user Directory Reference
Files
file  cs_user_1d_wall_thermal.cpp
file  cs_user_atmo.cpp
 User-defined functions specific to amospheric flow models.
file  cs_user_boundary_conditions.cpp
 User functions for boundary condition definitions.
file  cs_user_coupling.cpp
 Code couplings definition with SYRTHES and code_saturne.
file  cs_user_electric_scaling.cpp
 Define scaling parameter for electric model.
file  cs_user_extra_operations.cpp
 The cs_user_extra_operations series of function have a very broad purpose (i.e. handing anything that does not have another dedicated user function).
file  cs_user_fluid_structure_interaction.cpp
 User-defined functions dedicated to Fluid-Structure interaction modeling.
file  cs_user_head_losses.cpp
 User head loss definitions.
file  cs_user_hgn.cpp
 Define user properties for two-phase homogeneous compressible model.
file  cs_user_ibm.cpp
file  cs_user_ibm_modify.cpp
file  cs_user_initialization.cpp
 Initialization prior to solving time steps.
file  cs_user_lagr_boundary_conditions.cpp
file  cs_user_lagr_model.cpp
file  cs_user_lagr_particle.cpp
file  cs_user_lagr_volume_conditions.cpp
file  cs_user_les_inflow.cpp
file  cs_user_mesh.cpp
 Definition and modification of the calculation mesh.
file  cs_user_paramedmem_coupling.cpp
 User functions for input of ParaMEDMEM coupling parameters.
file  cs_user_parameters.cpp
 User functions for input of calculation parameters.
file  cs_user_performance_tuning.cpp
 Definition of advanced options relative to parallelism.
file  cs_user_physical_properties.cpp
 User definition of physical properties.
file  cs_user_porosity.cpp
 User definitions of porous media.
file  cs_user_postprocess.cpp
file  cs_user_radiative_transfer.cpp
 User function for input of radiative transfer parameters: absorption coefficient and net radiation flux.
file  cs_user_radiative_transfer_bcs.cpp
file  cs_user_solver.cpp
 User solver setting and implementation.
file  cs_user_source_terms.cpp
 Additional source terms for variable equations.
file  cs_user_time_table.cpp
 User definitions of time tables.
file  cs_user_turbomachinery.cpp
 Definition of turbomachinery related options.
file  cs_user_wall_condensation.cpp
 Source terms associated at the boundary faces and the neighboring cells with surface condensation.
file  cs_user_zones.cpp
