1#ifndef CS_SADDLE_SYSTEM_H
2#define CS_SADDLE_SYSTEM_H
Definition: cs_defs.h:332
Definition: cs_defs.h:325
@ x2
Definition: cs_field_pointer.h:199
cs_real_t * cs_saddle_system_b11_inv_diag(cs_lnum_t b11_max_size, cs_cdo_system_helper_t *sh)
Retrieve the inverse of the diagonal of the (1,1)-block matrix The storage of a matrix is in a gather...
Definition: cs_saddle_system.cpp:460
void cs_saddle_system_b12_matvec(const cs_cdo_system_helper_t *sh, const cs_real_t *x2, cs_real_t *res, bool reset_res)
Compute the resulting vector of the operation m12*x2 The block (1,2) is stored in an unassembled way ...
Definition: cs_saddle_system.cpp:586
void cs_saddle_system_matvec(const cs_cdo_system_helper_t *sh, cs_real_t *x1, cs_real_t *x2, cs_real_t *r1, cs_real_t *r2)
Compute the matrix-vector operation for a saddle-point system r1 = M11.x1 + M12.x2 (result for the fi...
Definition: cs_saddle_system.cpp:693
void cs_saddle_system_b21_matvec(const cs_cdo_system_helper_t *sh, const cs_real_t *x1, cs_real_t *res)
Compute the resulting vector of the operation m21*x1 The block (2,1) is stored in an unassembled way....
Definition: cs_saddle_system.cpp:642
void cs_saddle_system_residual(const cs_cdo_system_helper_t *sh, cs_real_t *x1, cs_real_t *x2, cs_real_t *res1, cs_real_t *res2)
Compute the residual of the saddle-point system res1 = rhs1 - M11.x1 - M12.x2 (residual for the first...
Definition: cs_saddle_system.cpp:778
void cs_saddle_system_b11_matvec(const cs_cdo_system_helper_t *sh, cs_real_t *vec, cs_real_t *matvec)
Perform a matrix-vector multiplication for the (1,1) block when the input vector is in a scatter stat...
Definition: cs_saddle_system.cpp:531
Definition: cs_cdo_system.h:373
