fvm_interpolate.h
1#ifndef FVM_INTERPOLATE_H
2#define FVM_INTERPOLATE_H
5 * Interpolate data defined on a nodal representation associated with a mesh.
30#include "base/cs_defs.h"
33 * Local headers
36#include "fvm/fvm_defs.h"
37#include "fvm/fvm_nodal.h"
38
39/*=============================================================================
40 * Macro definitions
41 *============================================================================*/
43/*============================================================================
44 * Type definitions
46
47/*=============================================================================
48 * Static global variables
50
51/*=============================================================================
52 * Public function prototypes
53 *============================================================================*/
54
55/*----------------------------------------------------------------------------
56 * Interpolate vertex-based values to points located relative to a mesh.
57 *
58 * Least-squared based interpolation is used for now.
59 *
60 * parameters:
61 * this_nodal <-- pointer to nodal mesh representation structure
62 * entity_dim <-- 3 for location on cells, 2 for faces, 1 for edges,
63 * and 0 for vertices
64 * data_dim <-- data dimension
65 * n_points <-- number of points to locate
66 * location_id <-- id of element (with concatenated sections)
67 * in which each point is located
68 * point_coords <-- point coordinates
69 * src_data <-- source data (interleaved)
70 * dest_data <-> destination data (interleaved)
71 *----------------------------------------------------------------------------*/
72
73void
74fvm_interpolate_vtx_data(const fvm_nodal_t *this_nodal,
75 int entity_dim,
76 int data_dim,
77 cs_lnum_t n_points,
78 const cs_lnum_t location_id[],
79 const cs_coord_t point_coords[],
80 const cs_real_t src_data[],
81 cs_real_t dest_data[]);
82
83/*----------------------------------------------------------------------------*/
84
85#endif /* FVM_INTERPOLATE_H */
Definition: cs_defs.h:332
double cs_coord_t
Definition: cs_defs.h:330
Definition: cs_defs.h:325
void fvm_interpolate_vtx_data(const fvm_nodal_t *this_nodal, int entity_dim, int data_dim, cs_lnum_t n_points, const cs_lnum_t location_id[], const cs_coord_t point_coords[], const cs_real_t src_data[], cs_real_t dest_data[])
Definition: fvm_interpolate.cpp:105
