1#ifndef CS_TURBULENCE_KE_H
2#define CS_TURBULENCE_KE_H
Definition: cs_defs.h:332
cs_real_t cs_real_6_t[6]
Definition: cs_defs.h:351
Definition: cs_defs.h:325
@ rij
Definition: cs_field_pointer.h:71
void cs_turbulence_ke_q_mu_t(int phase_id)
Calculation of turbulent viscosity for the non-linear quadratic K-epsilon from Baglietto et al....
Definition: cs_turbulence_ke.cpp:2410
void cs_turbulence_ke_clip(int phase_id, cs_lnum_t n_cells, int iclip)
Clipping of the turbulent kinetic energy and turbulent dissipation.
Definition: cs_turbulence_ke.cpp:2079
void cs_turbulence_ke_q(int phase_id, cs_real_6_t rij[])
Calculation of non linear terms of the quadratic k-epsilon model (Baglietto et al....
Definition: cs_turbulence_ke.cpp:2522
void cs_turbulence_ke(int phase_id, cs_real_t *prdv2f)
Solve the k-epsilon equations.
Definition: cs_turbulence_ke.cpp:280
void cs_turbulence_ke_mu_t(int phase_id)
Calculation of turbulent viscosity for the K-epsilon model.
Definition: cs_turbulence_ke.cpp:2327
