Force temperature in a given region
This is an example of cs_user_extra_operations which sets temperature to 20 in a given region starting at t = 12s
Body
Do this with precaution... The user is responsible for the validity of results.
/* Example: set temperature to 20 in a given region starting at t = 12s
const double t_cur = domain->time_step->t_cur;
if ((CS_F_(t) != nullptr) && (t_cur >= 12.0)) {
cs_real_t *cvar_t = CS_F_(t)->val;
cs_array_real_set_scalar(domain->mesh->n_cells, 20.0, cvar_t);
bft_printf("User modification of variables at the end of the time step");
Definition: bft_printf.cpp:134
void cs_array_real_set_scalar(cs_lnum_t n_elts, cs_real_t ref_val, cs_real_t a[])
Assign a constant scalar value to an array.
Definition: cs_array.cpp:716
Definition: cs_defs.h:332
@ t
Definition: cs_field_pointer.h:91
#define CS_F_(e)
Definition: cs_field_pointer.h:47
