1#ifndef CS_MESH_CARTESIAN_H
2#define CS_MESH_CARTESIAN_H
50typedef struct _cs_mesh_cartesian_params_t cs_mesh_cartesian_params_t;
77cs_mesh_cartesian_params_t *
91cs_mesh_cartesian_params_t *
105cs_mesh_cartesian_params_t *
117cs_mesh_cartesian_params_t *
205 const char *csv_file_name);
Definition: cs_defs.h:528
Definition: cs_defs.h:332
unsigned cs_gnum_t
global mesh entity number
Definition: cs_defs.h:317
Definition: cs_defs.h:529
Definition: cs_defs.h:325
void cs_mesh_cartesian_set_gc_id_shift(int id, int shift)
Set group class id shift of cartesian mesh.
Definition: cs_mesh_cartesian.cpp:1121
cs_mesh_cartesian_params_t * cs_mesh_cartesian_by_id(const int id)
Return pointer to cartesian mesh parameters structure.
Definition: cs_mesh_cartesian.cpp:638
cs_gnum_t cs_mesh_cartesian_get_n_g_vtx(int id)
Get global number of vertices of a cartesian mesh.
Definition: cs_mesh_cartesian.cpp:1176
cs_mesh_cartesian_params_t * cs_mesh_cartesian_create(const char *name)
Create cartesian mesh structure.
Definition: cs_mesh_cartesian.cpp:703
cs_mesh_cartesian_params_t * cs_mesh_cartesian_by_name_try(const char *name)
Get function for structured mesh based on its name.
Definition: cs_mesh_cartesian.cpp:657
int cs_mesh_cartesian_get_number_of_meshes(void)
Return number of structured meshes to build.
Definition: cs_mesh_cartesian.cpp:622
cs_mesh_cartesian_params_t * cs_mesh_cartesian_by_name(const char *name)
Definition: cs_mesh_cartesian.cpp:676
void cs_mesh_cartesian_set_max_number_of_blocks(int n_blocks)
Set maximum number of cartesian blocks (by default is set to None)
Definition: cs_mesh_cartesian.cpp:1469
void cs_mesh_cartesian_finalize_definition(void)
Compute all global values for meshes.
Definition: cs_mesh_cartesian.cpp:1412
void cs_mesh_cartesian_block_connectivity(int id, cs_mesh_t *m, cs_mesh_builder_t *mb, long echo)
Build unstructured connectivity needed for partitionning.
Definition: cs_mesh_cartesian.cpp:1213
cs_gnum_t cs_mesh_cartesian_get_n_g_faces(int id)
Get global number of faces of a cartesian mesh.
Definition: cs_mesh_cartesian.cpp:1158
int cs_mesh_cartesian_define_simple(const char *name, int ncells[3], cs_real_t xyz[6])
Define a simple cartesian mesh with a constant step in all directions.
Definition: cs_mesh_cartesian.cpp:725
int cs_mesh_cartesian_need_build(void)
Indicate if a cartesian mesh is to be built.
Definition: cs_mesh_cartesian.cpp:1067
void cs_mesh_cartesian_define_dir_params(cs_mesh_cartesian_params_t *mp, int idim, cs_mesh_cartesian_law_t law, int ncells, cs_real_t smin, cs_real_t smax, cs_real_t progression)
Define parameters for a given direction.
Definition: cs_mesh_cartesian.cpp:1000
void cs_mesh_cartesian_define_dir_user(cs_mesh_cartesian_params_t *mp, int idir, int ncells, cs_real_t vtx_coord[])
Define directions parameters based on a user input.
Definition: cs_mesh_cartesian.cpp:755
int cs_mesh_cartesian_get_gc_id_shift(int id)
Get group class id shift of cartesian mesh.
Definition: cs_mesh_cartesian.cpp:1103
int cs_mesh_cartesian_get_ncells(int id, int idim)
Get number of cells in a given direction.
Definition: cs_mesh_cartesian.cpp:1194
void cs_mesh_cartesian_define_from_csv(const char *name, const char *csv_file_name)
Define a simple cartesian mesh based on a CSV file. CSV file needs to contain : (1) First line which ...
Definition: cs_mesh_cartesian.cpp:903
const char * cs_mesh_cartesian_get_name(int id)
Get name of structured mesh.
Definition: cs_mesh_cartesian.cpp:1085
void cs_mesh_cartesian_define_dir_geom_by_part(cs_mesh_cartesian_params_t *mp, int idir, int n_parts, const cs_real_t part_coords[], const cs_lnum_t n_part_cells[], const cs_real_t amp_factors[])
Define direction parameters based on a piecewise definition. Each part follows a geometric (or unifor...
Definition: cs_mesh_cartesian.cpp:808
void cs_mesh_cartesian_params_destroy(void)
Destroy cartesian mesh parameters.
Definition: cs_mesh_cartesian.cpp:1442
Definition: cs_mesh_cartesian.h:40
@ CS_MESH_CARTESIAN_USER_LAW
Definition: cs_mesh_cartesian.h:45
@ CS_MESH_CARTESIAN_CONSTANT_LAW
Definition: cs_mesh_cartesian.h:42
@ CS_MESH_CARTESIAN_N_LAW_TYPES
Definition: cs_mesh_cartesian.h:46
@ CS_MESH_CARTESIAN_PARABOLIC_LAW
Definition: cs_mesh_cartesian.h:44
@ CS_MESH_CARTESIAN_GEOMETRIC_LAW
Definition: cs_mesh_cartesian.h:43
cs_gnum_t cs_mesh_cartesian_get_n_g_cells(int id)
Get global number of cells of a cartesian mesh.
Definition: cs_mesh_cartesian.cpp:1140
integer(c_int), pointer, save smin
starting min
Definition: atincl.f90:144
Definition: cs_mesh_builder.h:57
