowercase options list
68 * time_dependecy <-- indicates if and how meshes will change with time
69 * comm <-- associated MPI communicator.
70 *
71 * returns:
72 * pointer to opaque plot writer structure.
73 *----------------------------------------------------------------------------*/
74
75#if defined(HAVE_MPI)
76
77void *
78fvm_to_plot_init_writer(const char *name,
79 const char *path,
80 const char *options,
81 fvm_writer_time_dep_t time_dependency,
82 MPI_Comm comm);
83
84#else
85
86void *
87fvm_to_plot_init_writer(const char *name,
88 const char *path,
89 const char *options,
90 fvm_writer_time_dep_t time_dependency);
91
92#endif
93
94/*----------------------------------------------------------------------------
95 * Finalize FVM to plot file writer.
96 *
97 * parameters:
98 * writer <-- pointer to opaque plot writer structure.
99 *
100 * returns:
101 * null pointer.
102 *----------------------------------------------------------------------------*/
103
104void *
105fvm_to_plot_finalize_writer(void *writer);
106
107/*----------------------------------------------------------------------------
108 * Associate new time step with an Plot geometry.
109 *
110 * parameters:
111 * writer <-- pointer to associated writer
112 * time_step <-- time step number
113 * time_value <-- time_value number
114 *----------------------------------------------------------------------------*/
115
116void
117fvm_to_plot_set_mesh_time(void *writer,
118 const int time_step,
119 const double time_value);
120
121/*----------------------------------------------------------------------------
122 * Write nodal mesh to a plot file
123 *
124 * parameters:
125 * writer <-- pointer to associated writer.
126 * mesh <-- pointer to nodal mesh structure that should be written.
127 *----------------------------------------------------------------------------*/
128
129void
130fvm_to_plot_export_nodal(void *writer,
131 const fvm_nodal_t *mesh);
132
133/*----------------------------------------------------------------------------
134 * Write field associated with a nodal mesh to a plot file.
135 *
136 * Assigning a negative value to the time step indicates a time-independent
137 * field (in which case the time_value argument is unused).
138 *
139 * parameters:
140 * writer <-- pointer to associated writer
141 * mesh <-- pointer to associated nodal mesh structure
142 * name <-- variable name
143 * location <-- variable definition location (nodes or elements)
144 * dimension <-- variable dimension (0: constant, 1: scalar,
145 * 3: vector, 6: sym. tensor, 9: asym. tensor)
146 * interlace <-- indicates if variable in memory is interlaced
147 * n_parent_lists <-- indicates if variable values are to be obtained
148 * directly through the local entity index (when 0) or
149 * through the parent entity numbers (when 1 or more)
150 * parent_num_shift <-- parent number to value array index shifts;
151 * size: n_parent_lists
152 * datatype <-- indicates the data type of (source) field values
153 * time_step <-- number of the current time step
154 * time_value <-- associated time value
155 * field_values <-- array of associated field value arrays
156 *----------------------------------------------------------------------------*/
157
158void
159fvm_to_plot_export_field(void *writer,
160 const fvm_nodal_t *mesh,
161 const char *name,
162 fvm_writer_var_loc_t location,
163 int dimension,
164 cs_interlace_t interlace,
165 int n_parent_lists,
166 const cs_lnum_t parent_num_shift[],
167 cs_datatype_t datatype,
168 int time_step,
169 double time_value,
170 const void *const field_values[]);
171
172/*----------------------------------------------------------------------------
173 * Flush files associated with a given writer.
174 *
175 * In this case, the effective writing to file is done.
176 *
177 * parameters:
178 * writer <-- pointer to associated writer
179 *----------------------------------------------------------------------------*/
180
181void
182fvm_to_plot_flush(void *writer);
183
184/*----------------------------------------------------------------------------*/
185
187
188#endif /* FVM_TO_PLOT_H */
cs_datatype_t
Definition: cs_defs.h:290
Definition: cs_defs.h:528
cs_interlace_t
Definition: cs_defs.h:504
Definition: cs_defs.h:529
Definition: cs_defs.h:325
void fvm_to_plot_set_mesh_time(void *writer, const int time_step, const double time_value)
Definition: fvm_to_plot.cpp:462
void fvm_to_plot_export_field(void *writer, const fvm_nodal_t *mesh, const char *name, fvm_writer_var_loc_t location, int dimension, cs_interlace_t interlace, int n_parent_lists, const cs_lnum_t parent_num_shift[], cs_datatype_t datatype, int time_step, double time_value, const void *const field_values[])
Definition: fvm_to_plot.cpp:568
void * fvm_to_plot_finalize_writer(void *writer)
Definition: fvm_to_plot.cpp:432
void * fvm_to_plot_init_writer(const char *name, const char *path, const char *options, fvm_writer_time_dep_t time_dependency, MPI_Comm comm)
Definition: fvm_to_plot.cpp:328
void fvm_to_plot_flush(void *writer)
Definition: fvm_to_plot.cpp:650
void fvm_to_plot_export_nodal(void *writer, const fvm_nodal_t *mesh)
Definition: fvm_to_plot.cpp:488
Definition: fvm_writer.h:57
Definition: fvm_writer.h:69
Definition: mesh.f90:26
