fvm_to_melissa.h
1#ifndef FVM_TO_MELISSA_H
2#define FVM_TO_MELISSA_H
5 * Write a nodal representation associated with a mesh and associated
6 * variables to Melissa daemon output.
7 *============================================================================*/
8
9/*
10 This file is part of code_saturne, a general-purpose CFD tool.
11
12 Copyright (C) 1998-2026 EDF S.A.
13
14 This program is free software; you can redistribute it and/or modify it under
15 the terms of the GNU General Public License as published by the Free Software
16 Foundation; either version 2 of the License, or (at your option) any later
17 version.
18
19 This program is distributed in the hope that it will be useful, but WITHOUT
20 ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
21 FOR A PARTICULAR PURPOSE. See the GNU General Public License for more
22 details.
23
24 You should have received a copy of the GNU General Public License along with
25 this program; if not, write to the Free Software Foundation, Inc., 51 Franklin
26 Street, Fifth Floor, Boston, MA 02110-1301, USA.
27*/
28
29/*----------------------------------------------------------------------------*/
30
31#include "base/cs_defs.h"
32
33/*----------------------------------------------------------------------------
34 * Local headers
35 *----------------------------------------------------------------------------*/
36
37#include "fvm/fvm_defs.h"
38#include "fvm/fvm_nodal.h"
39#include "fvm/fvm_writer.h"
45/*=============================================================================
46 * Macro definitions
48
50 * Type definitions
52
53/*=============================================================================
54 * Public function prototypes
55 *============================================================================*/
56
57/*----------------------------------------------------------------------------
58 * Initialize FVM to Melissa output writer.
59 *
60 * Options are:
61 * dry_run trace output to <name>.log file, but do not
62 * actually communicate with Melissa server
63 * rank_step=<integer> MPI rank step
64 * trace trace output to <name>.log file
65 *
66 * parameters:
67 * name <-- base output case name.
68 * options <-- whitespace separated, lowercase options list
69 * time_dependecy <-- indicates if and how meshes will change with time
70 * comm <-- associated MPI communicator.
71 *
72 * returns:
73 * pointer to opaque Melissa output writer structure.
74 *----------------------------------------------------------------------------*/
75
76#if defined(HAVE_MPI)
77
78void *
79fvm_to_melissa_init_writer(const char *name,
80 const char *path,
81 const char *options,
82 fvm_writer_time_dep_t time_dependency,
83 MPI_Comm comm);
84
85#else
86
87void *
88fvm_to_melissa_init_writer(const char *name,
89 const char *path,
90 const char *options,
91 fvm_writer_time_dep_t time_dependency);
92
93#endif
94
95/*----------------------------------------------------------------------------
96 * Finalize FVM to Melissa output writer.
97 *
98 * parameters:
99 * this_writer_p <-- pointer to opaque Melissa writer structure.
100 *
101 * returns:
102 * null pointer.
103 *----------------------------------------------------------------------------*/
104
105void *
106fvm_to_melissa_finalize_writer(void *this_writer_p);
107
108/*----------------------------------------------------------------------------
109 * Associate new time step with a Melissa geometry.
110 *
111 * parameters:
112 * this_writer_p <-- pointer to associated writer
113 * time_step <-- time step number
114 * time_value <-- time_value number
115 *----------------------------------------------------------------------------*/
116
117void
118fvm_to_melissa_set_mesh_time(void *this_writer_p,
119 const int time_step,
120 const double time_value);
121
122/*----------------------------------------------------------------------------
123 * Indicate if a elements of a given type in a mesh associated to a given
124 * Melissa output writer need to be tesselated.
125 *
126 * parameters:
127 * this_writer_p <-- pointer to associated writer
128 * mesh <-- pointer to nodal mesh structure that should be written
129 * element_type <-- element type we are interested in
130 *
131 * returns:
132 * 1 if tesselation of the given element type is needed, 0 otherwise
133 *----------------------------------------------------------------------------*/
134
135int
137 const fvm_nodal_t *mesh,
138 fvm_element_t element_type);
139
140/*----------------------------------------------------------------------------
141 * Write nodal mesh to a Melissa output
142 *
143 * parameters:
144 * this_writer_p <-- pointer to associated writer.
