fvm_to_med.h
1#ifndef FVM_TO_MED_H
2#define FVM_TO_MED_H
4#if defined(HAVE_MED)
5
6/*============================================================================
7 * Write a nodal representation associated with a mesh and associated
8 * variables to MED files
9 *============================================================================*/
11/*
12 This file is part of code_saturne, a general-purpose CFD tool.
13
14 Copyright (C) 1998-2026 EDF S.A.
15
16 This program is free software; you can redistribute it and/or modify it under
17 the terms of the GNU General Public License as published by the Free Software
18 Foundation; either version 2 of the License, or (at your option) any later
19 version.
20
21 This program is distributed in the hope that it will be useful, but WITHOUT
22 ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
23 FOR A PARTICULAR PURPOSE. See the GNU General Public License for more
24 details.
25
26 You should have received a copy of the GNU General Public License along with
27 this program; if not, write to the Free Software Foundation, Inc., 51 Franklin
28 Street, Fifth Floor, Boston, MA 02110-1301, USA.
29*/
30
31/*----------------------------------------------------------------------------*/
32
33#include "base/cs_defs.h"
34
35/*----------------------------------------------------------------------------
36 * Local headers
37 *----------------------------------------------------------------------------*/
38
39#include "fvm/fvm_defs.h"
40#include "fvm/fvm_nodal.h"
41#include "fvm/fvm_writer.h"
43/*----------------------------------------------------------------------------*/
46
47/*=============================================================================
48 * Macro definitions
50
51/*============================================================================
52 * Type definitions
53 *============================================================================*/
54
55/*=============================================================================
56 * Public function prototypes
58
59/*----------------------------------------------------------------------------
60 * Returns number of library version strings associated with the MED format.
61 *
62 * The first associated version string should corresponds to the MED library,
63 * The second to the HDF5 library.
64 *
65 * returns:
66 * number of library version strings associated with the MED format.
67 *----------------------------------------------------------------------------*/
68
69int
70fvm_to_med_n_version_strings(void);
71
72/*----------------------------------------------------------------------------
73 * Returns a library version string associated with the MED format.
74 *
75 * The first associated version string should corresponds to the MED library,
76 * The second to the HDF5 library.
77 *
78 * In certain cases, when using dynamic libraries, fvm may be compiled
79 * with one library version, and linked with another. If both run-time
80 * and compile-time version information is available, this function
81 * will return the run-time version string by default.
82 *
83 * Setting the compile_time flag to 1, the compile-time version string
84 * will be returned if this is different from the run-time version.
85 * If the version is the same, or only one of the 2 version strings are
86 * available, a NULL character string will be returned with this flag set.
87 *
88 * parameters:
89 * string_index <-- index in format's version string list (0 to n-1)
90 * compile_time <-- 0 by default, 1 if we want the compile-time version
91 * string, if different from the run-time version.
92 *
93 * returns:
94 * pointer to constant string containing the library's version.
95 *----------------------------------------------------------------------------*/
96
97const char *
98fvm_to_med_version_string(int string_index,
99 int compile_time_version);
100
101/*----------------------------------------------------------------------------
102 * Initialize FVM to MED file writer.
103 *
104 * Options are:
105 * discard_polygons do not output polygons or related values
106 * discard_polyhedra do not output polyhedra or related values
107 * divide_polygons tesselate polygons with triangles
108 * divide_polyhedra tesselate polyhedra with tetrahedra and pyramids
109 * (adding a vertex near each polyhedron's center)
110 * serial_io force serial IO even when parallel IO is available
111 *
112 * parameters:
113 * name <-- base output case name.
114 * options <-- whitespace separated, lowercase options list
115 * time_dependecy <-- indicates if and how meshes will change with time
116 * comm <-- associated MPI communicator.
117 *
118 * returns:
119 * pointer to opaque MED writer structure.
120 *----------------------------------------------------------------------------*/
121
122#if defined(HAVE_MPI)
123
124void *
125fvm_to_med_init_writer(const char *const name,
126 const char *const path,
127 const char *const options,
128 const fvm_writer_time_dep_t time_dependency,
129 const MPI_Comm comm);
130
131#else
132
133void *
134fvm_to_med_init_writer(const char *const name,
135 const char *const path,
136 const char *const options,
137 const fvm_writer_time_dep_t time_dependency);
138
139#endif
140
141/*----------------------------------------------------------------------------
142 * Finalize FVM to MED file writer.
