cs_turbulence_rij.h
1#ifndef CS_TURBULENCE_RIJ_H
2#define CS_TURBULENCE_RIJ_H
5 * Rij-epsilon turbulence model.
31 * Local headers
34#include "base/cs_defs.h"
36/*=============================================================================
37 * Public function prototypes
51/*-----------------------------------------------------------------------------*/
52
53extern "C" void
54cs_turbulence_rij(int phase_id);
55
56/*----------------------------------------------------------------------------*/
65/*----------------------------------------------------------------------------*/
66
67extern "C" void
69 int phase_id,
70 cs_real_t c_durbin_l);
71
72/*----------------------------------------------------------------------------*/
82/*----------------------------------------------------------------------------*/
83
84extern "C" void
86 cs_real_t almax);
87
88/*----------------------------------------------------------------------------*/
96/*----------------------------------------------------------------------------*/
97
98extern "C" void
99cs_turbulence_rij_clip(int phase_id,
100 cs_lnum_t n_cells);
101
102/*----------------------------------------------------------------------------*/
108/*----------------------------------------------------------------------------*/
109
110extern "C" void
111cs_turbulence_rij_mu_t(int phase_id);
112
124/*----------------------------------------------------------------------------*/
125
126extern "C" void
128(
129 const cs_mesh_quantities_t *mq,
130 cs_lnum_t n_cells,
131 int phase_id,
132 bool idfm,
133 bool iggafm,
134 bool iebdfm
135);
136
137/*----------------------------------------------------------------------------*/
140/*----------------------------------------------------------------------------*/
141
142extern "C" void
144
145/*----------------------------------------------------------------------------*/
146
147#endif /* CS_TURBULENCE_RIJ_H */
Definition: cs_defs.h:332
Definition: cs_defs.h:325
void cs_turbulence_rij_clip(int phase_id, cs_lnum_t n_cells)
Clip the turbulent Reynods stress tensor and the turbulent dissipation (coupled components version).
Definition: cs_turbulence_rij.cpp:3850
void cs_turbulence_rij_anisotropic_mu_t(const cs_mesh_quantities_t *mq, cs_lnum_t n_cells, int phase_id, bool idfm, bool iggafm, bool iebdfm)
Compute anisotropic turbulent viscosity for RSM models.
Definition: cs_turbulence_rij.cpp:4238
void cs_turbulence_rij_mu_t(int phase_id)
Compute the turbulent viscosity for the Reynolds Stress model.
Definition: cs_turbulence_rij.cpp:4126
void cs_turbulence_rij_init_by_ref_quantities(cs_real_t uref, cs_real_t almax)
Initialize Rij-epsilon variables based on reference quantities.
Definition: cs_turbulence_rij.cpp:3782
void cs_turbulence_rij_compute_rusanov(void)
Compute Rusanov equivalent diffusivity of the model.
Definition: cs_turbulence_rij.cpp:4392
void cs_turbulence_rij_solve_alpha(int f_id, int phase_id, cs_real_t c_durbin_l)
Solve the equation on alpha in the framework of the Rij-EBRSM model.
Definition: cs_turbulence_rij.cpp:3529
void cs_turbulence_rij(int phase_id)
Solve the for incompressible flows or slightly compressible flows for one time step.
Definition: cs_turbulence_rij.cpp:2922
Definition: cs_mesh_quantities.h:88