145 * mesh <-- pointer to nodal mesh structure that should be written.
146 *----------------------------------------------------------------------------*/
147
148void
149fvm_to_melissa_export_nodal(void *this_writer_p,
150 const fvm_nodal_t *mesh);
151
152/*----------------------------------------------------------------------------
153 * Write field associated with a nodal mesh to a Melissa output.
154 *
155 * Assigning a negative value to the time step indicates a time-independent
156 * field.
157 *
158 * Fields already exported by another Melissa writer will be ignored,
159 * as will fields already exported for the same or greater time step,
160 * or exported with a different time dependency.
161 * Use a different field name if you really need to output fields in such
162 * a configuration.
163 *
164 * parameters:
165 * writer <-- pointer to associated writer
166 * mesh <-- pointer to associated nodal mesh structure
167 * name <-- variable name
168 * location <-- variable definition location (nodes or elements)
169 * dimension <-- variable dimension (0: constant, 1: scalar,
170 * 3: vector, 6: sym. tensor, 9: asym. tensor)
171 * interlace <-- indicates if variable in memory is interlaced
172 * n_parent_lists <-- indicates if variable values are to be obtained
173 * directly through the local entity index (when 0) or
174 * through the parent entity numbers (when 1 or more)
175 * parent_num_shift <-- parent number to value array index shifts;
176 * size: n_parent_lists
177 * datatype <-- indicates the data type of (source) field values
178 * time_step <-- number of the current time step
179 * time_value <-- associated time value (ignored)
180 * field_values <-- array of associated field value arrays
181 *----------------------------------------------------------------------------*/
182
183void
184fvm_to_melissa_export_field(void *this_writer_p,
185 const fvm_nodal_t *mesh,
186 const char *name,
187 fvm_writer_var_loc_t location,
188 int dimension,
189 cs_interlace_t interlace,
190 int n_parent_lists,
191 const cs_lnum_t parent_num_shift[],
192 cs_datatype_t datatype,
193 int time_step,
194 double time_value,
195 const void *const field_values[]);
196
197/*----------------------------------------------------------------------------*/
198
200
201#endif /* FVM_TO_MELISSA_H */
cs_datatype_t
Definition: cs_defs.h:290
Definition: cs_defs.h:528
cs_interlace_t
Definition: cs_defs.h:504
Definition: cs_defs.h:529
Definition: cs_defs.h:325
fvm_element_t
Definition: fvm_defs.h:44
void * fvm_to_melissa_finalize_writer(void *this_writer_p)
Definition: fvm_to_melissa.cpp:442
int fvm_to_melissa_needs_tesselation(void *this_writer_p, const fvm_nodal_t *mesh, fvm_element_t element_type)
void fvm_to_melissa_set_mesh_time(void *this_writer_p, const int time_step, const double time_value)
Definition: fvm_to_melissa.cpp:477
void fvm_to_melissa_export_nodal(void *this_writer_p, const fvm_nodal_t *mesh)
Definition: fvm_to_melissa.cpp:495
void fvm_to_melissa_export_field(void *this_writer_p, const fvm_nodal_t *mesh, const char *name, fvm_writer_var_loc_t location, int dimension, cs_interlace_t interlace, int n_parent_lists, const cs_lnum_t parent_num_shift[], cs_datatype_t datatype, int time_step, double time_value, const void *const field_values[])
Definition: fvm_to_melissa.cpp:534
void * fvm_to_melissa_init_writer(const char *name, const char *path, const char *options, fvm_writer_time_dep_t time_dependency, MPI_Comm comm)
Definition: fvm_to_melissa.cpp:277
Definition: fvm_writer.h:57
Definition: fvm_writer.h:69
Definition: mesh.f90:26