143 *
144 * parameters:
145 * this_writer_p <-- pointer to opaque MED writer structure.
146 *
147 * returns:
148 * null pointer.
149 *----------------------------------------------------------------------------*/
150
151void *
152fvm_to_med_finalize_writer(void *this_writer_p);
153
154/*----------------------------------------------------------------------------
155 * Indicate if a elements of a given type in a mesh associated to a given
156 * MED file writer need to be tesselated.
157 *
158 * parameters:
159 * this_writer <-- pointer to associated writer
160 * mesh <-- pointer to nodal mesh structure that should be written
161 * element_type <-- element type we are interested in
162 *
163 * returns:
164 * 1 if tesselation of the given element type is needed, 0 otherwise
165 *----------------------------------------------------------------------------*/
166
167int
168fvm_to_med_needs_tesselation(void *this_writer,
169 const fvm_nodal_t *mesh,
170 fvm_element_t element_type);
171
172/*----------------------------------------------------------------------------
173 * Associate new time step with a MED mesh.
174 *
175 * parameters:
176 * this_writer <-- pointer to associated writer
177 * time_step <-- time step number
178 * time_value <-- time_value number
179 *----------------------------------------------------------------------------*/
180
181void
182fvm_to_med_set_mesh_time(void *const this_writer,
183 const int time_step,
184 const double time_value);
185
186/*----------------------------------------------------------------------------
187 * Indicate a given mesh is present in a MED file.
188 *
189 * This does not do any verification that the mesh is indeed present,
190 * so this should be ensured before. The writer info is simply updated
191 * so that additional fields may be output or updated in an existing file.
192 *
193 * parameters:
194 * this_writer <-- pointer to associated writer.
195 * mesh <-- pointer to nodal mesh structure that should be written.
196 *----------------------------------------------------------------------------*/
197
198void
199fvm_to_med_map_nodal(void *this_writer,
200 const fvm_nodal_t *mesh);
201
202/*----------------------------------------------------------------------------
203 * Write nodal mesh to a MED file
204 *
205 * parameters:
206 * this_writer_p <-- pointer to associated writer.
207 * mesh <-- pointer to nodal mesh structure that should be written.
208 *----------------------------------------------------------------------------*/
209
210void
211fvm_to_med_export_nodal(void *const this_writer_p,
212 const fvm_nodal_t *const mesh);
213
214/*----------------------------------------------------------------------------
215 * Write field associated with a nodal mesh to a MED file.
216 *
217 * Assigning a negative value to the time step indicates a time-independent
218 * field (in which case the time_value argument is unused).
219 *
220 * parameters:
221 * this_writer_p <-- pointer to associated writer
222 * mesh <-- pointer to associated nodal mesh structure
223 * name <-- variable name
224 * location <-- variable definition location (nodes or elements)
225 * dimension <-- variable dimension (0: constant, 1: scalar,
226 * 3: vector, 6: sym. tensor, 9: asym. tensor)
227 * interlace <-- indicates if variable in memory is interlaced
228 * n_parent_lists <-- indicates if variable values are to be obtained
229 * directly through the local entity index (when 0) or
230 * through the parent entity numbers (when 1 or more)
231 * parent_num_shift <-- parent number to value array index shifts;
232 * size: n_parent_lists
233 * datatype <-- indicates the data type of (source) field values
234 * time_step <-- number of the current time step
235 * time_value <-- associated time value
236 * field_values <-- array of associated field value arrays
237 *----------------------------------------------------------------------------*/
238
239void
240fvm_to_med_export_field(void *const this_writer,
241 const fvm_nodal_t *const mesh,
242 const char *const name,
243 const fvm_writer_var_loc_t location,
244 const int dimension,
245 const cs_interlace_t interlace,
246 const int n_parent_lists,
247 const cs_lnum_t parent_num_shift[],
248 const cs_datatype_t datatype,
249 const int time_step,
250 const double time_value,
251 const void *const field_values[]);
252
253/*----------------------------------------------------------------------------*/
254
256
257#endif /* FVM_TO_MED_H */
258
259#endif /* HAVE_MED */
cs_datatype_t
Definition: cs_defs.h:290
Definition: cs_defs.h:528
cs_interlace_t
Definition: cs_defs.h:504
Definition: cs_defs.h:529
Definition: cs_defs.h:325
fvm_element_t
Definition: fvm_defs.h:44
Definition: fvm_writer.h:57
Definition: fvm_writer.h:69
Definition: mesh.f90:26
